13105B
13105B
    HEYCO
    UV Black NT-18-047 Miniature Heyco® Nytye® Nylon Cable Tie
13105B 数据手册
“Stay Connected” with HEYware Products ® Heyco Nytye Nylon Cable Ties ® • Smooth, radiused edges ensure that Nytyes won’t cut into the cable’s insulation–or the installer’s hand. • One-piece design reduces cost and installation time. • Nytyes feature a bent tip for ease of pickup and insertion around small bundles. V-shaped raised ridges on the tip provide a sure grip. • Nylon 12 cable ties are weather/UV resistant and suitable for high moisture, corrosive and low temperature indoor or outdoor applications. • Close, evenly spaced teeth permit fine adjustment–from .025˝ (0,6 mm) on the smallest Nytyes to .063˝ (1,6 mm) on the largest. • Standard UV Black Nytyes are available in 100 packs; add -P to Part No.; eg. 13140B-P • Compliant with MS3367 and MIL-S-23190E PART SPECIFICATIONS Tensile Max. Bundle Strength Diameter Lbs. N in. mm. 18 80 40 .63 .87 1.18 1.38 1.57 2.36 16,0 22,0 30,0 35,0 40,0 60,0 13100 13102 13105 13107 13108 13111 13100B 13102B 13105B 13107B 13108B 13111B NT-18-031 NT-18-039 NT-18-047 NT-18-059 NT-18-063 NT-18-078 3.15 3.94 4.72 5.91 6.30 7.87 80 100 120 150 180 200 .10 2,5 .87 1.18 1.30 1.38 1.65 1.97 2.56 3.15 3.35 4.02 22,0 30,0 33,0 35,0 42,0 50,0 65,0 80,0 85,0 102,0 13120 13121 13122 13123 13124 13126 13128 13129 13130 13134 13120B 13121B 13122B 13123B 13124B 13126B 13128B 13129B 13130B 13134B NT-40-039 NT-40-047 NT-40-055 NT-40-059 NT-40-070 NT-40-078 NT-40-099 NT-40-110 NT-40-118 NT-40-145 3.94 4.72 5.51 5.91 7.09 7.87 9.92 11.02 11.81 14.57 100 120 140 150 180 200 252 280 300 370 178 .14 3,6 .94 1.57 1.65 1.97 2.56 2.76 3.23 3.54 4.02 4.13 5.12 5.91 24,0 40,0 42,0 50,0 65,0 70,0 82,0 90,0 102,0 105,0 130,0 150,0 13140 13142 13143 13145 13147 13149 13151 13153 13155 13156 13158 13160 13140B 13142B 13143B 13145B 13147B 13149B 13151B 13153B 13155B 13156B 13158B 13160B NT-50-047 NT-50-063 NT-50-072 NT-50-078 NT-50-098 NT-50-110 NT-50-118 NT-50-137 NT-50-145 NT-50-157 NT-50-177 NT-50-196 4.72 6.30 7.20 7.87 9.84 11.02 11.81 13.78 14.57 15.75 17.72 19.68 120 160 183 200 250 280 300 350 370 400 450 500 222 .19 4,8 Standard colors natural and UV Black. Consult Heyco for heat-stabilized material and colors. Standard UV Black Nytyes available in 100 packs; add -P to Part No.; eg. 13140B-P Heyco Nytye Nylon 12 Cable Ties ® ® PART SPECIFICATIONS Tensile Max. Bundle Strength Diameter Lbs. N in. mm. 40 7-64 PART DIMENSIONS A B Length Width in. mm. in. mm. Standard 50 Part No. 0998 (for Nylon) and 0996 (for Stainless Steel) fits all standard duty Nytyes. Metal construction, has three tension settings, and automatically trims excess. DESCRIPTION Intermediate A ® PART NO. UV Natural Black Miniature B Heyco Cable Tie Tensioning Tool ® 178 1.44 1.87 50 222 3.06 4.00 100 444 2.06 Standard color UV Black. Material Certifications Flammability Rating Temperature Range 36,6 47,5 77,7 101,6 52,3 PART NO. UV UV Black Black Bulk 100 Packs 13340B 13342B 13343B 13344B 13346B 13340B-P 13342B-P 13343B-P 13344B-P 13346B-P DESCRIPTION NT-40-058-12 NT-50-076-12 NT-50-112-12 NT-50-145-12 NT-100-087-12 ALL NEW PRODUCTS! PART DIMENSIONS A B Length Width in. mm. in. mm. 5.84 7.56 11.25 14.50 8.70 148,3 192,0 285,7 368,3 220,1 .14 3,6 .18 4,6 .30 7,6 Nylon 6/6 or Nylon 12 Certified by UL for Compliance with both Canadian and U.S. requirements under File E54523 (Nylon 6/6 only) 94V-2 -40°F (-40°C) to 185°F (85°C) (Nylon 6/6) -58°F (-50°C) to 302°F (150°C) (Nylon 12) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
13105B 价格&库存
很抱歉,暂时无法提供与“13105B”相匹配的价格&库存,您可以联系我们找货
