AP836 1K J 100PPM
AP836 1K J 100PPM
    ARCOL(艾高)
    ARCOL - AP836 1K J 100PPM - Through Hole Resistor, 1 kohm, AP836, 35 W, ± 5%, TO-220, 350 V
AP836 1K J 100PPM 数据手册
AP836 35 Watts TO-220 High Power Resistors A high power TO-220 style resistor package designed for high frequency emitter circuits in switching power supplies. Also used in voltage regulation and low energy pulse loading. • 35 Watts at 25˚C case temperature on heat sink • Single screw mounting to heat sink • Moulded case for proctection and easy to mount • Non-inductive design • Electrically isolated case • RoHS Compliant Characteristics Power rating: 2.50 Watts in free air Operating voltage: 350V max Dielectric strength: 1800Vac Insulation resistance: 10GΩ min Working temperature: -65ºC to 150ºC Temperature coefficient: As specified, referenced to 25˚C, ∆R taken at +105˚C Short time overload: ∆R ±0.3%, 2 times rated power with applied voltage not to exceed 1.5 times maximum continuous operating voltage for 5 seconds Load life: ∆R ±1.0%, 2000 hours at rated power Damp heat with load: ∆R ±0.5%, 40 ±2˚C, 90 - 95% R.H max working voltage for 1000 hours with 1.5 hours “ON” and 0.5 hours “OFF” Solderability: 90% min coverage, 245 ±5˚C for 3 seconds Thermal shock: ∆R ±0.3%, -65˚C - 150˚C, 100 cycles Terminal strength: ∆R ±0.2%, 2.4 N Vibration and high frequency: ∆R ±0.2%, 20g peak Electrical Specifications Resistance Value Range Available Tolerance & Pref. Available TCR Value Ranges R05 - 1R J (±5%) K (±10%) 3R01 - 10R 10R2 - 10K F (±1%) , J (±5%) , K (±10%) D (±0.5%) F (±1%) J (±5%) K (±10%) 100 Not specified ±300ppm/˚C Power Rated % 1R02 - 3R Derating Curve ±100ppm/˚C ±200ppm/˚C ±50ppm/˚C ±100ppm/˚C ±200ppm/˚C 80 60 40 20 0 0 25 50 Preferred value ranges: F (±1%) - E96 , J (±5%) - E24, K (±10%) - E12 75 100 125 150 175 Case Temperature (°C) ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 1 of 2 3/14.35 AP836 35 Watts TO-220 High Power Resistors Ordering Procedure Standard Resistor: Series, Resistance Value, Tolerance Code, 0.571 0.591" (14.50 14.5015.00mm) - 15.00 0.112 0.120" 0.159 0.190" (4.06 4.064.82mm) - 4.82 0.046 0.054" (1.17 1.17 1.37mm) - 1.37 eg: AP836 10K J ± 50ppm/°C 0.022 0.028" (0.55 0.400.70mm) - 0.70 0.080 0.089" (2.05 2.052.52mm) - 2.52 0.500 0.597" (12.70 12.7014.70mm) - 14.70 0.157" Max (4.00mm) 4.00 max 0.19 0.21" (4.83 4.835.33mm) - 5.33 0.027 0.034" (0.70 0.70 0.86mm) - 0.86 TCR 0.047 0.055" (1.20 1.201.40mm) - 1.40 0.23 0.25" (5.85 5.856.35mm) - 6.35 0.139 0.148" (3.55 3.55-3.75mm) 3.95 0.39 0.41" (9.91 9.9110.41mm) - 10.41 (2.85 -3.05mm) 2.65 3.05 Dimensions (mm) ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 2 of 2 3/14.35
AP836 1K J 100PPM
物料型号:AP836
器件简介: - 35瓦特在25°C的散热器温度下 - 单螺钉安装到散热器 - 模制外壳,便于安装和保护 - 非感性设计 - 电气隔离外壳 - 符合RoHS标准
引脚分配: - 尺寸:14.50 - 15.00mm(长),2.85 - 3.05mm(宽),4.06 - 4.82mm(高),9.91 - 10.41mm(引脚间距),1.20 - 1.40mm(引脚直径),3.55 - 3.75mm(引脚长度),5.85 - 6.35mm(引脚间距),0.55 - 0.70mm(引脚间距),1.17 - 1.37mm(引脚间距),2.05 - 2.52mm(引脚间距),4.83 - 5.33mm(引脚间距),12.70 - 14.70mm(引脚间距),4.00mm(最大尺寸),0.70 - 0.86mm(引脚间距)。
参数特性: - 功率额定值:35瓦特 - 工作电压:最大350V - 绝缘电阻:最小1800V AC - 工作温度:-65°C至150°C - 短时过载:在25°C时,电阻变化±0.3%,额定功率的2倍,电压不超过最大连续工作电压的1.5倍,持续5秒 - 负载寿命:在额定功率下2000小时,电阻变化±1.0%,在40±2°C,90 - 95% R.H下,最大工作电压下1000小时,1.5小时“开”和0.5小时“关” - 焊锡性:90%最小覆盖,245±5°C持续3秒 - 振动和高频:-65°C至150°C,100个周期,电阻变化±0.3%,2.4N峰值,电阻变化±0.2%
功能详解: - 电阻值范围:R05-1R,1R02-3R,3R01-10R,10R2-10K - 可用的容差和优选值范围:F(±1%),J(±5%),K(±10%) - 可用的温度系数:+300ppm/C,+100ppm/C,+200ppm/C,+50ppm/C,+100ppm/C,+200ppm/C
应用信息: - 适用于高频发射极电路、开关电源、电压调节和低能量脉冲负载
封装信息: - TO-220封装
AP836 1K J 100PPM 价格&库存
很抱歉,暂时无法提供与“AP836 1K J 100PPM”相匹配的价格&库存,您可以联系我们找货
