CP-39 RD
CP-39 RD
    BIVAR
    CP Series Red nylon Circuit Board Card Ejector Card-O-Pull
CP-39 RD 数据手册
REV. F G H DATE APPROVED 02/24/04 06/13/13 05/04/16 M. C. T. Y. J. C. DESCRIPTION Production Release. Added Max. Allowable Draft Angle. Added Notes 4, 5, 6 & Color Options Sheet #2 1.10 [27.9mm] 0.250 [6.4mm] 0.37 [9.4mm] 0.08 [1.9mm] CARD THICKNESS 0.52 [13.2mm] 0.26 [6.5mm] 0.14 [3.6mm] 3° MAX. Ø.093 [Ø2.4mm] PART NO. COLOR ROLL PIN CP-36 NT CP-36 WE CP-36 XX CP-39 NT CP-39 WE CP-39 XX NATURAL WHITE SEE S.#2 NATURAL WHITE SEE S.#2 RP-250 RP-250 RP-250 RP-250 RP-250 RP-250 CARD THICK. 1/16"(1.6mm) 0.30 [7.6mm]MIN. 45° x 0.25 [6.4mm] CHAMFER 0.25 [6.4mm] 0.25 [6.4mm] 3/32"(2.4mm) 0.50 [12.7mm] 0.25 [6.4mm] Ø.109 [Ø2.8mm] Recommended Application Layout STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) 5. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST. 4. ROLL PINS INCLUDED. PACKAGED SEPARATELY. 3. MATERIAL: NYLON 6/6, 94V-2, WHITE. 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: S. Irving CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: CIRCUIT BOARD CARD EJECTOR DATE: 05/19/98 DATE: 09/09/03 PART NO: REVISION: CP-3X CAGE CODE : 32559 H SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 OTHER AVAILABLE COLORS * SEE TABLE FOR ORDERING INFORMATION CP- 3 _ CP SERIES CP-36 CP-39 __ ORDER CODE AA BK BE BN FG GY GN LE OE PK RD VT YW COLOR AQUA BLACK BLUE BROWN FOREST GREEN GRAY GREEN LIME ORANGE PINK RED VIOLET YELLOW STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: CIRCUIT BOARD CARD EJECTOR DESIGNED: S. Irving 6. PARTS ARE DYED TO COLOR UPON REQUEST. CHECKED: M. Chen DATE: 05/19/98 DATE: 09/09/03 PART NO: REVISION: CP-3X CAGE CODE : 32559 H SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
CP-39 RD 价格&库存
很抱歉,暂时无法提供与“CP-39 RD”相匹配的价格&库存,您可以联系我们找货
