311-200
311-200
    BIVAR
    MOUNT RECT CAPACITORS 0.200"
311-200 数据手册
REV. B C D E DESCRIPTION Engineering Update w/o Changes "0.02" was "0.015", add "0.140" Removed Part Numbers from Table Removed Material Code DATE APPROVED 03/01/04 05/17/04 07/17/14 05/22/16 M. C. M. C. J. C. J. C. 0.140 [3.6mm] 0.02 [0.5mm] Ø.055 [Ø1.4mm] REF. 0.030 [0.8mm] COUNTERBORE, TYP. TYP. Ø.035 [Ø0.9mm]TYP. A PART NO. B A B 311-200 .300 (7.6mm) .200 (5.1mm) 312-250 .350 (8.9mm) .250 (6.4mm) 313-300 .400 (10.2mm) .300 (7.6mm) 315-400 .500 (12.7mm) .400 (10.2mm) 0.050 [1.3mm] TYP. 0.100 [2.5mm] Ø.030 [Ø0.8mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PERM-O-PAD, CAPACITOR MOUNT DATE: 08/03/98 DATE: 08/07/03 PART NO: REVISION: 31X-XXX CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
311-200 价格&库存
很抱歉,暂时无法提供与“311-200”相匹配的价格&库存,您可以联系我们找货
    • 251+1.35120251+0.17503
    • 500+1.31615500+0.17049
    • 1000+1.281891000+0.16605
    库存:251
    311-200
      • 251+1.03594251+0.13419
      库存:251
      311-200
