ES800F2
ES800F2
    ANTEX
ES800F2 数据手册
Replacement Elements • • • • • • • CE conformity Built to meet BS EN60335-2-45 Full power range from 12 to 50 watts Wide choice of input voltages "Thermally balanced" fixed setting and "in handle" adjustable temperature models Wide range of soldering and desoldering bit profiles Light, compact and well balanced for operator satisfaction By designing the bit to wrap around the heating element, ANTEX have ensured maximum heat transfer into the bit, and minimum heat loss to ambient. Such is the efficiency that tests have proven that an ANTEX 25 watt iron has equivalent soldering power to many other manufacturers' 40 watt irons. The ANTEX MLXS is a 25 watt 12 volt soldering iron equipped with a 4.5 metre twin cable furnished with giant "croc-clips" for use on vehicle batteries. Ideal for emergency use in the car, boat or caravan, the package is also a must for outdoor hobbyists such as model aircraft or boat enthusiasts where urgent repairs may be needed and mains power is not available. The ANTEX SK2, SK5 and SK6 kits offer a high quality soldering iron, ST6 bench stand, length of solder and the "Introduction to Soldering" booklet all in one package. The three kits differ only by the soldering iron contained therein. Soldering irons in these kits are available with options of UK or Europlug, or silicone rubber cable. The TCK-50 kit comprises the essential tools for the serious hobbyist or service/repair shop. The adjustable 50 watt temperature controlled TCS iron can be set precisely to match the job in hand, recognising that various components may require protection against overheating. The ST6 bench stand accommodates the iron when not in use. For solder removal from p.c.b.'s a "mini" desolder pump is included and a 2 metre length of 60/40 22 s.w.g. solder wire. Soldering irons in this kit are available with options of UK or Europlug, or silicone rubber cable. SPECIFICATION NOMINAL POWER (W) STANDARD VOLTAGE OPTIONAL VOLTAGES TIP TEMP (° C) FITTED BIT CABLE LENGTH (m) CABLE TYPE LEAK CURRENT (uA) LENGTH TIP/HANDLE (mm) M 12 230,115,24 100 370 10 1.5 PVC 1.5 147 M230E C230E C 15 230,115,24 100,50 370 820 1.5 PVC 3.5 147 Element for Soldering Iron, 12W / 230V Element for Soldering Iron, 15W / 230V Element for Soldering CS230E Iron, 18W / 230V Element for Soldering XS230E Iron, 25W / 230V CS 18 230,115,24 100,50,12 390 1100 1.5 PVC 1.5 182 E170060 E270060 E470060 E580060 XS 25 230,115,24,12 100,50 420 51 1.5 PVC 2.0 200 TCS 50 230,115 100 200-450 1100 1.5 PVC 5.0 222 A545 45 24 200-450 1100 1.5 SILICONE 1.5 222 XS12E Element for Soldering Iron, 25W / 12V Element for Soldering TCS230E Iron, 50W / 230V TC25E TC50E SD50E Element for Soldering Iron, 25W / 24V Element for Soldering Iron, 50W / 24V Element for Soldering Iron, 50W / 24V E510060 E680080 EK20080 EL20080 EM20080 Element for Soldering HP100E Iron, 100W / ER80010 230V Replacement Element Major E for Soldip ES80080 Max
ES800F2 价格&库存
很抱歉,暂时无法提供与“ES800F2”相匹配的价格&库存,您可以联系我们找货
