REV.
C
D
E
F
DATE
APPROVED
02/24/04
02/24/09
05/10/11
05/16/16
M. C.
T. Y.
T. Y.
J. C.
DESCRIPTION
Engineering Update w/o Changes
Updated Model
Added Other Available Colors, 2nd Page
Added Notes 4, 5, 6 & Color Options Sheet #2
1.13 [28.6mm]
0.375 [9.5mm]
0.250 [6.4mm]
0.45 [11.3mm]
0.50 [12.7mm]
0.250 [6.4mm]
0.64 [16.3mm]
SLOT THICKNESS
0.25 [6.4mm]
0.14 [3.6mm]
2.6° MAX.
Ø.093 [Ø2.4mm]
0.30 [7.6mm]MIN.
45° x 0.25 [6.4mm]
CHAMFER
PART NO.
COLOR
ROLL PIN
CP-06 NT
CP-06 WE
CP-06 XX
CP-09 NT
CP-09 WE
CP-09 XX
NATURAL
WHITE
SEE S.#2
NATURAL
WHITE
SEE S.#2
RP-250
RP-250
RP-250
RP-250
RP-250
RP-250
SLOT THICK.
±.005
CARD
THICK.
0.25 [6.4mm]
0.24 [6.1mm]
0.071
1/16"(1.6mm)
0.093
3/32"(2.4mm)
0.50 [12.7mm]
0.25 [6.4mm]
Ø.109 [Ø2.8mm]
Recommended Application Layout
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST.
4. ROLL PINS INCLUDED. PACKAGED SEPARATELY.
3. MATERIAL: NYLON 6/6, 94V-2, WHITE.
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
S. Irving
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
CIRCUIT BOARD CARD EJECTOR
DATE:
09/15/98
DATE:
09/23/03
PART NO:
REVISION:
CP-0X
CAGE CODE : 32559
F
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
OTHER AVAILABLE COLORS
* SEE TABLE FOR ORDERING INFORMATION
CP- 0_
CP SERIES
CP-06
CP-09
ORDER CODE
COLOR
AQUA
AA
BK
BLACK
BLUE
BE
BN
BROWN
FG
FOREST GREEN
GY
GRAY
GN
GREEN
LE
LIME
OE
ORANGE
PK
PINK
RD
RED
VT
VIOLET
YW
YELLOW
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
S. Irving
6. PARTS ARE DYED TO COLOR UPON REQUEST.
CHECKED:
M. Chen
DATE:
09/15/98
DATE:
09/23/03
PART NO:
REVISION:
CP-0X
CAGE CODE : 32559
F
SHEET # 2 OF 2
很抱歉,暂时无法提供与“CP-06 YW”相匹配的价格&库存,您可以联系我们找货
