2824
2824
    HEYCO
2824 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Shorty Bushings ® Single Locking Step for Panel Thickness up to .062˝ (1,6 mm) Mounting Hole Diameter Range: .187˝ (4,7 mm) to 1.093˝ (27,8 mm) MOUNTING HOLE DIAMETER PART NO. Black White DESCRIPTION A Inside Diameter in. mm. PART DIMENSIONS B Head Diameter in. mm. in. mm. .187 .218 .281 .307 .312 4,7 5,5 7,1 7,8 7,9 2800 2859 2853 2808 2810 2801 2860 2854 2809 2811 B 187-125 B 218-125 B 281-218 B 307-244 B 312-250 .13 .13 .22 .24 .25 3,2 3,2 5,5 6,2 6,3 .25 .28 .34 .38 .38 6,4 7,1 8,7 9,7 9,7 .343 .375 .390 .406 .437 .468 .500 .512 .531 .593 .625 .687 .750 .781 .875 1.000 8,7 9,5 9,9 10,3 11,1 11,9 12,7 13,0 13,5 15,1 15,9 17,4 19,1 19,8 22,2 25,4 2856 2803 2815 2806 2813 2817 2820 2822 2824 2833 2827 2832 2836 2844 2850 2847 2857 2804 2816 2807 2814 2818 2821 2823 2825 2834 2828 2835 2837 2845 2851 2848 B 343-218 B 375-250 B 390-265 B 406-281 B 437-312 B 468-343 B 500-375 B 512-375 B 531-406 B 593-468 B 625-500 B 687-562 B 750-625 B 781-625 B 875-750 B 1000-875 .22 .25 .27 .28 .31 .34 5,5 6,3 6,7 7,1 7,9 8,6 .41 .44 .43 .47 .50 .53 10,3 11,1 10,9 11,9 12,7 13,5 .38 9,5 .56 14,3 .41 .47 .50 .57 .63 .63 .75 .88 10,3 11,9 12,7 14,4 15,9 15,9 19,0 22,3 .59 .66 .70 .76 .83 .86 .94 1.06 15,1 16,7 17,9 19,3 21,0 21,8 23,9 27,0 1.093 27,8 2838 2839 B 1093-969 .97 24,6 1.16 29,4 C Overall Height in. mm. .24 6,0 .25 6,4 .26 6,5 • For use in panels .062˝ (1,6 mm) and thinner. • Lower overall height protrudes less through thin mounting panels; thus Shorty Bushings occupy less “real estate” inside your application. • Insulating feed-thru bushings for limited internal clearance (minimum .125˝ (3,2 mm) applications. • Insulate and isolate electric or telecommunications cables as well as low RPM shafts and pushpull rods. • Locking fingers hold securely after only fingertip pressure snap-in installation. • Locking fingers in fractional increments up to the maximum panel thickness. • Available in multiple sizes for use in mounting holes from .187˝ (4,7 mm) to 1.093˝ (27,8 mm). Standard colors black and white. Consult Heyco for other colors. C B A SINGLE PANEL DESIGN (PANEL MAY BE THINNER) Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories, File E15331 Certified by Canadian Standards Association, File 8919 94V-2 -.4°F (-18°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 6-8
很抱歉,暂时无法提供与“2824”相匹配的价格&库存,您可以联系我们找货
