1027
1027
    HEYCO
1027 数据手册
“Stay Connected” with Liquid Tight Conduit, Tubing & Fittings ® Heyco-Flex Mounting Brackets ™ • For mounting Heyco-Flex Conduit or Tubing securely into place, vertically or horizontally. See pages 2-1, 2-7, and 2-8. • Only fingertip pressure is required to snap conduit or tubing into bracket. • Low profile design for space savings and pleasing appearance. • Recommended distance between brackets at intervals not greater than 3 feet (1m) as required by Article 351-27 of 1996 NEC. • Use one standard #10 (4-5M) screw for attaching bracket to panel (screw not included). • Resist salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. FITS CONDUIT/ TUBING SIZE PART NO. DESCRIPTION PART DIMENSIONS A Inside Dia. Black Gray in. 3/8 1025 1026 HFB 3/8 1/2 1027 1028 HFB 1/2 3/4 1029 1030 HFB 3/4 1 1031 1032 HFB 1 Standard color black or gray. mm. .66 .79 1.05 1.24 16,9 20,0 26,7 31,5 B Length in. .91 1.07 1.27 1.52 C Height mm. in. 23,2 27,3 32,2 38,6 .72 .71 .67 .84 mm. 18,2 18,0 17,0 21,3 A C in. mm. .90 1.06 1.31 1.53 22,9 26,8 33,2 38,9 E Width in. mm. .75 19,1 D Dimensions excluding draft B D Outside Dia. E Heyco Sealing Washers ® Will Fit These Electrical Fitting NPT Trade Sizes • For use with Heyco-Flex fittings. • Liquid tight, dust tight, and oil tight at enclosure. • Suitable for wet locations requiring a separate gasket between the box and fitting. • Also suitable for other panel sealing applications. • Easy to install since washers seal off on the perimeter, not on the connector threads. • Special double sealing ridges compensate for minor unevenness at enclosure. PART NO. 1/4 3/8 1/2 3/4 1 1-1/4 1-1/2 2 Standard color black. DESCRIPTION A Inside Diameter Black 3258 3259 3260 3261 3262 3264 3265 3257 SW 1/4 SW 3/8 SW 1/2 SW 3/4 SW 1 SW 1-1/4 SW 1-1/2 SW 2 PART DIMENSIONS B Outside Diameter in. mm. in. mm. .54 .67 .85 1.03 1.28 1.66 1.86 2.32 13,7 17,0 21,6 26,2 32,5 42,2 47,2 58,9 .80 1.01 1.24 1.50 1.77 2.16 2.44 2.93 20,2 25,5 31,5 38,1 45,0 54,8 62,0 74,4 C Thickness in. mm. .13 3,2 .14 .18 3,4 4,6 .16 4,1 .18 4,6 C B A Quick Specs 2-19 Material Flammability Rating Temperature Range HFB - Nylon 6/6 HFB - 94V-2 -22°F (-30°C) to 221°F (105°C) SW - Thermoplastic Elastomer SW - 94V-0 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“1027”相匹配的价格&库存,您可以联系我们找货
