FLP25-1.95
FLP25-1.95
    BIVAR
    2 mm Fiber Optic Core 7 mm Round Lens 10 inch Flexible Light Pipe Assembly
FLP25-1.95 数据手册
REVISIONS NOTES: 1. ALLOWABLE CUT LENGTH IS UP TO 3 DECIMAL PLACES. REV. A B C DESCRIPTION ENGINEERING RELEASE UPDATED FIBER IN BOM ECO-1219 - UPDATED LENS DIMENSIONS DATE APPROVED 9/14/2009 T.Y. T.Y. A.V. 11/16/2012 8/22/2023 L .21IN 5.3mm HOLDER CAP BODY .063IN 1.6mm FLEXIBLE LIGHT PIPE .273IN 6.9mm .070IN 1.8mm HOLDER CAP INSERT .57IN 14.5mm .253IN±.005 6.4MM±0.1 LENGTH (L) 0.750" ~ 16.000" 16.001" ~ 40.000" 40.001" ~ 80.000" 80.001" ~ 3,940.0" TOLERANCE ±0.050" ±0.150" ±0.300" ±0.500" CUSTOMER USE DRAWING DECIMALS RECOMMENDED MOUNTING HOLE (PANEL THICKNESS = 0.100")  STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: B. OLIVER REVISED: K. BARON CHECKED: A. VALDEZ ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 9/14/2009 DATE: 9/13/2023 DATE: 9/13/2023 LENS CAP/FLP ASSEMBLY 7MM ROUND REVISION: DRAWING NO: FLP25-XX.X C CAGE CODE: SHEET SIZE 32559 A SCALE: 2:1 SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FLP25-1.95 价格&库存
很抱歉,暂时无法提供与“FLP25-1.95”相匹配的价格&库存,您可以联系我们找货
