F8404
F8404
    HEYCO
    F8404
F8404 数据手册
“Stay Connected” with Liquid Tight Conduit, Tubing & Fittings ® Heyco Nylon Corrugated Conduit/Tubing – HPAS Series ® Highly Flexible Polyamide Nylon 6 Type HPAS • • • • • • • • • • • • • • • • Low fire hazard. Low smoke and toxicity. Halogen, sulphur, and phosphorus free. Highly flexible and high fatigue life. High impact strength and recovers if crushed. Lightweight and low installed cost. Use with Heyco Nylon Fittings. See pages 2-5 through 2-6. UV resistant. For use with all types of equipment, machinery, pumps, motors, and HVAC equipment. 10 mm thru 54 mm nominal sizes. Highly resistant to abrasion, oil, and solvents. Voltage Rating: 300V. Suitable for use in outdoor locations. See Page 2-4 for mounting clips. Maximum flexibility, can be used in extremely tight quarters. Bend radius of HPAS Series is equal to its outside diameter. See Pages 2-21 for technical specifications. NOMINAL SIZE PART NO. Black 94V-2 94V-0 DESCRIPTION PART DIMENSIONS A B Inside Outside Diameter Diameter in. mm. in. mm. Inside Bend Radius mm. in. 10 mm F8400 F8421 HPAS 10MM 50M COIL .59 15,0 .24 6,2 .39 10,0 13 mm F8402 F8422 HPAS 13MM 50M COIL .79 20,0 .38 9,6 .51 13,0 16 mm F8404 F8424 HPAS 16MM 50M COIL 1.18 30,0 .47 12,0 .62 15,8 21 mm F8406 F8426 HPAS 21MM 50M COIL 1.57 40,0 .65 16,5 .84 21,2 28 mm F8410 F8432 HPAS 28MM 50M COIL 2.17 55,0 .88 22,3 1.12 28,5 34 mm F8414 F8434 HPAS 34MM 50M COIL 2.56 65,0 1.11 28,2 1.36 34,5 42 mm F8416 F8436 HPAS 42MM 25M COIL 3.15 80,0 1.42 36,0 1.67 42,5 54 mm F8418 F8438 HPAS 54MM 25M COIL 3.74 95,0 1.85 47,1 2.15 54,5 2-3 164 50 82 25 Standard color black. A LOW FIRE HAZARD Quick Specs Roll Length Ft. M. Material Certifications Flammability Rating Nylon 6 (PA6) Recognized under Underwriters’ Laboratories File E121095 for both U.S. and Canadian requirements 94V-2 and 94V-0 Halogen Free Temperature Range -4°F (-20°C) to 221°F (105°C) IP Rating IP 66 with HPASC Fittings Per EN60529 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com B
F8404 价格&库存
很抱歉,暂时无法提供与“F8404”相匹配的价格&库存,您可以联系我们找货
