10786
10786
    HEYCO
10786 数据手册
“Stay Connected” with HEYware Products ® ® Heyco Nylon PCB Supports - Adhesive-Back Mount BAYONET SNAP LOCK 10,2 / ADHESIVE-BACK BASE 17,8 sq BAYONET SNAP FIT 10,2 / ADHESIVE-BACK BASE 17,8 sq BAYONET SNAP LOCK 8,7 / ADHESIVE-BACK BASE 12,7 sq TEARDROP SNAP LOCK / ADHESIVE-BACK BASE 12,7 sq HCBS2 HCBS3 HCBS4 HCBS Maximum Thickness in. mm. PCB .062 Chassis 1,6 Mounting Hole Diameter in. mm. .157 4,0 adhesive-back mount A Maximum Thickness in. mm. .062 1,6 Mounting Hole Diameter in. mm. .157 4,0 adhesive-back mount Maximum Thickness in. mm. .062 1,6 Mounting Hole Diameter in. mm. .125 3,2 adhesive-back mount Maximum Thickness in. mm. .062 1,6 Mounting Hole Diameter in. mm. .098 2,5 adhesive-back mount PART NO. Natural DESCRIPTION PART NO. Natural DESCRIPTION PART NO. Natural DESCRIPTION mm. PART NO. Natural DESCRIPTION in. .187 4,8 10772 HCBS-03-AB 10784 HCBS2-03-AB 10794 HCBS3-03-AB 10803 HCBS4-03-AB .250 6,4 10773 HCBS-04-AB 10785 HCBS2-04-AB 10795 HCBS3-04-AB 10804 HCBS4-04-AB .312 7,9 10796 HCBS3-05-AB .375 9,5 .437 11,1 .500 12,7 .562 14,3 .625 15,9 10774 10775 10776 HCBS-06-AB HCBS-08-AB HCBS-10-AB 10786 10787 10788 HCBS2-06-AB HCBS2-08-AB HCBS2-10-AB .750 19,1 10777 HCBS-12-AB 10789 HCBS2-12-AB .875 22,2 10778 HCBS-14-AB 10790 HCBS2-14-AB 1.000 25,4 10779 HCBS-16-AB 10791 HCBS2-16-AB 1.125 28,6 10780 HCBS-18-AB 10792 HCBS2-18-AB 10797 HCBS3-06-AB 10805 HCBS4-06-AB 10798 HCBSC-07-AB 10806 HCBS4-07-AB 10807 HCBS4-08-AB 10808 HCBS4-10-AB 10799 HCBS3-08-AB 10800 HCBS3-09-AB 10801 HCBS3-10-AB Standard color natural. Quick Specs 7-26 Material Flammability Rating Temperature Range Nylon 6/6 with PE foam tape 94V-2 -40°F (-40°C) to 185°F (85°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
10786 价格&库存
很抱歉,暂时无法提供与“10786”相匹配的价格&库存,您可以联系我们找货
    • 1000+3.327521000+0.43131
