2790
2790
    HEYCO
2790 数据手册
“Stay Connected with Heyco” Bushings, Grommets, HEYCaps and Plugs Heyco Dome Plugs ® Mounting Hole Diameter Range: .187˝ (4,7 mm) to 6.000˝ (152,4 mm) • Close unneeded panel holes and electrical knockouts. • Quick and easy installation. • Convex, matte finish head tapers to thin edge (Except DP-187). • Multiple sizes for use in .187˝ (4,7 mm) to 6.000˝ (152,4 mm) diameter holes. • Lock firmly into panel up to .250˝ (6,4 mm) thick. • Locking fingers in fractional increments up to the maximum panel thickness. • Approximate Head Thickness: .062˝ (1,6 mm). Thickness may vary. • For Snap-In Metric Dome Plugs see page 6-28. MOUNTING HOLE DIAMETER in. mm. PART NO. Black White DESCRIPTION Colors xx** PART DIMENSIONS A B Head Diameter Overall Height in. mm. in. mm. Single Locking Step for Panel Thickness up to .062˝ (1,6 mm) .187 4,7 2590 2591 2592xx 6,4 6,4 2607 2603 2608 2604 2609xx 2605xx DP 250-040! DP 250 .25 .250 .31 7,9 .312 7,9 2613 2614 2615xx DP 312 .38 9,5 DP 187* .23 5,9 .31 7,9 .41 10,3 Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) .375 .437 .500 .562 .625 .687 .750 .812 9,5 11,1 12,7 14,3 15,9 17,4 19,1 20,6 2617 2633 2643 2653 2663 2673 2683 2693 2618 2634 2644 2654 2664 2674 2684 2694 2619xx 2635xx 2645xx 2655xx 2665xx 2675xx 2685xx 2695xx DP 375 DP 437 DP 500 DP 562 DP 625 DP 687 DP 750 DP 812 .47 .53 .56 .66 .72 .78 .92 .99 11,9 13,5 14,2 16,7 18,2 19,8 23,4 25,1 .875 1.000 22,2 25,4 2703 2713 2704 2714 2705xx 2715xx DP 875 DP 1000 1.02 1.20 25,8 30,6 1.093 1.125 27,8 28,6 2723 2724 2725xx DP 1093 1.22 30,9 1.187 1.250 1.375 1.500 1.750 30,1 31,7 34,9 38,1 44,5 2733 2740 2753 2763 2773 2734 2741 2754 2764 2774 2735xx 2742xx 2755xx 2765xx 2775xx DP 1187 DP 1250 DP 1375 DP 1500 DP 1750 1.33 1.38 1.50 1.67 1.92 33,8 34,9 38,1 42,4 48,7 .45 11,5 2.000 50,8 2783 2784 2785xx DP 2000 2.17 55,1 .47 11,9 Multiple Locking Steps for Panel Thickness up to .250˝ (6,4 mm) A 6-23 B Quick Specs 2.093 2.125 53,2 54,0 2403 2404 *** DP 2.093 2.34 59,9 .75 19,1 2.250 2.500 57,2 63,5 2411 2790 2412 2791 2413xx 2792xx DP 2.25 DP 2.5 2.48 2.71 63,0 68,8 .75 19,1 3.000 76,2 2455 2456 2457xx DP 3.0 3.16 80,3 .74 18,8 3.375 3.500 85,7 88,9 2482 2464 2483 2465 *** 2466xx DP 3.375 DP 3.5 3.66 3.66 92,9 92,9 .75 19,1 4.000 101,6 2473 2474 2475xx DP 4.0 4.17 105,8 .71 18,0 5.000 127,0 2451 2452 *** DP 5.0 5.24 133,0 .75 19,1 6.000 152,4 2453 2454 *** DP 6.0 6.22 157,9 .78 Standard colors black and white. Consult Heyco for other colors (see below) *Convex, glossy finish head. ** xx indicates that, following the color match process, Heyco adds a two letter suffix to the Root Part No. shown. This suffix will identify your particular CUSTOM Color selection. Consult Heyco for molded nylon color chips for accurate matching. For details as well as information regarding our Stock Colors, see page 6-51. ***Consult Heyco for root Part No. ! Max panel thickness is .040˝ (1,0 mm) 19,8 Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E51579 Certified by the Canadian Standards Association File 8919 94V-2 -40°F (-40°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“2790”相匹配的价格&库存,您可以联系我们找货
