9395
9395
    HEYCO
9395 数据手册
“Stay Connected” with Power Components ® Heyco Wire Protector Terminal Blocks ® Screw to Screw–With Wire Protector Flap • Wire protector flap allows the WIRE SIZE AMPS POLES PART NO. DESCRIPTION AWG mm2 North FR Screws use of STRANDED or SOLID America Natural White (Metric) wire with no crimp terminals and no soldering required. 300 Volts Rated (450 Volts in Europe) • Allows standardization of the 2 9389 9419 TB OB-WP-2P SOLID WIRE Cordset. Input 12-22 2,5 20 M 2,5 12 9393 N/A TB 0B-WP-12P and output wires are always 2 9394 N/A TB 1B-WP-2P secured with a screw. 3 9395 N/A TB 1B-WP-3P • Modern low profile design 10-20 4 30 M 2,6 4 N/A 9426 TB 1B-WP-4P occupies less real estate. 12 9398 9428 TB 1B-WP-12P • No exposed metal parts. 3 9400 N/A TB 2B-WP-3P “Dead front” designed safety. 8-14 6 50 4 9406 N/A TB 2B-WP-4P M 3,5 • Pressure clamp connectors are 12 9403 9433 TB 2B-WP-12P supplied in the open position, Standard color natural. Flame retardant white available at extra charge. ready to accept single or multiple solid conductors. • All sizes are rated at 300 volts (450 volts in Europe). • Metal parts feature galvanized steel screws and Ni or tin plated brass inserts. • Available in 94V-0 flame retardant (FR), 6/6 Nylon material. • Part No. 9299 fixing pin (below) can be used to mount all terminal WIRE PROTECTOR FLAP blocks, with panel thickness limitations–consult Heyco. • DFARS Compliant LOW PROFILE C STYLE A in. B mm. PART DIMENSIONS C D E F in. mm. in. mm. in. mm. in. mm. in. mm. 0.55 14,1 - - .70 17,8 .61 15,5 .12 3,0 3.78 96,0 .12 3,0 .32 8,2 0.66 16,7 .14 3,5 - - 1.05 26,7 .14 3,5 .79 20,0 .66 16,8 .14 3,5 .39 10,0 1.44 36,6 4.59 116,7 1.21 30,8 1.67 42,3 .92 23,4 .75 19,0 .17 4,3 .45 11,5 .15 3,7 5.29 134,3 A F E B D Quick Specs 8-3 Materials Certifications V D E Flammability Rating Temperature Range 6/6 Nylon and brass Recognized under Component Program of Underwriters’ Laboratories to both Canadian and US requirements File E197025 Approved 94V-2 -40°F (-40°C) to 284°F (140°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“9395”相匹配的价格&库存,您可以联系我们找货
