250 340 LSPB
250 340 LSPB
    YOKOGAWA
    CURRENT METER
250 340 LSPB 数据手册
Table of Contents DC Voltmeters DC Ammeters DC Microammeters DC Milliammeters AC Voltmeters AC Ammeters AC Microammeters AC Milliammeters AC Frequency Meters AC Motor Load Indicators Expanded Scale Voltmeters Elapsed Time Meters Terminal Resistance Values Cross Reference to Other Manufacturers Electrical and Physical Options Parts & Accessories Dimensional Drawings New Big Look Horizon Line Stylist 2-3 3-5 3 4 5-6 6-7 6 6 13 12 3,5 8 8-10 8-9 9 10-11 11-12 11 12 13 12 8, 11 14 15-16 15 15 17 17-19 20-21 32 30-31 29 32-33 20-21 32 30-31 29 34-35 Elapsed Time 185 Edgewise 280 Edgewise 26 26 26 26 26 26 26 27 28 28 28 28 28 28 28 26 27-28 30-31 25, 29 37 30-31 27, 29 38 17, 18 19 14, 17 24-25 22-23 32 30-31 29 36 38, 39 Key to 200-Prefix Catalog Numbers 250 2 40 Digits 1, 2, and 3 Style 250 - New Big Look (Taut Band), (I/V*-P&J) 251 - Horizon Line (Taut Band), (I/V*-P&J) 254 - New Big Look (P&J) 255 - Horizon Line (P&J) 260 - Surface Mount (Taut Band), (I/V*-P&J) 261 - Window Mount (Taut Band), (I/V*-P&J) 264 - (P&J) Surface Mount 265 - (P&J) Window Mount Digit 4 - Size 1 - 11⁄2” 2 - 21⁄2” 3 - 31⁄2” 4 - 41⁄2” *I/V = Iron Vane Mechanism Digits 5 and 6 Elec. and Mechanical Variables 00 - DC Amps Zero-Left 01 - DC Amps Zero-Center 04 - DC Volts/Ext. Res. Zero-Left 05 - DC Volts/Ext. Res. Zero-Center 10 - AC Amps Rectified 20 - DC Volts Zero-Left 21 - DC Volts Zero-Center 24 - DC Millivolts Zero-Left 25 - DC Millivolts Zero-Center 30 - AC Volts Rectified 37 - AC Expanded Scale Voltmeter 38 - DC Expanded Scale Voltmeter 40 - AC Amps (I/V)* 60 Hz 44 - AC Volts (I//V)* 60 Hz 45 - AC Volts 400 Hz (I/V)* 50 - Frequency LS LS 7,8,9,1 XXX or XXXXXXXXXX Digits 12, 13, 14, 15, 16, 17-21Special Units When used, these denote unique models. Refer to factory for details. Digit 11 - Factory Style For factory use. Digits 9 and 10 - Scale Example: LS = 0-5 Amps MT= 0-10 Amps NG = 0-20 Amps Digits 7 and 8 - Elec. Rating Example: LS = 5 Amps MT = 10 Amps NG = 20 Amps 1 New Big Look Overload: Voltmeters (AC and DC) - 50% momentary, 20% sustained. Ammeters (AC and DC) momentary; 10 times the rated current for 10 consecutive intervals of .5 second with a 1 minute interval between successive applications; sustained: 20% for six hours. Type 250 and 254 New Big Look New Big Look 1.40” 2.06” 2.88” 3.93” Insulation Level: All meters (except 11⁄2”), 2600 Vrms Hi-pot, 11⁄2”-1500 Vrms Hi-pot. Specifications Burden Data: AC ammeter-5 amps, 0.5 va, Max. 0.5 power-factor lagging @ 60 Hz. AC voltmeter - unity power factor. Accuracy: All DC and AC iron-vane; ±2% of full-scale AC rectifier type; ±3% of full scale (with 60 Hz sine wave at 25º C). When standard 60 Hz iron vane ammeters are used at the extreme limits of 25 or 400 Hz, additional error (approx. .75%) may be experienced. Expanded-scale voltmeters: ±.5% of full scale value. Response Time and Overshoot: Response time: 3 seconds (max.) for 21⁄2”, 31⁄2”, 41⁄2” size for microammeters; 2 seconds (max.) for all other DC ratings, and 2.5 seconds (max) for AC ratings. Maximum of 40% overshoot. ANSI Specification: All meters meet ANSI Specifications C-39.1 To order New Big Look panel meters use the appropriate catalog numbers provided in the tables. Taut band & AC I/V instruments have a 250 prefix number. Pivot & Jewel instruments have a prefix of 254. Ordering Examples: Scale Data: 90 degree rotation. Scale Length: Size 11⁄2” 21⁄2” 31⁄2” 41⁄2” How To Order Dimensions: See page 32-33 1. 