10043
10043
    HEYCO
10043 数据手册
“Stay Connected” with HEYware Products ® ® Heyco Nylon PCB Supports - Imperial Spacing TWO PRONG SNAP LOCK / TWO PRONG SNAP LOCK TWO PRONG SNAP LOCK / TWO PRONG SNAP LOCK TWO PRONG SNAP LOCK / TWO PRONG SNAP LOCK TEARDROP SNAP LOCK / TEARDROP SNAP LOCK HSP2 HSP3 HDLSPTH HSP1 Maximum Thickness in. mm. Mounting Hole Diameter in. mm. Maximum Thickness in. mm. Mounting Hole Diameter in. mm. Maximum Thickness in. mm. Mounting Hole Diameter in. mm. Maximum Thickness in. mm. Mounting Hole Diameter in. mm. PCB .062 1,6 .157 4,0 .062 1,6 .187 4,8 .062 1,6 .157 4,0 .062 1,6 .098 2,5 Chassis .062 1,6 .157 4,0 .062 1,6 .187 4,8 .062 1,6 .187 4,8 .062 1,6 .098 2,5 A PART NO. Natural DESCRIPTION PART NO. Natural DESCRIPTION PART NO. Natural PART NO. Natural DESCRIPTION 1,6 10036 HDLSPTH-01 3,2 10037 HDLSPTH-02 HSP3-03 10038 HDLSPTH-03 10025 HSP3-04 10039 HDLSPTH-04 HSP2-05 10026 HSP3-05 10040 HDLSPTH-05 10015 HSP2-06 10027 HSP3-06 10041 HDLSPTH-06 10016 HSP2-07 10028 HSP3-07 10042 HDLSPTH-07 in. mm. .063 .125 .187 4,8 10000 HSP1-03 10012 HSP2-03 10024 .250 6,4 10001 HSP1-04 10013 HSP2-04 .312 7,9 10002 HSP1-05 10014 .375 9,5 10003 HSP1-06 .437 11,1 10004 HSP1-07 DESCRIPTION .500 12,7 10005 HSP1-08 10017 HSP2-08 10029 HSP3-08 10043 HDLSPTH-08 .562 14,3 10006 HSP1-09 10018 HSP2-09 10030 HSP3-09 10044 HDLSPTH-09 10045 HDLSPTH-10 10046 HDLSPTH-14 .625 15,9 10007 HSP1-10 10019 HSP2-10 10031 HSP3-10 .750 19,1 10008 HSP1-12 10020 HSP2-12 10032 HSP3-12 .875 22,2 10009 HSP1-14 10021 HSP2-14 10033 HSP3-14 1.000 25,4 10010 HSP1-16 10022 HSP2-16 10034 HSP3-16 Standard color natural. For special order parts in UL 94V-0 natural material, add the suffix “F” to Part No. Quick Specs 7-4 Material Flammability Rating Temperature Range Nylon 6/6 94V-2 -40°F (-40°C) to 185°F (85°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
10043 价格&库存
很抱歉,暂时无法提供与“10043”相匹配的价格&库存,您可以联系我们找货
      • 1000+1.440521000+0.18720
