H921VR7BC
H921VR7BC
    BIVAR
H921VR7BC 数据手册
ITEM Q'TY 1 1 922-343 Multi-Functional Single LED Holder 2 1 R7XX 2x7mm Rectangular LED, See Page 2 PART NUMBER REV. PART DESCRIPTION B C D 1 2 0.295 [7.5mm] 0.091 [2.3mm] DESCRIPTION Engineering Update w/o Changes Added R7BC-XX LEDs Engineering Update w/o Changes DATE APPROVED 03/08/04 09/28/06 07/30/16 M. C. M. C. J. C. 0.400 [10.2mm] 0.207 [5.3mm] 0.268 [6.8mm] 0.295 [7.5mm] 0.148 [3.7mm] 0.157 [4.0mm] 0.020 [0.5mm] 0.100 [2.5mm] SQ. TYP. 2 1 Holder Face 0.185 [4.7mm] 0.100 [2.5mm] LED Lead Ø.032+.003 TYP. -.002 Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) 2 1 Single Color Bi-Color 1 2 BI-COLOR POLARITY LED P/N (1) CATHODE (2) CATHODE RED R7BC GREEN R7BC-Y/G GREEN YELLOW R7BC-R/Y YELLOW RED STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 10/10/03 DATE: 10/10/03 RECTANGULAR 2X7MM VERT. 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H921VR7XX CAGE CODE : 32559 D SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. H921VR7GD H921VR7YD H921VR7RD H921VR7BC H921VR7BC-Y/G H921VR7BC-R/Y Peak Wave Length λ p(nm ) Em itted Color 565 585 655 635 568 585 568 640 585 GREEN YELLOW RED RED GREEN YELLOW GREEN RED YELLOW Lens Appearance DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED Abs. Max. Rating If (m A) 30 30 40 30 30 30 30 30 30 Electro-Optical Data @ 20m A View ing Angle Vf 2 ½ Iv (V) (Deg) (m cd) TYP MAX TYP 2.2 2.6 7 125 2.1 2.6 5 125 1.7 2.0 1 125 2.0 2.6 6 120 2.2 2.6 6 2.1 2.6 5 120 2.2 2.6 6 2.0 2.6 6 120 2.1 2.6 6 LED P/N R7GD R7YD R7RD R7BC R7BC-Y/G R7BC-R/Y STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: D. Green CHECKED: M. Chen DATE: 10/10/03 DATE: 10/10/03 FAX: (949) 951-3974 TITLE: RECTANGULAR 2X7MM VERT. 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H921VR7XX CAGE CODE : 32559 D SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H921VR7BC 价格&库存
很抱歉,暂时无法提供与“H921VR7BC”相匹配的价格&库存,您可以联系我们找货
H921VR7BC
  • 1+11.261961+1.45770
  • 10+9.4286210+1.22040
  • 100+7.51671100+0.97293
  • 250+6.76591250+0.87575
  • 500+6.39051500+0.82716
  • 1000+5.831781000+0.75484
  • 2000+5.264312000+0.68139
  • 4000+4.888924000+0.63280
H921VR7BC
  • 1+10.45560
  • 10+8.75352
  • 100+6.97838
  • 250+6.28126
  • 500+5.93270
  • 1000+5.41406
  • 2000+4.88702
  • 4000+4.53846
