REV.
F
G
H
DATE
APPROVED
02/24/04
06/13/13
05/04/16
M. C.
T. Y.
J. C.
DESCRIPTION
Production Release.
Added Max. Allowable Draft Angle.
Added Notes 4, 5, 6 & Color Options Sheet #2
1.10 [27.9mm]
0.250 [6.4mm]
0.37 [9.4mm]
0.08 [1.9mm]
CARD THICKNESS
0.52 [13.2mm]
0.26 [6.5mm]
0.14 [3.6mm]
3°
MAX.
Ø.093 [Ø2.4mm]
PART NO.
COLOR
ROLL PIN
CP-36 NT
CP-36 WE
CP-36 XX
CP-39 NT
CP-39 WE
CP-39 XX
NATURAL
WHITE
SEE S.#2
NATURAL
WHITE
SEE S.#2
RP-250
RP-250
RP-250
RP-250
RP-250
RP-250
CARD
THICK.
1/16"(1.6mm)
0.30 [7.6mm]MIN.
45° x 0.25 [6.4mm]
CHAMFER
0.25 [6.4mm]
0.25 [6.4mm]
3/32"(2.4mm)
0.50 [12.7mm]
0.25 [6.4mm]
Ø.109 [Ø2.8mm]
Recommended Application Layout
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST.
4. ROLL PINS INCLUDED. PACKAGED SEPARATELY.
3. MATERIAL: NYLON 6/6, 94V-2, WHITE.
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
S. Irving
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
CIRCUIT BOARD CARD EJECTOR
DATE:
05/19/98
DATE:
09/09/03
PART NO:
REVISION:
CP-3X
CAGE CODE : 32559
H
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
OTHER AVAILABLE COLORS
* SEE TABLE FOR ORDERING INFORMATION
CP- 3 _
CP SERIES
CP-36
CP-39
__
ORDER CODE
AA
BK
BE
BN
FG
GY
GN
LE
OE
PK
RD
VT
YW
COLOR
AQUA
BLACK
BLUE
BROWN
FOREST GREEN
GRAY
GREEN
LIME
ORANGE
PINK
RED
VIOLET
YELLOW
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
S. Irving
6. PARTS ARE DYED TO COLOR UPON REQUEST.
CHECKED:
M. Chen
DATE:
05/19/98
DATE:
09/09/03
PART NO:
REVISION:
CP-3X
CAGE CODE : 32559
H
SHEET # 2 OF 2
很抱歉,暂时无法提供与“CP-39 OE”相匹配的价格&库存,您可以联系我们找货
