10346
10346
    HEYCO
10346 数据手册
“Stay Connected” with HEYware Products ® ® Heyco Nylon PCB Supports - Imperial Spacing FLANGED TWO PRONG SNAP FIT / FLANGED TWO PRONG SNAP LOCK FLAT TOP REST MOUNT / ARROWHEAD LOCK FLAT TOP REST MOUNT / TEARDROP SNAP LOCK TEARDROP SNAP LOCK / TEARDROP SNAP LOCK HMPS HPS-TD HSP-MDL-3 HMSPS Maximum Thickness in. mm. Mounting Hole Diameter in. mm. PCB .062 1,6 .157 4,0 Chassis .062 1,6 .157 4,0 A in. mm. .063 1,6 .125 3,2 PART NO. Natural DESCRIPTION Maximum Thickness in. mm. Mounting Hole Diameter in. mm. Maximum Thickness in. mm. flat top rest mount .078 2,0 .125 Mounting Hole Diameter in. mm. flat top rest mount 3,2 .062 1,6 .098 2,5 DESCRIPTION Maximum Thickness in. mm. Mounting Hole Diameter in. mm. .062 1,6 .098 2,5 .039 1,0 .078 2,0 PART NO. Natural DESCRIPTION PART NO. Natural PART NO. Natural DESCRIPTION 10341 HPS-TD-01 10352 HSP-MDL-3-01 10331 HMPS-02 10342 HPS-TD-02 10353 HSP-MDL-3-02 .187 4,8 10320 HMSPS-03 10332 HMPS-03 10343 HPS-TD-03 10354 HSP-MDL-3-03 .250 6,4 10321 HMSPS-04 10333 HMPS-04 10344 HPS-TD-04 10355 HSP-MDL-3-04 .312 7,9 10322 HMSPS-05 10334 HMPS-05 10345 HPS-TD-05 10356 HSP-MDL-3-05 .375 9,5 10323 HMSPS-06 10335 HMPS-06 10346 HPS-TD-06 10357 HSP-MDL-3-06 .437 11,1 10324 HMSPS-07 10336 HMPS-07 10347 HPS-TD-07 10325 HMSPS-08 .500 12,7 .562 14,3 .625 15,9 10326 HMSPS-10 .689 17,5 10327 HMSPS-11 .750 19,1 10328 HMSPS-12 .875 22,2 10329 HMSPS-14 10337 HMPS-08 10348 HPS-TD-08 10338 HMPS-09 10349 HPS-TD-09 10339 HMPS-10 10350 HPS-TD-10 Standard color natural. For special order parts in UL 94V-0 natural material, add the suffix “F” to Part No. Material Flammability Rating Temperature Range Nylon 6/6 94V-2 -40°F (-40°C) to 185°F (85°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 7-11
10346 价格&库存
很抱歉,暂时无法提供与“10346”相匹配的价格&库存,您可以联系我们找货
