ITEM
1
2
Q'TY
1
1
PART NUMBER
DC-XXX-XXX
CS-600 F-10.75
PART DESCRIPTION
DEEP CHANNEL PRESS-IN CARD GUIDE
CONDUCTIVE INSERT
REV.
A
B
C
D
E
+0.3mm
0.01+0.01
-0.00 0.2mm-0.0mm
0.256 [6.5mm]
A
0.250 [6.4mm]
DESCRIPTION
Engineering Release
ECO#388, Engineering Update.
Updated Conductive Insert P/N
12 Additional Lengths Added
Engineering Update w/o Changes
DATE
APPROVED
02/06/03
05/01/03
03/12/08
07/25/13
05/13/16
M. C.
M. C.
M. C.
T. Y.
J. C.
0.250 [6.4mm]
SW
0.194 [4.9mm]
0.2 [5.1mm]
0.050 [1.3mm]
0.19 [4.8mm]
0.50 [12.7mm] TYP.
45° REF.
0.200 [5.1mm]
C
0.250+0.003
-0.001 TYP.
B
0.01 [0.3mm]
Ø.187+.003
-.001
0.182+0.003
-0.001
TYP.
PART
NO.
A
±.062 (1.6)
B
±.032 (.8)
C
±.015 (.4)
DC-250 CI
DC-400 CI
DC-450 CI
DC-500 CI
DC-550 CI
DC-600 CI
DC-650 CI
DC-700 CI
DC-750 CI
DC-800 CI
2.5 (63.5)
4.0 (101.6)
4.5 (114.3)
5.0 (127.0)
5.5 (139.7)
6.0 (152.4)
6.5 (165.1)
7.0 (177.8)
7.5 (190.5)
8.0 (203.2)
1.5 (38.1)
3.0 (76.2)
3.5 (88.9)
4.0 (101.6)
4.5 (114.3)
5.0 (127.0)
5.5 (139.7)
6.0 (152.4)
6.5 (165.1)
7.0 (177.8)
---------3.5 (88.9)
DC-400-102 CI
DC-450-102 CI
DC-500-102 CI
DC-550-102 CI
DC-600-102 CI
DC-650-102 CI
DC-700-102 CI
DC-750-102 CI
DC-800-102 CI
4.0 (101.6)
4.5 (114.3)
5.0 (127.0)
5.5 (139.7)
6.0 (152.4)
6.5 (165.1)
7.0 (177.8)
7.5 (190.5)
8.0 (203.2)
3.0 (76.2)
3.5 (88.9)
4.0 (101.6)
4.5 (114.3)
5.0 (127.0)
5.5 (139.7)
6.0 (152.4)
6.5 (165.1)
7.0 (177.8)
--------3.5 (88.9)
DC-450-130 CI
DC-600-130 CI
DC-800-130 CI
4.5 (114.3)
6.0 (152.4)
8.0 (203.2)
3.5 (88.9)
5.0 (127.0)
7.0 (177.8)
--3.5 (88.9)
S.W.
±.005 (.1)
.080 (2.0)
.102 (2.6)
.132 (3.4)
PCB
THICKNESS
84101-01
-84101-02
-1/16 (1.6) -84101-03
---84101-04
--3/32 (2.4) -------1/8 (3.2)
C
DESC
DWG. NO.
84101-22
84101-23
84101-24
C
B
Recommended Mounting Holes
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DEEP CHANNEL CARD GUIDE
DATE:
01/06/03
DATE:
01/06/03
REVISION:
PART NO:
DC-XXX-XXX-CI
CAGE CODE : 32559
E
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“DC-600-CI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+21.25663100+2.75145
