REV.
PART DESCRIPTION
ITEM
Q'TY
PART NUMBER
1
1
H-102C
T-1 (3mm) LED Holder, 90° Mount, Interlocking Left End
2
2
H-100C
T-1 (3mm) LED Holder, 90° Mount, Interlocking Center
3
1
H-103C
T-1 (3mm) LED Holder, 90° Mount, Interlocking Right End
4
4
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
1
2
3
DESCRIPTION
A Engineering Update w/o Changes
B LED Package Change to 3XX-S LEDs
C Engineering Update w/o Changes
DATE
APPROVED
03/05/04
12/14/07
06/20/16
M. C.
M. C.
J. C.
4
0.69 [17.5]
0.091 [2.3mm]
0.250 [6.4mm]
Ø.118 [Ø3.0mm]
TYP.
0.285 [7.2mm]
0.200 [5.1mm]
Cathode I.D.
Mark
0.100 [2.5mm]
0.157 [4.0mm]
TYP.
0.020 [0.5mm] SQ. TYP.
0.185 [4.7mm]
0.185 [4.7mm]
Holder Faces
0.100 [2.5mm] LED Lead TYP.
Ø.032+.003
-.002 TYP.
0.172 [4.4mm] Holder Pitch
TYP.
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: T-1 (3MM) 90° SINGLE LEVEL
QUAD-STATION ARRAY
DATE:
03/05/04
DATE:
03/05/04
PART NO:
REVISION:
H104CXX
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
STANDARD
H104CBWD
H104CGD
H104CYD
H104CHD
H104CRD
H104CSRD
LOW CURRENT
H104CGDL
H104CYDL
H104CHDL
5 VOLT
H104CGD5V
H104CYD5V
H104CHD5V
Electro-Optical Data
Peak Wave
Length
λ p(nm )
Em itted Color
Lens
Appearance
430
565
585
635
655
660
BLUE
GREEN
YELLOW
HE RED
RED
SUPER RED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
View ing
Angle
Vf
If
Iv
2 ½
(V)
(m A)
(m cd) (Deg)
TYP TYP MAX TYP
Data @ 20m A
4.5
2.6
30
45
2.6
2.6
30
45
2.0
6
45
2.6
90
45
Data @ 2m A
2
1.9
2.2
6
45
2
1.9
2.2
4
45
2
1.8
2.2
6
45
Data @ 5V
10
5.0
30
45
10
5.0
10
5.0
30
45
LED P/N
3BWD-S
3GD-S
3YD-S
3HD-S
3RD-S
3SRD-S
3GDL-S
3YDL-S
3HDL-S
3GD5V-S
3YD5V-S
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
QUAD-STATION ARRAY
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
PART NO:
REVISION:
H104CXX
CAGE CODE : 32559
C
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H104CHDL”相匹配的价格&库存,您可以联系我们找货
