2000
2000
    HEYCO
2000 数据手册
“Stay Connected with Heyco” Bushings, Grommets, Bumpers & Feet Heyco Snap Bushings ® Mounting Hole Diameter Range: .250˝ (6,4 mm) to .875˝ (22,2 mm) • Convert raw-edged holes to smooth, neat, insulated holes. • Insulate and mechanically protect electrical and telecommunications cables, tubing, hose, rope, and utility lines. • Locking fingers snap into holes with fingertip pressure. • Locking fingers in fractional increments up to the maximum panel thickness. • Withstand a push back force of 35 pounds. • Available in multiple sizes for use in .250˝ (6,4 mm) to 6.00˝ (152,4 mm) diameter holes. • We offer the following brass-colored parts for lamp and lighting applications: Part No. 2012, SB 312-3 Brass Part No. 2033, SB 375-4 Brass Part No. 2041, SB 437-4 Brass MOUNTING HOLE DIAMETER in. PART NO. Black SINGLE PANEL DESIGN .250 PART DIMENSIONS B Head Diameter in. mm. C Overall Height in. mm. 6,4 2003 2004 SB 250-040 .125 3,2 .312 7,9 .312 7,9 .312 .375 7,9 9,5 .312 7,9 Single Locking Step for Panel Thickness up to .062˝ (1,6 mm) .250 .312 6,4 7,9 2000 2010 2001 2011 SB 250-2 SB 312-3 .140 .187 3,6 4,8 Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) .375 9,5 2020 2030 2021 2031 SB 375-3 SB 375-4 .187 .250 4,8 6,4 .468 11,9 .406 10,3 .437 11,1 2042 2038 2043 2037 2039 2044 SB 437-243 SB 437-4 SB 437-5 .243 .270 .312 6,2 6,8 7,9 .531 13,5 .406 10,3 .500 12,7 2058 2049 2053 2059 2050 2054 SB 500-4 SB 500-5 SB 500-6 .250 .312 .391 6,4 7,9 9,9 .570 14,5 .406 10,3 .562 14,3 2060 2063 2066 2061 2064 2067 SB 562-5 SB 562-6 SB 562-7 .312 .391 .437 7,9 9,9 11,1 .656 16,7 .406 10,3 .625 15,9 2075 2070 2073 2078 2071 2074 SB 625-4 SB 625-7 SB 625-8 .250 .440 .500 6,4 11,1 12,7 .718 18,2 .406 10,3 .687 17,4 2083 2086 2084 2087 SB 687-8 SB 687-9 .500 .562 12,7 14,3 .781 19,8 .406 10,3 .750 19,1 2090 2092 2093 2096 2091 2099 2094 2097 SB 750-6 SB 750-8 SB 750-9 SB 750-10 .391 .500 .562 .609 9,9 12,7 14,3 15,5 .850 21,6 .406 10,3 .812 20,6 2100 2103 2101 2104 SB 812-9 SB 812-10 .562 .625 14,3 15,9 .890 22,6 .406 10,3 22,2 2110 2113 2116 2120 2123 2126 2111 2114 2117 2121 2124 2127 SB 875-6 SB 875-7 SB 875-8 SB 875-9 SB 875-10 SB 875-11 .375 .437 .500 .562 .625 .687 9,5 11,1 12,7 14,3 15,9 17,5 .953 24,2 .453 11,5 .875 Standard colors black and white. Consult Heyco for other colors. B MULTIPLE PANEL DESIGN A Quick Specs 5-1 White mm. A C A Inside Diameter in. mm. Single Locking Step for Panel Thickness up to .040˝ (1,0 mm) C B DESCRIPTION Material Certifications Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories, File E15331 Certified by Canadian Standards Association, File 8919 Flammability Rating 94V-2 Material Temperature Index 257°F (125°C)–Maximum temperature on part not to exceed 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“2000”相匹配的价格&库存,您可以联系我们找货
  • 82+12.1526082+1.43570
  • 107+9.05485107+1.06973
  • 250+5.41364250+0.63956
  • 500+3.95722500+0.46750
库存:714
2000
  • 2000+0.647222000+0.07647
  • 5000+0.377105000+0.04455
库存:18000
2000
  • 1+1.099961+0.12995
  • 10+0.6810410+0.08046
  • 25+0.6370425+0.07526
  • 50+0.6063850+0.07164
  • 100+0.57666100+0.06813
  • 250+0.54039250+0.06384
  • 500+0.51469500+0.06081
  • 1000+0.490081000+0.05790
  • 2500+0.459282500+0.05426
库存:241807
