1681
1681
    HEYCO
1681 数据手册
“Stay Connected with Heyco” HEYCaps & Nylon Finishing Plugs Heyco Shorty Plugs ® Single Locking Step for Panel Thickness up to: .062˝ (1,6 mm) Mounting Hole Diameter Range: .218˝ (5,5 mm) to 1.093˝ (27,8 mm) • Limited intrusion .125˝ (3,2 mm) inside the panel. • Quick and easy installation. • Multiple sizes for mounting holes from .218˝ (5,5 mm) to 1.093˝ (27,8 mm). • Approximate Head Thickness: .062˝ (1,6 mm). • For Shorty Window Plugs see page 6-18. MOUNTING HOLE DIAMETER in. mm. PART NO. DESCRIPTION Black White Colors xx** PART DIMENSIONS A B Head Diameter Overall Height in. mm. in. mm. .218 5,5 1654 1655 1656xx SP 218 .281 7,1 .281 7,1 1660 1661 1662xx SP 281 .343 8,7 .312 7,9 1678 1679 1680xx SP 312 .375 9,5 .343 8,7 1663 1664 1665xx SP 343 .406 10,3 .375 9,5 1681 1682 1683xx SP 375 .468 .406 10,3 1666 1667 1668xx SP 406 .437 11,1 1684 1685 1686xx SP 437 .468 11,9 1669 1670 1671xx SP 468 .500 12,7 1687 1688 1689xx .531 13,5 1672 1673 1674xx .593 15,1 1675 1676 .625 15,9 1690 .750 19,0 .781 .250 6,4 11,9 .250 6,4 .531 13,5 .250 6,4 SP 500 .563 14,3 SP 531 .593 15,1 1677xx SP 593 .687 17,5 1691 1692xx SP 625 .718 18,3 1693 1694 1695xx SP 750 .843 21,4 .250 6,4 19,8 1696 1697 1698xx SP 781 .890 22,6 .875 22,2 1699 1700 1701xx SP 875 .968 24,6 1.000 25,4 1702 1703 1704xx SP 1000 1.200 30,5 1.093 27,8 1705 1706 1707xx SP 1093 1.219 31,0 Standard colors black or white. Consult Heyco for other colors (see below). ** xx indicates that, following the color match process, Heyco adds a two letter suffix to the Root Part No. shown. This suffix will identify your particular CUSTOM Color selection. Consult Heyco for molded nylon color chips for accurate matching. For details as well as information regarding our Stock Colors, see page 6-42. A Quick Specs 6-3 Material Certifications Flammability Rating Temperature Rating B Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E51579 Certified by the Canadian Standards Association File 8919 94V-2 -40°F (-40°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“1681”相匹配的价格&库存,您可以联系我们找货
  • 1+1.003041+0.13035
  • 5+0.862195+0.11205
  • 10+0.8013610+0.10414
  • 25+0.7290225+0.09474
  • 50+0.6831350+0.08878
  • 100+0.63896100+0.08304
  • 250+0.58411250+0.07591
  • 500+0.54606500+0.07097
  • 1000+0.510491000+0.06634
库存:16264
