FPA100 Thick Film Power Resistors
Due to a Non-Inductive design these elements are
ideally suited for high frequency and pulse load
applications. The FPA100 is available connected as 2
terminals or 4 terminals, in parallel or series.
• SOT227 Style package
• Competitively priced
• 100 Watts dissipation in a small footprint
• Very low inductance
• Direct heatsink mounting
Characteristics
Ohmic value range:
E24, contact ARCOL for values outside this series
Tolerance (Code):
Standard J (±5%).
K (±10%) available for 1R to 10R values. F (±1%) also available on request.
TCR:
100ppm (at +105°C ref to +25°C)
Power rating at 25° C:
100W
Max working voltage:
1kV rms
Resistance range:
1R to 5M
Voltage proof:
Dielectric strength 4kVdc
Partial discharge:
Up to 2kV rms / 80 pC
Capacitance/mass:
≤40pF
Working temp range:
-55°C to +155°C
Max. torque for contacts (static):
1.3Nm
Max. torque for base plate (static): 1.5Nm
Inductance:
≤ 50nH
Ordering Procedure
Standard (Version 1) Resistor Specify Series, Watts, Ohmic
Derating Curve
100
Value, Tolerance Code, e.g.: FPA100 2R2 J
Rated Power %
Versions 2, 3, 4 or 5 Specify Series, Watts, Ohmic Value or
Values, Tolerance Code and then Version Number,
e.g.: FPA100 2R2 2R2 J version 4.
Refer to versions available on page 2.
75
50
25
50 100 125 155
Temperature ˚C
ARCOL UK Limited,
The information contained herein does not form part of a
Threemilestone Ind. Estate,
contract and is subject to change without notice. ARCOL
Truro, Cornwall, TR4 9LG, UK.
operate a policy of continual product development, therefore,
T +44 (0) 1872 277431
specifications may change.
F +44 (0) 1872 222002
E sales@arcolresistors.com
www.arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask ARCOL.
Page 1 of 2
13 / 15.33
Dimensions (mm)
A
G
1
M
M4
L
2
8.2
F
D
E
A
B
C
D min
E
F
Min
38
30.1
11.5
4.1
4.0
24.4
Max
39
30.3
13.5
N/A
4.3
26.4
G
J
K
L
M
N
7.8
14.5
0.75
1.9
9.5
11.5
C
Min
3
K
4
J
N
B
Versions Available
1
4
1
2
2
4
1
2
3
4
5
3
1
2
3
1
4
1
2
3
4
ARCOL UK Limited,
Page 2 of 2
13/ 15.33
很抱歉,暂时无法提供与“FPA100 100R J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+143.64018
- 100+133.69844
