1282
1282
    HEYCO
1282 数据手册
“Stay Connected” with Strain Relief Bushings ® Heyco Nylon Removable Snap-In Ratcheting Strain Reliefs ® For Round and Double D Mounting Holes WILL FIT THESE CABLES Cross Approximate Section Size in. mm. PANEL DIMENSIONS Mounting Maximum Hole Size Thickness in. mm. in. mm. Round, Flat or Multiple .12.58 2,914,6 .875 w/.770 flats Round, Flat or Multiple .12.75 2,919,1 1.109 w/1.000 flats PART NO. DESCRIPTION BODY LENGTH Black in. Corresponding Mounting Hole Plug mm. PART NO. DESC. 22,2 w/19,6 flats .13 3,2 1280 RSR 875 1.00 25,4 2509 DD 875 -770 28,2 w/25,2 flats .13 3,2 1282 RSR 1109 1.00 25,4 2717 DD 1109 -1000 Standard color black. Consult Heyco for white and other colors. Holes for Removal WIRE LOCKING RATCHET .99 (25,2 mm) .875 (22,2 mm) MOUNTING HOLE .98 (24,8 mm) .40 (10,2 mm) 1280 .770 (19,6 mm) .99 (25,2 mm) 1.109 (28,2 mm) • Assembly friendly! Independent of insertion into the panel, the Ratcheting Strain Relief self-locks onto the cable. Thus, it may be preassembled offline for final assembly at a later time or remote location, for lower installed cost! • Unique wire locking ratchet allows for generous wire range from .12˝ (2,9 mm) to .75˝ (19,1 mm). • Can be used for one cable or multiple cables (round or flat wire). • Installs easily with fingertip pressure into a standard round or Double D hole. • Ratcheting Strain Relief can be easily removed by inserting standard snap ring pliers with .04˝ tips (Heyco PN 0054) into the two holes on the part (see drawing) and spreading part open. • Ideal solution for managing internal wire bundles such as wire harnesses. • PN 1280 UL Recognized for multiple cables/conductors. • Consult Heyco for other wire types and sizes. • For Double D Mounting Hole Punches, see page 4-30. PN 0054 MOUNTING HOLE 1.19 (30,2 mm) .40 (10,2 mm) 1282 Material Certifications Flammability Rating Temperature Range 1.000 (25,4 mm) Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E15331 Certified by Canadian Standards Association File 8919 94V-2 -.04°F (-18°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 4-4
很抱歉,暂时无法提供与“1282”相匹配的价格&库存,您可以联系我们找货
