CS-18 230V
CS-18 230V
    ANTEX
    ANTEX - CS-18 230V - Soldering Iron, Plug-in, 18 W, 230 VAC, UK
CS-18 230V 数据手册
CS18 The Antex CS18 soldering iron is ideal for miniature precision soldering. Features           Nominal Power - 18 watts 12V, 24V, & 230V versions are available Supplied with long-life iron plated bit Antex 1100 bit is fitted to this iron (2.3mm) An inner ceramic shaft provides near perfect insulation A range of alternative sized bits are also available All irons are available with the option of a burn-proof silicone cable. Ideally suited to educational environments Supplied complete with 2.3mm bit, 1.5m of cable and full instructions CE marked Soldering iron stands are available separately Options Product S482470 S473470 S48J470 Description CS18 230V PVC cable, British Plug CS18 230V PVC cable, European Plug CS18 230V Silicone cable, British Plug
CS-18 230V 价格&库存
很抱歉,暂时无法提供与“CS-18 230V”相匹配的价格&库存,您可以联系我们找货
