CS18 UK
CS18 UK
    ANTEX
    ANTEX - CS18 UK - Soldering Iron Tool Kit, Antex CS18 Iron, Digital Multimeter, 230V, 18W, UK Plug, ...
CS18 UK 数据手册
SD02030 DATA SHEET CS 18 TOOL KIT An engineer’s toolkit featuring an Antex CS18 burn-proof silicone cabled iron, a variety of tools, and a digital multimeter. The tip fitted to the iron is a long life, iron plated Antex 1100 bit (2.3mm). Iron power is 18 watts. CE approved. IRON SPECIFICATIONS CS 18 18WATT SOLDERING IRON NOMINAL POWER (W) 18 STANDARD VOLTAGE 230 NOMINAL TIP TEMP (°C) 390 FITTED BIT 1100 (2.3mm) CABLE LENGTH (m) 1.5 CABLE TYPE Silicon with British plug LEAKAGE CURRENT (uA)
CS18 UK 价格&库存
很抱歉,暂时无法提供与“CS18 UK”相匹配的价格&库存,您可以联系我们找货