21⁄2”, 300 V DC Voltmeter, zero left, taut band - 250 220 RXRX 2. 21⁄2”, 300 V DC Voltmeter, zero left, pivot & jewel, 254 style - 254 220 RXRX 3. 21⁄2”, 300 V AC (Iron Vane), pivot & jewel - 250244 RXRX Notes: Pivot & jewel instruments are not available in 11⁄2” size. Severe-duty meters are available to meet CSA, UL 1437 and IEC 144 requirements. UL/CSA version, with flame retardant window and base, is not offered in 11⁄2”. IEC version is not offered in 11⁄2” and 41⁄2”. To order, add /CSA, /UL or IEC after catalog number, or contact factory. For ratings and scales not listed contact factory. DC Voltmeters 11⁄2 Size Rating & Scale Type Taut Band 21⁄2 Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band Pivot and Jewel DC VOLTMETERS — ZERO-LEFT 1.0 Volts 1.5 Volts 3 Volts 5 Volts 8 Volts 250 120 LALA 250 120 LCLC 250 120 LJLJ 250 120 LSLS 250 120 MJMJ 250 220 LALA 250 220 LCLC 250 220 LJLJ 250 220 LSLS 250 220 MJMJ 254 220 LALA 254 220 LCLC 254 220 LJLJ 254 220 LSLS 254 220 MJMJ 250 320 LALA 250 320 LCLC 250 320 LJLJ 250 320 LSLS 250 320 MJMJ 254 320 LALA 254 320 LCLC 254 320 LJLJ 254 320 LSLS 254 320 MJMJ 250 420 LALA 250 420 LCLC 250 420 LJLJ 250 420 LSLS 250 420 MJMJ 254 420 LALA 254 420 LCLC 254 420 LJLJ 254 420 LSLS 254 420 MJMJ 10 Volts 15 Volts 30 Volts 40 Volts 50 Volts 250 120 MTMT 250 120 NDND 250 120 NLNL 250 120 NPNP 250 120 NTNT 250 220 MTMT 250 220 NDND 250 220 NLNL 250 220 NPNP 250 220 NTNT 254 220 MTMT 254 220 NDND 254 220 NLNL .......... 254 220 NTNT 250 320 MTMT 250 320 NDND 250 320 NLNL 250 320 NPNP 250 320 NTNT 254 320 MTMT 254 320 NDND 254 320 NLNL .......... 254 320 NTNT 250 420 MTMT 250 420 NDND 250 420 NLNL 250 420 NPNP 250 420 NTNT 254 420 MTMT 254 420 NDND 254 420 NLNL .......... 254 420 NTNT 80 Volts 100 Volts 150 Volts 200 Volts 250 Volts 250 120 PDPD 250 120 PKPK 250 120 PZPZ 250 120 RLRL 250 120 RSRS 250 220 PDPD 250 220 PKPK 250 220 PZPZ 250 220 RLRL 250 220 RSRS 254 220 PDPD 254 220 PKPK 254 220 PZPZ 254 220 RLRL 254 220 RSRS 250 320 PDPD 250 320 PKPK 250 320 PZPZ 250 320 RLRL 250 320 RSRS 254 320 PDPD 254 320 PKPK 254 320 PZPZ 254 320 RLRL 254 320 RSRS 250 420 PDPD 250 420 PKPK 250 420 PZPZ 250 420 RLRL 250 420 RSRS 254 420 PDPD 254 420 PKPK 254 420 PZPZ 254 420 RLRL 254 420 RSRS 300 Volts 500 Volts 600 Volts 250 120 RXRX .......... .......... 250 220 RXRX .......... .......... 254 220 RXRX .......... .......... 250 320 RXRX 250 320 SFSF 250 320 SJSJ 254 320 RXRX 254 320 SFSF 254 320 SJSJ 250 420 RXRX 250 420 SFSF 250 420 SJSJ 254 420 RXRX 254 420 SFSF 254 420 SJSJD DC VOLTMETERS — ZERO-LEFT, RATED 0-1 mA DC, FOR USE WITH EXTERNAL RESISTORS. RESISTORS NOT INCLUDED (SEE PAGE 29 FOR RESISTORS) S C A L E O N L Y 2 500 Volts 600 Volts 750 Volts 250 104 FASF 250 104 FASJ 250 104 FASM 250 204 FASF 250 204 FASJ 250 204 FASM 254 204 FASF 254 204 FASJ 254 204 FASM .......... .......... 250 304 FASM .......... .......... 254 304 FASM .......... .......... 250 404 FASM .......... .......... 