HS Aluminium Housed Resistors
Manufactured in line with the requirements of MIL 18546 and
IEC 115, designed for direct heatsink mounting with thermal
compound to achieve maximum performance.
• High Power to volume
• Wound to maximise High Pulse Capability
• Values from R005 to 100K
• Custom designs welcome
• RoHS Compliant
Characteristics
Tolerance (Code):
Standard ±5% (J) and ±10% (K). Also available ±1% (F), ±2% (G) and ±3% (H)
Tolerance for low Ω values:
Typically ≥ R05 ±5% ≤ R047 ±10%
Temperature coefficients:
Typical values < 1K 100ppm Std. > 1K 25ppm Std. For lower TCR’s please contact Arcol
Insulation resistance (Dry):
10,000 MΩ minimum
Power dissipation:
At high ambient temperature dissipation derates linearly to zero at 200°C
Ohmic values:
From R005 to 100K depending on wattage size
Low inductive (NHS):
Specify by adding N before HS Series code, e.g. NHS50
NHS ohmic value:
Divide standard HS maximum value by 4
NHS working volts:
Divide standard HS maximum working voltage by 1.414
Temp. Rise & Power Dissipation
Heat Dissipation
Surface temperature of resistor related to power dissipation.
Heat dissipation: Whilst the use of proprietary heat sinks
The resistor is standard heatsink mounted using a proprietary
with lower thermal resistances is acceptable, uprating is not
heatsink compound.
recommended. For maximum heat transfer it is recommended
that a heat sink compound be applied between the resistor
S U RFACE T E M P E R ATU R E R I S E ( ˚ C)
200
HS300
HS150
HS50
100
the maximum hot spot temperature of 200°C is not exceeded,
HS250
HS200
therefore, the resistor must be mounted on a heat sink of
correct thermal resistance for the power being dissipated.
HS25
HS100
HS75
HS15
HS10
Ordering Procedure
5
base and heat sink chassis mounting surface. It is essential that
50
75
100
150
200
P OW ER DISSI PATI ON (WATTS )
250
300
Standard Resistor. To specify standard: Series, Watts, Ohmic
Value, Tolerance Code, e.g.: HS25 2R2 J
Non Inductive Resistor. To specify add N, e.g.: NHS100 10R J
ARCOL UK Limited,
The information contained herein does not form part of a
Threemilestone Ind. Estate,
contract and is subject to change without notice. ARCOL
Truro, Cornwall, TR4 9LG, UK.
operate a policy of continual product development, therefore,
T +44 (0) 1872 277431
specifications may change.
F +44 (0) 1872 222002
E sales@arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask ARCOL.
For more information and ordering, please consult
www.arcolresistors.com
Page 1 of 2
12/14.08
Electrical Specifications
Style
MIL-R
18546
Power
rating
on std.
heatsink
@25°C
Watts
with no
heatsink
@25°C
Resistance
range
Limiting
element
voltage
Voltage
proof AC
Peak
Voltage
proof AC
rms.
Approx
weight
gms
Typical
surface
rise HS
mounted
HS10
RE 60
10
5
R005-10K
160
1400
1000
4
5.8
Size
Standard heatsink
cm2
Thickness
mm
415
1
HS15
RE 65
15
7
R005-10K
265
1400
1000
7
5.1
415
1
HS25
RE 70
25
9
R005-36K
550
3500
2500
14
4.2
535
1
HS50
RE 75
HS75
50
14
R01-86K
1250
3500
2500
32
3.0
535
1
75
24
R01-50K
1400
6363
4500
85
1.1
995
3
HS100
100
30
R01-70K
1900
6363
4500
115
1.0
995
3
HS150
150
45
R01-100K
2500
6363
4500
175
1.0
995
3
HS200
200
50
R01-50K
1900
7070
5000
475
0.7
3750
3
HS250
250
55
R01-50K
2200
7070
5000
600
0.6
4765
3
HS300
300
60
R01-68K
2500
7070
5000
700
0.6
5780
3
HS10-HS300 Standard Resistor
Centre hole in
150 Watts only
J
L
J
L
J
L
6mm
3.0 ± 0.1
2.1 ± 0.1
G A
HS 10, 15, 25, 50
G A
HS 75, 100, 150
G A
HS 200, 250, 300
Ø 3.2
max.
Ø 2.0
± 0.25
F
E
F
E
B
B
F
E
M
B
D
D
D
C
C
H
C
H
K
H
K
K
Dimensions (mm)
Size
A Max
B Max
C Max
D Max
E Max
F±0.3
G±0.3
H Max
J Max
K Max
L ±0.25*
M Max
HS10
16.5
30.0
8.8
8.5
15.9
11.3
12.4
4.5
2.4
1.8
2.4
HS15
21.0
36.5
11.0
11.2
19.9
14.3
15.9
5.5
2.8
1.8
2.4
HS25
28.0
51.0
14.8
14.2
27.3
18.3
19.8
7.7
5.2
2.6
3.2
HS50
28.0
72.5
14.8
14.2
49.1
39.7
21.4
8.4
5.2
2.6
3.2
HS75
47.5
72.0
24.1
27.3
48.7
29.0
37.0
11.8
10.4
3.7
4.4
HS100
47.5
88.0
24.1
27.3
65.2
35.0
37.0
11.8
15.4
3.7
4.4
HS150
47.5
121.0
24.1
27.3
97.7
58.0
37.0
11.8
20.4
3.7
4.4
HS200
72.5
145.7
41.8
45.5
89.7
70.0
57.2
20.5
10.4
5.5
5.1
103.4
HS250
72.5
167.0
41.8
45.5
109.7
89.0
57.2
20.5
10.4
5.5
5.1
122.4
HS300
72.5
184.4
41.8
45.5
127.7
104.0
59.0
20.5
12.4
5.5
6.6
141.4
* HS200-HS300 Watts is ± 0.45
Page 2 of 2
12/14.08
很抱歉,暂时无法提供与“HS150470RJ”相匹配的价格&库存,您可以联系我们找货
