2119
2119
    HEYCO
2119 数据手册
9940Heyco4:Sec 3 4/16/08 8:27 AM Page 8 Heyco Products, Inc. “The First Name in Wire Protection” EXPANDED PRODUCT RANGE Heyco® Universal Bushings • Flexible shutters adjust to accommodate and support any shape from .125˝ (3,2 mm) to a maximum diameter of 1.500˝ (38,1 mm). • Absorbs vibration and cushions and insulates cables, tubing, hoses or shafts with limited internal clearance. • Fingertip pressure snap-locks the bushing into its mounting hole. • See Quick Specs on 4-8. B A PANEL DIMENSIONS Maximum Mounting Hole Thickness Diameter in. .125 .125 .125 .125 .125 .125 .125 .125 NEW! .125 .125 .125 .125 .125 NEW! .250 .250 mm. 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 3,2 6,35 6,35 in. .500 .625 .750 .812 .875 1.000 1.093 1.187 1.250 1.375 1.500 1.750 2.000 2.500 3.000 mm. 12,7 15,9 19,1 20,6 22,2 25,4 27,8 30,2 31,8 34,9 38,1 44,5 50,8 63,5 76,2 PART NO. DESCRIPTION Black 2055 2077 2089 2106 2119 2137 2157 2153 2155 2184 2213 2298 2422 2440 2460 UB-500 UB-625 UB-750 UB-812 UB-875 UB-1000 UB-1093 UB-1187 UB-1250 UB-1375 UB-1500 UB-1750 UB-2000 UB-2.500 UB-3.000 PART DIMENSIONS Maximum A B Inside Head Overall Diameter Diameter Height in. mm. in. mm. in. mm. .312 7,6 .600 15,2 .385 9,8 .437 11,1 .718 18,3 .406 10,3 .500 12,7 .844 21,4 .390 9,9 .500 12,7 .890 22,6 .390 9,9 .562 14,3 .937 23,8 .453 11,5 .750 19,1 1.063 27,0 .453 11,5 .812 20,6 1.156 29,4 .453 11,5 .950 24,1 1.250 31,8 .453 11,5 1.015 25,8 1.314 33,4 .453 11,5 1.000 25,4 1.490 37,8 .453 11,5 1.062 26,9 1.610 40,9 .450 11,4 1.375 34,9 1.870 47,5 .465 11,8 1.640 41,6 2.130 54,0 .490 12,4 1.970 50,0 2.660 67,6 .750 19,05 2.470 62,7 3.160 80,3 .750 19,05 Standard color black. Consult Heyco for white and other colors. Locking fingers in fractional increments up to maximum panel thickness. Heyco® Shorty Universal Bushings • Absorbs vibration and cushions and insulates cables, tubing, hoses or shafts with limited internal clearance. • Fingertip pressure snap-locks the bushing into its mounting hole. • Flexible shutters adjust to accommodate and support any shape from .125˝ (3,2 mm) to a maximum NEW! diameter of .820˝ (27,8 mm). • See Quick Specs on 4-8. PANEL DIMENSIONS Maximum Mounting Hole Thickness Diameter PART NO. DESCRIPTION Black in. mm. in. mm. .062 1,6 .500 12,7 2858 SUB 500 .062 1,6 .625 15,9 2861 SUB 625 .062 1,6 .750 19,1 2862 SUB 750 .062 1,6 .875 22,2 2863 SUB 875 .062 1,6 1.000 25,4 2864 SUB 1000 .062 1,6 1.093 27,8 2158 SUB 1093 Standard color black. Consult Heyco for white and other colors. Maximum Inside Diameter in. mm. .312 7,6 .437 11,1 .500 12,7 .560 14,2 .750 19,0 .820 27,8 PART DIMENSIONS A B Head Overall Diameter Height in. mm. in. mm. .600 15,2 .250 6,4 .729 18,5 .250 6,4 .859 21,8 .250 6,4 .937 23,8 .250 6,4 1.063 27,0 .250 6,4 1.156 29,4 .250 6,4 B A 4-7 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • Web site: www.heyco.com
很抱歉,暂时无法提供与“2119”相匹配的价格&库存,您可以联系我们找货
  • 1+1.408271+0.18304
  • 10+1.1660910+0.15157
  • 25+1.0933325+0.14211
  • 50+1.0431950+0.13559
  • 100+0.99187100+0.12892
  • 250+0.92980250+0.12085
  • 500+0.88540500+0.11508
  • 1000+0.843091000+0.10958
  • 2500+0.790242500+0.10272
库存:34364
