REVISIONS
REV.
C
D
E
F
G
H
DESCRIPTION
Engineering Update w/o Changes
Updated S Dimension
Updated 14-NL Material to 94V-0
Added Notes 3, 4, 5 & Color Options Sheet #2
Updated Color Options Sheet #2
Changed Material to Halogen Free, ECO 1026
L1
W
DATE
APPROVED
02/13/04
11/26/07
09/11/12
05/16/16
07/06/18
10/17/19
M.
J. C.
C.
M. C.
T. Y.
J. C.
M. C.
A. V.
(1107X-XXX)
(1107X0-XXX)
L2
0.260 [6.6mm]
0.65 [16.6mm]
S (SLOT BASE)
(1107X-XXX)
0.435 [11.0mm]
0.59 [15.0mm]
(1107X0-XXX)
0.185 [4.7mm]
0.490 [12.4mm]
6 DEG MAX DRAFT
PART NO.
COLOR
S
W
L1
L2
PCB
THICKNESS
ROLL PIN
DESC
1107-062 XX
SEE S.#2
.075 (1.9mm) .290 (7.4mm) 2.0 (50.8mm)
.062 (1.6mm)
RP-250
83023-09
11073-062 NT
NATURAL
.075 (1.9mm) .350 (8.9mm) 2.0 (50.8mm)
.062 (1.6mm)
RP-312
11073-093 XX
SEE S.#2
.100 (2.5mm) .350 (8.9mm) 2.0 (50.8mm)
.093 (2.4mm)
RP-312
11073-125 NT
NATURAL
.140 (3.6mm) .350 (8.9mm) 2.0 (50.8mm)
.125 (3.2mm)
RP-312
83023-10
110710-062 XX
SEE S.#2
1.5 (38.1mm) .062 (1.6mm)
RP-250
83023-11
1107310-062 NT
NATURAL
RP-312
1107310-093 XX
SEE S.#2
1.5 (38.1mm) .093 (2.4mm)
RP-312
1107310-125 NT
NATURAL
1.5 (38.1mm) .125 (3.2mm)
RP-312
0.30 [7.6mm] MIN.
CHAMFER
0.24 [6.1mm]
0.25 [6.4mm]
0.18 [4.6mm]
0.51 [12.9mm]
MIN.
0.25 [6.4mm]
0.047 [1.2mm]
Recommended Application Layout
STANDARD TOLERANCE
(UNLESS OTHERWISE SPECIFIED)
DECIMALS
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
4. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST.
3. ROLL PINS INCLUDED. PACKAGED SEPARATELY.
2. MATERIAL: NYLON 6/6, 30% GLASS FILLED, HALOGEN FREE, 94V-0 NATURAL COLOR.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DESIGNED:
D. GREEN
REVISED:
TD. NGUYEN
CHECKED:
K. BARON
DATE:
10/17/19
DATE:
11/18/19
PCB INSERTER/EXTRACTOR
REVISION:
DRAWING NO:
1107XXX-XXX XX
04/16/03
DATE:
FAX: (949) 951-3974
SHEET
SIZE
SCALE:
A
NONE
H
CAGE CODE:
32559
SHEET # 1 OF
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
2
REVISIONS
OTHER AVAILABLE COLORS
REV.
* SEE TABLE FOR ORDERING INFORMATION
SERIES
1107-062
11073-093
110710-062
1107310-093
ORDER CODE
BK
BE
GN
NT
RD
WE
YW
DESCRIPTION
DATE
APPROVED
See Sheet 1
COLOR
BLACK
BLUE
GREEN
NATURAL
RED
WHITE
YELLOW
PANTONE CODE
PQ-BLUE072C
PQ-2258C
PQ-19-1664TCX
PQ-YELLOWC
PART NO:
REVISION:
1107XXX-XXX XX
SCALE:
H
SHEET # 2 OF 2
很抱歉,暂时无法提供与“11073-125 NT”相匹配的价格&库存,您可以联系我们找货
