REV.
PART DESCRIPTION
ITEM
Q'TY
PART NUMBER
1
1
H-100C
T-1 (3mm) LED Holder, 90° Mount, Interlocking Center
2
1
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
1
DESCRIPTION
A Engineering Update w/o Changes
B LED Package Change to 3XX-S LEDs
C Engineering Update w/o Changes
2
DATE
APPROVED
03/05/04
12/14/07
06/20/16
M. C.
M. C.
J. C.
0.091 [2.3mm]
0.250 [6.4mm]
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
0.285 [7.2mm]
0.200 [5.1mm]
Cathode I.D.
Mark
0.100 [2.5mm]
0.157 [4.0mm]
0.020 [0.5mm] SQ. TYP.
0.185 [4.7mm]
0.185 [4.7mm]
Holder Faces
0.100 [2.5mm] LED Lead
Ø.032+.003
-.002 TYP.
0.172 [4.4mm] Holder Pitch
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
S. Irving
CHECKED:
A. Vilgiate
ANGULAR
X°
± 1°
DATE:
03/05/04
DATE:
03/05/04
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1 (3MM) INTERLOCKING
90° SINGLE-LEVEL LED ASSEMBLY
REVISION:
PART NO:
H100CXX
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
STANDARD
H100CBWD
H100CGD
H100CYD
H100CHD
H100CRD
H100CSRD
LOW CURRENT
H100CGDL
H100CYDL
H100CHDL
5 VOLT
H100CGD5V
H100CYD5V
H100CHD5V
Electro-Optical Data
Peak Wave
Length
λ p(nm )
Em itted Color
Lens
Appearance
430
565
585
635
655
660
BLUE
GREEN
YELLOW
HE RED
RED
SUPER RED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
View ing
Angle
If
Iv
Vf
2 ½
(m A)
(m cd) (Deg)
(V)
TYP TYP MAX TYP
Data @ 20m A
4.5
2.6
30
45
2.6
2.6
30
45
2.0
6
45
2.6
90
45
Data @ 2m A
2
1.9
2.2
6
45
2
1.9
2.2
4
45
2
1.8
2.2
6
45
Data @ 5V
10
5.0
30
45
10
5.0
10
5.0
30
45
LED P/N
3BWD-S
3GD-S
3YD-S
3HD-S
3RD-S
3SRD-S
3GDL-S
3YDL-S
3HDL-S
3GD5V-S
3YD5V-S
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
DESIGNED:
T. Yin
CHECKED:
D. Green
± 5°
DATE:
03/05/04
DATE:
03/05/04
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
REVISION:
PART NO:
H100CXX
CAGE CODE : 32559
C
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H100CSRD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.870671+0.88931
- 10+5.7270110+0.74128
- 100+4.57463100+0.59212
- 250+4.12066250+0.53336
- 500+3.89367500+0.50398
- 1000+3.544461000+0.45878
- 2000+3.203992000+0.41471
- 4000+2.977004000+0.38533
- 国内价格
- 1+6.37828
- 10+5.31703
- 100+4.24740
- 250+3.82577
- 500+3.61496
- 1000+3.29036
- 2000+2.97414
- 4000+2.76332
