2460
2460
    HEYCO
2460 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Universal Bushings ® Mounting Hole Diameter Range: .500˝ (12,7 mm) to 3.000˝ (76,2 mm) • Flexible shutters adjust to accommodate and support any shape from .125˝ (3,2 mm) to a maximum cable/bundle diameter of 2.470˝ (62,7 mm). • Absorb vibration and cushion and insulate cables, tubing, hoses or shafts. • Locking fingers in fractional increments up to the maximum panel thickness. • Fingertip pressure snap-locks the bushing into its mounting hole. MOUNTING HOLE DIAMETER in. PART NO. Black DESCRIPTION White Maximum Cable/ Bundle Diameter in. mm. mm. PART DIMENSIONS A Head Diameter in. mm. B Overall Height in. mm. Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) .500 12,7 2055 2056 UB 500 .31 7,6 .60 15,2 .39 9,8 .625 15,9 2077 2076 UB 625 .44 11,1 .73 18,5 .41 10,3 .750 .812 19,1 20,6 2089 2106 2085 2107 UB 750 UB 812 .50 .50 12,7 12,7 .84 .89 21,4 22,6 .39 9,9 .875 22,2 UB 875 UB 875-112* UB 1000 UB 1093 UB 1187 UB 1250 14,3 .94 23,8 .45 11,5 25,4 27,8 30,2 31,8 2129 – 2138 2162 2154 2156 .56 1.000 1.093 1.187 1.250 2119 2118 2137 2157 2153 2155 .75 .81 .95 1.02 19,1 20,6 24,1 25,8 1.06 1.16 1.25 1.31 27,0 29,5 31,8 33,4 .44 11,2 2185 – UB 1375 UB 1375-1750 1.00 1.00 25,4 25,4 1.49 1.75 37,8 44,5 11,5 34,9 2184 2187 .45 1.375 .47 .49 11,8 12,4 .75 19,05 1.500 38,1 2213 2214 UB 1500 1.06 26,9 1.61 40,9 1.750 2.000 44,5 50,8 2298 2422 2299 2423 UB 1750 UB 2000 1.38 1.64 34,9 41,6 1.87 2.13 47,5 54,0 Multiple Locking Steps for Panel Thickness up to .250˝ (6,4 mm) 2.500 63,5 2440 2441 UB 2.500 1.97 50,0 2.63 66,8 3.000 76,2 2460 2463 UB 3.000 2.47 62,7 3.15 80,0 Standard colors black and white. Consult Heyco for other colors. *UB 875-112 inside diameter adjusts for 1/8˝ to 5/8˝ cables; UB 875 adjusts for 3/16˝ to 9/16˝ cables. B A Quick Specs 6-11 Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories, File E15331 Certified by Canadian Standards Association, File 8919 94V-2 -.4°F (-18°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“2460”相匹配的价格&库存,您可以联系我们找货
