“Stay Connected” with
Power Components
Heyco PCB Contacts
PCB Blade, Pins, and Female Connectors
PART DATA
Type
Dimensions
in.
mm.
Blades
NEW!
For Maximum
PCB Thickness
in.
mm.
PART NO.
NonPolarized
polarized
Material
• Designed for printed circuit board
applications when connection to
AC power is required.
• Can be used for either NEMA 1-15
or 5-15 applications.
• Part Nos. 5200 and 5201 are full wide
designed for added support when
attached to the printed circuit board.
• For our complete line of stamped
Power Components, see Section 8.
• For our complete line of Nylon PCB
Supports, see section 7.
• DFARS Compliant
FEEDS
Length
Snap-thru
Pins*
.847
21,5
.047
1,2
Brass
5200
5201
1.030
26,1
.078
2,0
Brass
8179
.047
.047
1,2
1,2
Brass
Brass
5940
5907
Bulk
Bulk
Brass
7347
Bulk
Brass
7261
Bulk
Bulk
Diameter
Snap-Thru
Solder
.187
.187
4,7
4,7
Length
NEW!
Female
1.00
27,4
Rivet Mount†
1155-90 Female**
Wiping Contact 90°
.790
20,6
.047
1,2
*For additional Heyco Specialty Pins, see page 8-42.
**For additional Heyco Female Cord Connectors, see page 8-50.
.160˝ (4,1 mm) mounting hole.
5200
.060
.250
5201
.847
.312
.060
.19
.18
.77
.464
.847
.77
.464
UL/CSA
UL/CSA
MOLD LINE
MOLD LINE
.187
.187
5940
5907
.750 MIN
.843 MAX
.800
1.01
1.230
U/L & CSA
.047
MOLD LINE
.187
.31
.22
7261
.205
.78
.15
.56
.31
.25
Materials
Alloy 260 Brass (70% Cu, 30% Zn)
1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
Quick
Specs
8-38
很抱歉,暂时无法提供与“5200”相匹配的价格&库存,您可以联系我们找货
