4616
4616
    HEYCO
    缆线钳 镀镍黄铜 M10x1.5 银
4616 数据手册
“Stay Connected” with Liquid Tight Cordgrips ® ® Heyco -Tite EMC Brass Liquid Tight Cordgrips Straight-Thru, Metric Hubs EMC Nickel-Plated Brass with Contact Sleeve The Ultimate in Liquid Tight Strain Relief Protection CABLE DIA. RANGE Minimum in. PART NO. THREAD SIZE A Clearance Hole Dia. in. mm. PART DIMENSIONS B C D Max. O.A. Thread Wrenching Nut Length Length Flat Size in. mm. in. mm. in. mm. M8 x 1,25 .315 8,0 .94 24,0 .39 10,0 .43 11,0 M10 x 1,5 .394 10,0 .98 25,0 .39 10,0 .51 13,0 M12 x 1,5 .472 12,0 1.06 27,0 .39 10,0 .59 15,0 M16 x 1,5 M16 x 1,5 M20 x 1,5 M20 x 1,5 M25 x 1,5 M25 x 1,5 .630 .630 .787 .787 .984 .984 16,0 16,0 20,0 20,0 25,0 25,0 1.18 1.26 1.22 1.30 1.41 1.53 30,0 32,0 31,0 33,0 36,0 39,0 .39 10,0 .71 18,0 .39 10,0 .94 24,0 .43 11,0 1.18 30,0 1.260 32,0 1.65 42,0 .51 13,0 1.42 36,0 Maximum mm. in. or mm. Standard Thread .098 .118 .118 .157 .177 .236 .236 .315 .315 .433 .512 .630 .709 .827 2,5 3,0 3,0 4,0 4,5 6,0 6,0 8,0 8,0 11,0 13,0 16,0 18,0 21,0 .138 .157 .157 .236 .236 .295 .312 .394 .433 .551 .630 .748 .827 .984 3,5 4,0 4,0 6,0 6,0 7,5 8,0 10,0 11,0 14,0 16,0 19,0 21,0 25,0 4613 4614 4615 4616 4618 4619 4622 4623 4625 4626 4628 4629 4631 4632 3,5 4,0 4,0 6,0 6,0 7,5 8,0 10,0 11,0 14,0 16,0 19,0 21,0 25,0 14613 14614 14615 14616 14618 14619 14622 14623 14625 14626 14628 14629 14631 14632 M32 x 1,5 Short Thread .098 .118 .118 .157 .177 .236 .236 .315 .315 .433 .512 .630 .709 .827 2,5 3,0 3,0 4,0 4,5 6,0 6,0 8,0 8,0 11,0 13,0 16,0 18,0 21,0 .138 .157 .157 .236 .236 .295 .312 .394 .433 .551 .630 .748 .827 .984 M8 x 1,25 .315 8,0 .75 19,0 .20 5,0 .43 11,0 M10 x 1,5 .394 10,0 .79 20,0 .20 5,0 .51 13,0 M12 x 1,5 .472 12,0 .87 22,0 .20 5,0 .59 15,0 M16 x 1,5 M16 x 1,5 M20 x 1,5 M20 x 1,5 M25 x 1,5 M25 x 1,5 .630 .630 .787 .787 .984 .984 16,0 16,0 20,0 20,0 25,0 25,0 .98 1.06 1.06 1.10 1.26 1.38 25,0 27,0 27,0 29,0 32,0 35,0 .20 5,0 .71 18,0 .24 6,0 .94 24,0 .28 7,0 1.18 30,0 1.260 32,0 1.46 37,0 .31 8,0 1.42 36,0 .630 16,0 .98 25,0 .20 5,0 .71 18,0 M32 x 1,5 • Ideal for applications where Electromagnetic Interference (EMI) protection or Electromagnetic Compatibility (EMC) is needed. • IP 68 rated. • Nickel-plated finish over brass provides excellent corrosion resistance and durability. • Excellent 360° shield contact with contact sleeve due to braided shield which runs into the gland. • Combination of the sealing insert and the contact socket guarantees a constant contact quality with minimal transfer impedance. • Inner cable protection. • Long thread for use in standard or thick panels. • Multiple sizes for flexible cord diameters ranging from .098˝ (2,5 mm) to .984˝ (25,0 mm). • For use in clearance or threaded holes. • Cordgrips are made of nickel plated brass and the gland is made of TPE. • EMC locknuts available. See page 3-41. • DFARS Compliant Short Thread, High Temperature* .236 6,0 .315 8,0 4609 M16 x 1,5 *Special sealing gland rated to 200°C (392°F). B A C D Material Certifications Temperature Range IP Rating Nickel-Plated Brass W/TPE Sealing Gland Recognized under the Component Program of Underwriters’ Laboratories File E51579 to both Canadian and U.S. requirements -40°F (-40°C) to 212°F (100°C) IP 68, IP 69K 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 3-40
很抱歉,暂时无法提供与“4616”相匹配的价格&库存,您可以联系我们找货
  • 1+146.023981+18.95629
  • 10+124.0884810+16.10870
  • 25+116.3129425+15.09931
  • 50+110.7625450+14.37878
  • 100+105.47792100+13.69275
  • 250+98.87897250+12.83610
  • 500+94.16452500+12.22409
  • 1000+89.676421000+11.64146
库存:15
