3304
3304
    HEYCO
3304 数据手册
“Stay Connected” with HEYware Products ® Heyco Nylon Cable Clamps ® • For clamping cable or tubing securely into place. • Resist corrosion, salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. (This feature is not assessed by UL certification or testing.) • All parts are size marked in inches and millimeters. • Standard material Nylon 6/6. 94V-0 available, consult Heyco. • For Snap Rivets compatible with Heyco Cable Clamps, see the table on page 7-37. MOUNTING HOLE DIAMETER in. mm. SCREW SIZE PART DIMENSION A in. mm. PART NO. V-2* Black Natural DESCRIPTION CENTER-TO-CENTER DIMENSION B in. mm. Light Duty - 3/8˝ (9,5 mm) wide, .05˝ (1,3 mm) thick .170 .203 Molded in open position for easy assembly. 4,3 8 5,2 10 .125 3,2 3362 3312 CCL 125-170 .36 9,1 .187 4,7 3363 3313 CCL 187-170 .39 9,9 .250 6,3 3364 3314 CCL 250-170 .42 10,7 .312 7,9 3365 3315 CCL 312-170 .46 11,7 .375 9,5 3366 3316 CCL 375-170 .49 12,4 .437 11,1 3367 3317 CCL 437-170 .53 13,5 14,0 .500 12,7 3368 3318 CCL 500-170 .55 .125 3,2 3352 3302 CCL 1/8 .34 8,6 .187 4,7 3353 3303 CCL 3/16 .38 9,7 .250 6,3 3354 3304 CCL 1/4 .41 10,4 .312 7,9 3355 3305 CCL 5/16 .44 11,2 .375 9,5 3356 3306 CCL 3/8 .48 12,2 .437 11,1 3357 3307 CCL 7/16 .51 13,0 .500 12,7 3358 3308 CCL 1/2 .53 13,5 Heavy Duty - 1/2˝ (12,7 mm) wide, .06˝ (1,5 mm) thick Full radius on all Inside edges Mounting Hole .203 5,2 10 .38 (9,7 mm) B Center-to-Center .05 (1,3 mm) A .125 3,2 3372 3322 CCH 1/8 .37 9,4 .187 4,8 3373 3323 CCH 3/16 .41 10,4 .250 6,3 3374 3324 CCH 1/4 .44 11,2 .312 7,9 3375 3325 CCH 5/16 .48 12,2 .375 9,5 3376 3326 CCH 3/8 .51 13,0 .437 11,1 3377 3327 CCH 7/16 .54 13,7 .500 12,7 3378 3328 CCH 1/2 .58 14,7 .562 14,3 3379 3329 CCH 9/16 .61 15,5 .625 15,9 3380 3330 CCH 5/8 .65 16,5 .687 17,4 3381 3331 CCH 11/16 .68 17,3 .750 19,1 3382 3332 CCH 3/4 .71 18,0 .812 20,6 3383 3333 CCH 13/16 .75 19,1 .875 22,2 3384 3334 CCH 7/8 .78 19,8 1.000 25,4 3390 3340 CCH 1 .85 21,6 1.125 28,6 3392 3342 CCH 1-1/8 .92 23,4 1.187 30,1 3393 3343 CCH 1-3/16 .95 24,1 1.250 31,8 3394 3344 CCH 1-1/4 .99 25,1 1.375 34,9 3396 3346 CCH 1-3/8 1.05 26,7 1.500 38,1 3398 3348 CCH 1-1/2 1.12 28,4 - ACC 1750-2000 Adjustable - 1/2˝ (12,7 mm) wide, .065˝ (1,7 mm) thick NEW! .203 5,2 10 1.75 - 44,5 2.00 50,8 3755 Standard colors black and natural. *Consult Heyco for V-O parts (not shown) Quick Specs 7-36 Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E54523 94V-2 32°F (0°C) to 221°F (105°C) - Black 32°F (0°C) to 185°F (85°C) - Natural 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“3304”相匹配的价格&库存,您可以联系我们找货
