1209-062 YW
1209-062 YW
    BIVAR
    INSERTER/EXTRACT .062X1.55" YLW
1209-062 YW 数据手册
REV. D E F G H DATE APPROVED 05/01/08 05/14/09 09/05/12 09/29/15 05/16/16 M. C. T. Y. T. Y. J. C. J. C. DESCRIPTION Added Note 5 Pin Assembly Added /PA Diagram Added 1209-093 WE Removed Part From Part Offering List Added Note 4, 5, 6 & Color Options Sheet #2 1.55 [39.4mm] 0.370 [9.4mm] 0.187 [4.7mm] PIN ASSEMBLY DIAGRAM 0.370 [9.4mm] 0.650 [16.5mm] 5 0.192 [4.9mm] 0.150 [3.8mm] 1209-XXX XX/PA S 0.465 [11.8mm] Ø.125 [Ø3.2mm] 0.32 [8.1mm] MIN. 45° x 0.25 [6.4mm] CHAMFER PART NO. COLOR ROLL PIN 1209-062 NT NATURAL RP-375 1209-062 WE WHITE 1209-062 XX SEE S.#2 S PCB THICKNESS RP-375 .075"(1.9mm) .062"(1.6mm) RP-375 0.25 [6.4mm] 0.22 [5.6mm] 0.02 [0.5mm] 0.51 [12.9mm] MIN. Ø.140 [Ø3.6mm] 0.25 [6.4mm] 0.047 [1.2mm] Recommended Application Layout STANDARD TOLERANCE 5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST. ADD /PA SUFFIX ON P/N. INSERT PIN INTO Ø.125" HOLE. 4. ROLL PINS INCLUDED. PACKAGED SEPARATELY. 3. MATERIAL: NYLON 6/6, 94V-0, WHITE. 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: M. Chen CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PCB INSERTER/EXTRACTOR, CARD-O-PULL DATE: 02/24/03 DATE: 02/25/03 PART NO: REVISION: 1209-XXX XX CAGE CODE : 32559 H SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 OTHER AVAILABLE COLORS * SEE TABLE FOR ORDERING INFORMATION 1209-062 __ SERIES ORDER CODE AA BK BE BN FG GY GN LE OE PK RD VT YW COLOR AQUA BLACK BLUE BROWN FOREST GREEN GRAY GREEN LIME ORANGE PINK RED VIOLET YELLOW STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PCB INSERTER/EXTRACTOR, CARD-O-PULL DESIGNED: M. Chen 6. PARTS ARE DYED TO COLOR UPON REQUEST. CHECKED: D. Green DATE: 02/24/03 DATE: 02/25/03 PART NO: REVISION: 1209-XXX XX CAGE CODE : 32559 H SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
1209-062 YW 价格&库存
很抱歉,暂时无法提供与“1209-062 YW”相匹配的价格&库存,您可以联系我们找货
