PART NUMBER
REV.
ITEM
Q'TY
PART DESCRIPTION
1
1
H-130C-1-XXX
T-1 (3mm) LED Holder, 90° Mount, Interlocking Var. C/L
2
1
3XX-S
T-1 (3mm) Shouldered N-Flanged LED, See Page 2
1
B
C
D
E
DESCRIPTION
Engineering Update w/o Changes
LED Package Change to 3XX-S LEDs
Added H130CAD-XXX
DATE
APPROVED
03/05/04
10/26/07
02/29/08
06/20/16
M. C.
M. C.
M. C.
J. C.
2
0.084 [2.1mm]
0.240 [6.1mm]
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
L
EXAMPLE:
H130CRD-160*
C/L
Cathode I.D.
Mark
0.100 [2.5mm]
Centerline "C/L"
LED Color & Lens Appearance.
Omit 3 when ordering.
0.157 [4.0mm]
Series
* XXX = Centerline "C/L"
0.020 [0.5mm] SQ. TYP.
0.210 [5.3mm]
Holder Faces
0.100 [2.5mm] LED Lead
0.210 [5.3mm]
Ø.032+.003
-.002
TYP.
0.172 [4.4mm] Holder Pitch
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
Available Centerlines
XXX
C/L
L
120 .120 (3.0) .250 (6.4)
140 .140 (3.6) .270 (6.9)
160 .160 (4.1) .290 (7.4)
180 .180 (4.6) .310 (7.9)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
DATE:
06/11/03
DATE:
06/11/03
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1 (3MM) INTERLOCKING
90° SINGLE-LEVEL VAR. C/L LED ASSY
REVISION:
PART NO:
H130CXX-XXX
CAGE CODE : 32559
E
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED As s y. No.
STANDARD
H130CBWD-XXX
H130CGD-XXX
H130CYD-XXX
H130CHD-XXX
H130CRD-XXX
H130CSRD-XXX
H130CAD-XXX
LOW CURRENT
H130CGDL-XXX
H130CYDL-XXX
H130CHDL-XXX
5 VOLT
H130CGD5V-XXX
H130CYD5V-XXX
H130CHD5V-XXX
Ele ctro-Optical Data
Pe ak Wave
Le ngth
λ p(nm )
Em itte d Color
Le ns
Appe arance
430
565
585
635
655
660
610
BLUE
GREEN
YELLOW
HE RED
RED
SUPER RED
AMBER
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
Vie w ing
Angle
If
Iv
Vf
2 ½
(m A)
(m cd) (De g)
(V)
Typ. Typ. M ax. Typ.
Data @ 20m A
4.5
2.6
30
45
2.6
2.6
30
45
2.0
6
45
2.6
90
45
2.6
30
45
Data @ 2m A
2
1.9
2.2
6
45
2
1.9
2.2
4
45
2
1.8
2.2
6
45
Data @ 5V
10
5.0
30
45
10
5.0
10
5.0
30
45
LED P/N
3BWD-S
3GD-S
3YD-S
3HD-S
3RD-S
3SRD-S
3AD-S
3GDL-S
3YDL-S
3HDL-S
3GD5V-S
3YD5V-S
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
DESIGNED:
D. Green
CHECKED:
M. Chen
DATE:
06/11/03
DATE:
06/11/03
FAX: (949) 951-3974
TITLE:
REVISION:
PART NO:
H130CXX-XXX
CAGE CODE : 32559
E
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H130CGDL-120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.02167
- 10+5.68356
- 100+4.13241
- 500+3.27239
- 1000+3.11787
- 国内价格 香港价格
- 1+8.625441+1.11644
- 10+6.1111410+0.79100
- 100+4.44368100+0.57517
- 500+3.51827500+0.45539
- 1000+3.352401000+0.43392
