10616
10616
    HEYCO
10616 数据手册
“Stay Connected” with HEYware Products ® ® Heyco Nylon PCB Supports - Screw and Lock ALL NEW PRODUCTS! BAYONET SNAP LOCK 10,2 / 6-32 SELF-TAPPING SCREW BAYONET SNAP LOCK 10,2 / M4 THREADED FEMALE BAYONET SNAP LOCK 10,2 / 6-32 THREADED FEMALE BAYONET SNAP FIT 10,2 / 6-32 THREADED FEMALE HLCBS-TF-M4 HLCBS-TF-632 HCBS-TF-632 HHCBS Maximum Thickness* in. mm. Mounting Hole Diameter in. mm. Maximum Thickness in. mm. PCB .062 1,6 .157 Chassis .312 7,9 6-32 threaded PART NO. Natural DESCRIPTION PART NO. Natural** HHCBS-04 † A in. mm. 4,0 .062 1,6 Mounting Hole Diameter in. mm. .157 4,0 M4 DESCRIPTION Maximum Thickness in. mm. .062 1,6 Mounting Hole Diameter in. mm. .157 4,0 Maximum Thickness in. mm. .062 1,6 Mounting Hole Diameter in. mm. .157 4,0 threaded 6-32 threaded 6-32 PART NO. Natural** DESCRIPTION PART NO. Natural** DESCRIPTION .250 6,4 10616 .375 9,5 10617 HHCBS-06 10829 HLCBS-TF-M4-06 10890 HLCBS-TF-632-06 10897 HCBS-TF-632-06 .500 12,7 10618 HHCBS-08 10830 HLCBS-TF-M4-08 10891 HLCBS-TF-632-08 10898 HCBS-TF-632-08 .625 15,9 10619 HHCBS-10 10831 HLCBS-TF-M4-10 10892 HLCBS-TF-632-10 10899 HCBS-TF-632-10 .750 19,1 10620 HHCBS-12 10832 HLCBS-TF-M4-12 10893 HLCBS-TF-632-12 10900 HCBS-TF-632-12 .875 22,2 10621 HHCBS-14 10833 HLCBS-TF-M4-14 10894 HLCBS-TF-632-14 10901 HCBS-TF-632-14 1.000 25,4 10622 HHCBS-16 10834 HLCBS-TF-M4-16 10895 HLCBS-TF-632-16 10902 HCBS-TF-632-16 1.125 28,6 10623 HHCBS-18 1.250 31,8 10624 HHCBS-20 1.406 35,7 10625 HHCBS-22.5 Standard color natural. For special order parts in UL 94V-0 natural material, add the suffix “F” to Part No. *Refers to thread depth at chassis which is .312˝ (7,9 mm) **Consult Heyco for HLCBS-TF in V-0 material †Thread depth is .20˝ (5,2 mm) Quick Specs 7-22 Material Flammability Rating Temperature Range Nylon 6/6 94V-2 -40°F (-40°C) to 185°F (85°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
10616 价格&库存
很抱歉,暂时无法提供与“10616”相匹配的价格&库存,您可以联系我们找货
