ELM33005BC-3
ELM33005BC-3
    BIVAR
ELM33005BC-3 数据手册
REV. ITEM Q'TY 1 1 5BC-3-XXXX-F T-1¾ (5mm) Bi-Color/Tri-Color LED, See Page 2 2 1 ELM 3-XXX Extruded, Self-Retaining LED Spacer PART NUMBER PART DESCRIPTION B C D E F 1 DATE APPROVED 11/28/05 09/03/08 09/25/13 03/17/15 05/24/16 M. C. M. C. M. C. J. C. J. C. DESCRIPTION Corrected Extruded to ELM3. Removed Tolerance Note. Corrected P/N Typo in BOM. Removed P/N and Update Figure Drawings. Engineering Update w/o Changes 2 0.339 [8.6mm] Ø.032+.003 -.002 L TYP. (3) Ø.255 [Ø6.5mm] (2) Spacer Dia. (1) 0.100 [2.5mm] TYP. 0.100 [2.5mm] TYP. Ø.197 [Ø5.0mm] LED Dia. 0.020 [0.5mm] SQ. Recommended Mounting Holes TYP. Fig. 1 Fig. 2 (2) Common Cathode (2) Common Anode (1) Anode (3) Anode (1) Cathode (3) Cathode Red Yellow Red Green Green Yellow Red Yellow Red Green Green Yellow ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED STANDARD SPACER PROFILE ASSY DATE: 03/05/04 DATE: 03/05/04 REVISION: PART NO: ELM3XXX5BCXX CAGE CODE : 32559 F SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. Peak Wavelength Emitted Color Lens Appearance LED Assembly No. Length λp (nm) ELM3XXX5BC-3 (FIG. 1) ELM3XXX5BC-3-YG (FIG. 1) ELM3XXX5BC3CA (FIG. 2) ELM3XXX5BCYGCA (FIG. 2) 635 568 585 568 635 568 585 568 HE RED GREEN YELLOW GREEN HE RED GREEN YELLOW GREEN WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED Abs. Electro-Optical Data Max. @ 20mA Viewing Angle Rating 2θ 1/2 LED P/N Vf lv If (Deg) (V) (mcd) (mA) TYP MAX TYP 30 2.0 2.6 35.0 40 5BC-3-F 30 2.2 2.6 35.0 30 2.1 2.6 30.0 40 5BC-3-Y/G-F 30 2.2 2.6 35.0 30 2.0 2.6 35.0 40 5BC-3-CA-F 30 2.2 2.6 35.0 30 2.1 2.6 30.0 40 5BC-3-Y/G-CA-F 30 2.2 2.6 35.0 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED STANDARD SPACER PROFILE ASSY DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 REVISION: PART NO: ELM3XXX5BCXX CAGE CODE : 32559 F SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM33005BC-3 价格&库存
很抱歉,暂时无法提供与“ELM33005BC-3”相匹配的价格&库存,您可以联系我们找货
