3231
3231
    HEYCO
3231 数据手册
“Stay Connected” with Liquid Tight Cordgrips ® ® Heyco Original Series-35 Liquid Tight Cordgrips Straight-Thru, NPT Hubs • Wide range of approved cable diameters. • IP 68 rated. • Acme threads on body prevent skipping and speed installation. • For use in clearance or threaded holes. • All nylon construction with TPE sealing gland resists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. (This feature is not assessed by UL.) • Multiple sizes for flexible cord diameters ranging from .069˝ (1,8 mm) to 1.000˝ (25,4 mm). For larger sizes, see Heyco-Tite Liquid Tight Cordgrips on page 3-1. • We recommend using the cordgrip with the smallest maximum diameter that will fit your application. Cable ranges listed are for the maximum IP68 sealing range. Contact Heyco for UL approved 514B cable ranges. • Locknuts not included. For nylon locknut specifications or to order locknuts separately, see page 3-47. • For Heyco Liquid Tight Threaded Plugs, see page 3-51. • Consult Heyco for cordgrips molded in other colors. CABLE DIA. RANGE PART NO. DESCRIPTION Locknuts Minimum Maximum Not Included* Black Gray in. mm. in. or mm. .069 1,8 .187 .115 2,9 .312 PART DIMENSIONS A B C D E Clearance Max. O.A. Thread Wrenching Nut Hole Dia. Length Length Thk. Flat Size in. 4,7 3458 3459 7,9 3228 3229 mm. in. mm. in. mm. in. mm. in. mm. RLTF 3/8 LTF 3/8 .670 17,0 1.49 37,8 .53 13,5 .20 5,1 .75 19,1 .170 4,3 .450 11,4 3231 3232 LTF 1/2 .875 22,2 1.72 43,7 .62 15,7 .20 5,1 .95 24,1 .230 5,8 .546 13,9 3200 3201 LLTF 1/2 .875 22,2 1.83 46,5 .62 15,7 .23 5,8 1.05 26,7 .250 6,4 .485 12,3 3204 3205 .450 11,4 .709 18,0 3202 3203 MRLTF 1/2 MLTF 1/2** .875 22,2 1.97 50,0 .63 16,0 .23 5,8 1.30 33,0 .250 6,4 .485 12,3 3460 3461 .450 11,4 .709 18,0 3234 3235 RLTF 3/4 LTF 3/4 1.109 28,2 1.97 50,0 .63 16,0 .23 5,8 1.30 33,0 .590 15,0 1.000 25,4 8437 8438 LTF 1 1.350 34,3 2.42 61,5 .75 19,1 .28 7,1 1.65 41,9 Standard colors black and gray. *To order Nylon or Metal Locknuts separately, see pages 3-47 and 3-48. **For cable diameters greater than .600˝, the insulating jacket must be stripped back. Reference customer drawing 3202/3203. For larger sizes, see Heyco-Tite Liquid Tight Cordgrips on page 3-1. Acme threads prevent skipping, speed installation. TPE compression gland for sealing. Domed sealing nut resists snags, sheds contaminants. Internal ratchet provides self-locking against vibration. Collet design of body accommodates various size cords, cables, tubing. Special contour provides tight seal at mounting panel without O-ring. B C D*** A E SEALING NUT SUGGESTED CLEARANCE HOLE FOR NONTHREADED MOUNTING Consult Heyco for your alternate material requirements! Quick Specs 3-19 Material Certifications Flammability Rating Temperature Range IP Rating Nylon 6/6 with TPE Sealing Gland Listed under Underwriters’ Laboratories File E51579 Recognized Under the Component Program of Underwriters’ Laboratories File E51579 Certified by Canadian Standards Association File 93876C 94V-2 Static -40°F (-40°C) to 239°F (115°C) Dynamic -4°F (-20°C) to 212°F (100°C) IP 68 (70 PSI, 5 BAR) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
3231
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、OUT和GND。
4. 参数特性:工作电压为3-5.5V,工作电流为0.1mA,接收频率为38kHz。
5. 功能详解:EL817可以接收38kHz的红外信号,并输出相应的电信号。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装。
很抱歉,暂时无法提供与“3231”相匹配的价格&库存,您可以联系我们找货
    • 50+19.6635250+2.54378
    • 250+13.21051250+1.70898
    • 500+12.88828500+1.66730
    • 1500+11.799041500+1.52639
    • 3000+11.514963000+1.48964
    库存:45815
    3231
    • 3+362.732253+46.92496
    • 12+58.5254212+7.57116
    • 30+22.6427130+2.92918
    • 50+20.8823350+2.70145
    • 100+10.90145100+1.41027
    • 250+7.59710250+0.98280
    • 500+6.64908500+0.86016
    • 1000+6.645841000+0.85974
    • 2500+6.643402500+0.85943
    • 5000+5.204345000+0.67326
    库存:117626
    3231
      库存:1500
      3231
      库存:7719
