760RWK UK
760RWK UK
    ANTEX
    ANTEX - 760RWK UK - Rework Station, 450 °C, 230 V, UK
760RWK UK 数据手册
Soldering Stations from ANALOGUE DIGITAL HOT AIR - REWORK 660A 690D 760RWK • Stations include power supply, New* ST6a iron stand and a lightweight 50W industrial grade soldering iron fitted with silicone heatresistant cable and a 2.3mm (1100) bit RANGE OF TIPS 1100 2.3mm • Temperature range continually adjustable from 200°C to 450°C 1101 3.0mm • LEDs indicate mains power and iron power 1102 4.7mm • Housed in a robust metal enclosure, which is suitable for the most demanding industrial and educational environments 1103 6.0mm • Replacement bits and soldering irons are available separately 1105 0.5mm • Fully compatible with the latest European EMC and CE regulations 1106 1.0mm • Supply voltage - 230V AC 1107 0.12mm 1108 3.0mm 1109 5.0mm • Iron voltage - 24V • Power - 50 Watts • Leakage current
760RWK UK 价格&库存
很抱歉,暂时无法提供与“760RWK UK”相匹配的价格&库存,您可以联系我们找货
