1299
1299
    HEYCO
1299 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Shorty Window “View Port” Plugs ® Single Locking Step for Panel Thickness up to .062˝ (1,6 mm) Mounting Hole Diameter Range: .510˝ (13,0 mm) to 1.010˝ (25,7 mm) MOUNTING HOLE DIAMETER in. PART NO. DESCRIPTION PART DIMENSIONS A B Head Diameter Overall Height in. mm. in. mm. Clear* mm. .510 13,0 1292 SWP 510 .56 14,3 .635 16,1 1293 SWP 635 .73 18,6 .760 19,3 1294 SWP 760 .86 21,8 1295 SWP 885 .885 22,5 .95 24,2 1.13 28,6 .25 1295AA 1.010 25,7 1296 6,4 SWP 885 Infrared* SWP 1010 *Consult Heyco for Shorty Window Plugs in tinted colors. A B • Lock firmly into panels up to .062˝ (1,6 mm) thick, with limited intrusion inside the panel. • Molded of transparent polycarbonate for internal viewing or light transmission. • Snap into mounting holes with fingertip pressure–no tools required. • Locking fingers in fractional increments up to the maximum panel thickness. • Multiple sizes for use in .510˝ (13,0 mm) to 1.010˝ (25,7 mm) diameter holes. • Flammability Rating 94V-2. • Available in a variety of tints –consult Heyco. Heyco Oval Window “View Port” Plug ® Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) MOUNTING HOLE DIAMETER in. mm. PART NO. DESCRIPTION Clear* Head Diameter in. mm. see schematic 1299 OWP 875-2000 *Consult Heyco for Oval Window Plugs in tinted colors. 2.13 (54,4 mm) PART DIMENSIONS 2.13 - 1.01 54,4 - 26,6 Overall Height in. mm. .46 11,7 .46 (11,7 mm) FINGERS TO ACCOMMODATE PANEL THICKNESSES OF .032 (0,8 mm) - .125 (3,2 mm) 1.01 (25,6mm) .875 (22,2 mm) • Large viewing window for internal components. • Locking fingers in fractional increments up to the maximum panel thickness. Consult Heyco for Window Tints Other Than Clear R.438(2) (11,1 mm) HOLE SIZE 2.000 (50,8 mm) Material Flammability Rating Temperature Range Polycarbonate 94V-2 -40°F (-40°C) to 239°F (115°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 6-36
很抱歉,暂时无法提供与“1299”相匹配的价格&库存,您可以联系我们找货
