REV.
0.312 [7.9mm]
DESCRIPTION
E Engineering Update w/o Changes
F Removed Part From Part Offering List
G Added Notes 4, 5, 6 & Color Options Sheet #2.
1.50 [38.1mm]
1.10 [27.8mm]
0.39 [9.9mm]
0.07 [1.7mm]
DATE
APPROVED
02/24/04
09/29/15
03/29/16
M. C.
J. C.
J. C.
0.71 [17.9mm]
0.25 [6.4mm]
0.14 [3.6mm]
CARD THICKNESS
Ø.093 [Ø2.4mm]
45° x 0.25 [6.4mm]
CHAMFER
0.30 [7.6mm]MIN.
0.25 [6.4mm]
0.25 [6.4mm]
0.50 [12.7mm]
0.25 [6.4mm]
PART NO.
CP-46 NT
CP-46 WE
CP-46 XX
CP-413 NT
CP-413 WE
CP-413 XX
COLOR
ROLL PIN CARD THICK.
NATURAL RP-312
RP-312 1/16" (1.6mm)
WHITE
RP-312
SEE S.#2
NATURAL RP-312
1/8" (3.2mm)
RP-312
WHITE
RP-312
SEE S.#2
Ø.109 [Ø2.8mm]
Recommended Application Layout
STANDARD TOLERANCE
5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST.
( UNLESS OTHERWISE SPECIFIED )
4. ROLL PINS INCLUDED. PACKAGED SEPARATELY.
.X
.XX
.XXX
3. MATERIAL: NYLON 6/6, 94V-2, WHITE.
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
± .1
± .01
± .005
DESIGNED:
S. Irving
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
CIRCUIT BOARD CARD EJECTOR
DATE:
05/29/98
DATE:
09/09/03
PART NO:
REVISION:
CP-4XX
CAGE CODE : 32559
G
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
OTHER AVAILABLE COLORS
* SEE TABLE FOR ORDERING INFORMATION
CP SERIES
ORDER CODE
COLOR
46
AA
AQUA
413
BK
BLACK
BE
BLUE
BN
GY
BROWN
FOREST
GREEN
GRAY
GN
GREEN
LE
LIME
OE
ORANGE
PK
PINK
RD
RED
VT
VIOLET
YW
YELLOW
FG
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
S. Irving
6. PARTS ARE DYED TO COLOR UPON REQUEST.
CHECKED:
M. Chen
DATE:
05/29/98
DATE:
09/09/03
PART NO:
REVISION:
CP-4XX
CAGE CODE : 32559
G
SHEET # 2 OF 2
很抱歉,暂时无法提供与“CP-46 RD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+9.58181100+1.23790
