REV.
D
E
F
G
H
DATE
APPROVED
05/01/08
05/14/09
09/05/12
09/29/15
05/16/16
M. C.
T. Y.
T. Y.
J. C.
J. C.
DESCRIPTION
Added Note 5 Pin Assembly
Added /PA Diagram
Added 1209-093 WE
Removed Part From Part Offering List
Added Note 4, 5, 6 & Color Options Sheet #2
1.55 [39.4mm]
0.370 [9.4mm]
0.187 [4.7mm]
PIN ASSEMBLY DIAGRAM
0.370 [9.4mm]
0.650 [16.5mm]
5
0.192 [4.9mm]
0.150 [3.8mm]
1209-XXX XX/PA
S
0.465 [11.8mm]
Ø.125 [Ø3.2mm]
0.32 [8.1mm] MIN.
45° x 0.25 [6.4mm]
CHAMFER
PART NO.
COLOR
ROLL
PIN
1209-062 NT
NATURAL
RP-375
1209-062 WE
WHITE
1209-062 XX
SEE S.#2
S
PCB
THICKNESS
RP-375 .075"(1.9mm) .062"(1.6mm)
RP-375
0.25 [6.4mm]
0.22 [5.6mm]
0.02 [0.5mm]
0.51 [12.9mm]
MIN.
Ø.140 [Ø3.6mm]
0.25 [6.4mm]
0.047 [1.2mm]
Recommended Application Layout
STANDARD TOLERANCE
5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST. ADD /PA SUFFIX ON P/N.
INSERT PIN INTO Ø.125" HOLE.
4. ROLL PINS INCLUDED. PACKAGED SEPARATELY.
3. MATERIAL: NYLON 6/6, 94V-0, WHITE.
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
M. Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
PCB INSERTER/EXTRACTOR, CARD-O-PULL
DATE:
02/24/03
DATE:
02/25/03
PART NO:
REVISION:
1209-XXX XX
CAGE CODE : 32559
H
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
OTHER AVAILABLE COLORS
* SEE TABLE FOR ORDERING INFORMATION
1209-062 __
SERIES
ORDER CODE
AA
BK
BE
BN
FG
GY
GN
LE
OE
PK
RD
VT
YW
COLOR
AQUA
BLACK
BLUE
BROWN
FOREST GREEN
GRAY
GREEN
LIME
ORANGE
PINK
RED
VIOLET
YELLOW
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
M. Chen
6. PARTS ARE DYED TO COLOR UPON REQUEST.
CHECKED:
D. Green
DATE:
02/24/03
DATE:
02/25/03
PART NO:
REVISION:
1209-XXX XX
CAGE CODE : 32559
H
SHEET # 2 OF 2
很抱歉,暂时无法提供与“1209-062 GN”相匹配的价格&库存,您可以联系我们找货
