PART NUMBER
REV.
ITEM
Q'TY
PART DESCRIPTION
1
1
H-175C-2
T-1¾ (5mm) LED Holder, 90° Mount, Interlocking
2
1
5XX
T-1¾ (5mm) Non-Flange LED, See Page 2
1
A
B
C
D
2
DESCRIPTION
Engineering Update w/o Changes
Corrected LED Protrusion and Holder PN#
Updated LED Protrusion
DATE
APPROVED
03/05/04
01/18/07
08/05/09
06/20/16
M. C.
M. C.
T. Y.
J. C.
0.209 [5.3mm]
0.350 [8.9mm]
0.250 [6.4mm]
0.190 [4.8mm]
Ø.197 [Ø5.0mm]
0.240 [6.1mm]
0.120 [3.0mm]
0.157 [4.0mm]
0.100 [2.5mm]
0.020 [0.5mm] SQ. TYP.
0.200 [5.1mm]
Holder Faces
0.200 [5.1mm]
0.100 [2.5mm] LED Lead
Ø.032+.003
-.002
TYP.
0.254 [6.5mm] Holder Pitch
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
03/05/04
DATE:
03/05/04
T-1¾ (5MM) INTERLOCKING
90° SINGLE-LEVEL LED ASSY
REVISION:
PART NO:
H175CXX
CAGE CODE : 32559
D
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λ p(nm )
Electro-Optical Data
Em itted
Color
Lens
Appearance
MAX
TYP
If
(m A)
TYP
STANDARD
TYP
View ing
Angle
2 ½
(Deg)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 20m A
H175CBWD
430
BLUE
DIFFUSED
4.5
15
45
5BWD
H175CGD
568
GREEN
DIFFUSED
2.8
25
45
5GD
H175CPGD
555
PURE GREEN
DIFFUSED
2.8
10
45
5PGD
H175CYD
590
YELLOW
DIFFUSED
2.8
25
45
5YD
H175CHD
625
HE RED
DIFFUSED
2.8
25
45
5HD
H175CRD
700
RED
DIFFUSED
2.8
2
45
5RD
H175CSRD
645
SUPER RED
DIFFUSED
2.4
40
45
5SRD
LOW CURRENT
Data @ 2m A
H175CGDL
568
GREEN
DIFFUSED
2
2.1
2.6
5
45
5GDL
H175CYDL
590
YELLOW
DIFFUSED
2
2.0
2.6
4
45
5YDL
H175CHDL
625
HE RED
DIFFUSED
2
2.0
2.6
5
45
5HDL
5 VOLT
Data @ 5V
H175CGD5V
568
GREEN
DIFFUSED
10
5.0
25
45
5GD5V
H175CYD5V
590
YELLOW
DIFFUSED
10
5.0
5YD5V
H175CHD5V
625
HE RED
DIFFUSED
10
5.0
25
45
5HD5V
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
M. Chen
DATE:
03/05/04
DATE:
03/05/04
REVISION:
PART NO:
H175CXX
CAGE CODE : 32559
D
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H175CYDL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.137781+0.92660
- 10+5.9452510+0.77179
- 100+4.76143100+0.61811
- 250+4.28267250+0.55596
- 500+4.04765500+0.52545
- 1000+3.690761000+0.47912
- 2000+3.333872000+0.43279
- 4000+3.090144000+0.40115
- 国内价格
- 1+6.64539
- 10+5.53503
- 100+4.43306
- 250+3.98748
- 500+3.76828
- 1000+3.43649
- 2000+3.10350
- 4000+2.87712