254 404 FASM DC Voltmeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band Pivot and Jewel DC VOLTMETERS — ZERO-CENTER 5-0-5 Volts 10-0-10 Volts 30-0-30 Volts 50-0-50 Volts 80-0-80 Volts 250 121 LSLS 250 121 MTMT 250 121 NLNL 250 121 NTNT 250 121 PDPD 250 221 LSLS 250 221 MTMT 250 221 NLNL 250 221 NTNT 250 221 PDPD 254 221 LSLS 254 221 MTMT 254 221 NLNL 254 221 NTNT 254 221 PDPD 250 321 LSLS 250 321 MTMT 250 321 NLNL 250 321 NTNT 250 321 PDPD 254 321 LSLS 254 321 MTMT 254 321 NLNL 254 321 NTNT 254 321 PDPD 250 421 LSLS 250 421 MTMT 250 421 NLNL 250 421 NTNT 250 421 PDPD 254 421 LSLS 254 421 MTMT 254 421 NLNL 254 421 NTNT 254 421 PDPD 150-0-150 Volts 300-0-300 Volts 500 -0-500 Volts 600-0-600 Volts 250 121 PZPZ 250 121 RXRX .......... .......... 250 221 PZPZ 250 221 RXRX .......... .......... 254 221 PZPZ 254 221 RXRX .......... .......... 250 321 PZPZ 250 321 RXRX 250 321 SFSF 250 321 SJSJ 254 321 PZPZ 254 321 RXRX 254 321 SFSF 254 321 SJSJ 250 421 PZPZ 250 421 RXRX 250 421 SFSF 250 421 SJSJ 254 421 PZPZ 254 421 RXRX 254 421 SFSF 254 421 SJSJ .......... .......... .......... 250 338 NNNN 250 338 PNPN 250 338 RTRT 254 338 NNNN 254 338 PNPN 254 338 RTRT 250 438 NNNN 250 438 PNPN 250 438 RTRT 254 438 NNNN 254 438 PNPN 254 438 RTRT DC VOLTMETERS — EXPANDED SCALE 24-30 Volts 110-130 Volts 220-260 Volts .......... .......... .......... .......... .......... .......... DC VOLTMETERS — ZERO-CENTER, RATED 1-0-1 mA DC, FOR USE WITH EXTERNAL RESISTORS, RESISTORS NOT INCLUDED (SEE PAGE 29 FOR RESISTORS) S C A L E O N L Y 500-0-500 Volts 600-0-600 Volts 750-0-750 Volts 250 105 FASF 250 105 FASJ 250 105 FASM 250 205 FASF 250 205 FASJ 250 205 FASM 254 205 FASF 254 205 FASJ 254 205 FASM .......... .......... 250 305 FASM .......... .......... 254 305 FASM .......... .......... 250 405 FASM .......... .......... 254 405 FASM .......... .......... .......... 254 200 EAEA 254 200 EMEM 250 300 CFCF 250 300 CYCY 250 300 DRDR 250 300 EAEA 250 300 EMEM .......... .......... .......... 254 300 EAEA 254 300 EMEM .......... 250 400 CYCY 250 400 DRDR 250 400 EAEA 250 400 EMEM .......... .......... .......... 254 400 EAEA 254 400 EMEM .......... .......... 254 201 DRDR 254 201 EAEA 254 201 EMEM 250 301 CFCF 250 301 CYCY 250 301 DRDR 250 301 EAEA 250 301 EMEM .......... .......... 254 301 DRDR 254 301 EAEA 254 301 EMEM .......... 250 401 CYCY 250 401 DRDR 250 401 EAEA 250 401 EMEM .......... .......... 254 401 DRDR 254 401 EAEA 254 401 EMEM DC Ammeters DC MICROAMMETERS — ZERO-LEFT 20 µA 50 µA 100 µA 200 µA 500 µA 250 100 CFCF 250 100 CYCY 250 100 DRDR 250 100 EAEA 250 100 EMEM 250 200 CFCF 250 200 CYCY 250 200 DRDR 250 200 EAEA 250 200 EMEM DC MICROAMMETERS — ZERO-CENTER 20-0-20 µA 50-0-50 µA 100-0-100 µA 200-0-200 µA 500-0-500 µA 250 101 CFCF 250 101 CYCY 250 101 DRDR 250 101 EAEA 250 101 EMEM 250 201 CFCF 250 201 CYCY 250 201 DRDR 250 201 EAEA 250 201 EMEM DC MICROAMMETERS — ZERO-LEFT 1 mA 5 mA 10 mA 250 100 FAFA 250 100 FXFX 250 100 GZGZ 250 200 FAFA 250 200 FXFZ 250 200 GZGZ 254 200 FAFA 254 200 FXFX 254 200 GZGZ 250 300 FAFA 250 300 FXFX 250 300 GZGZ 254 300 FAFA 254 300 FXFX 254 300 GZGZ 250 400 FAFA 250 400 FXFX 250 400 GZGZ 254 400 FAFA 254 400 FXFX 254 400 GZGZ 20 mA 25 mA 30 mA 50 mA 80 mA 250 100 HFHF 250 100 HJHJ 250 100 HMHM 250 100 HYHY 250 100 JJJJ 250 200 HFHF 250 200 HJHJ 250 200 HMHM 250 200 HYHY 250 200 JJJJ 254 200 HFHF 254 200 HJHJ 254 200 HMHM 254 200 HYHY 254 200 JJJJ 250 300 HFHF 250 300 HJHJ 250 300 HMHM 250 300 HYHY 250 300 JJJJ 254 300 HFHF 254 300 HJHJ 254 300 HMHM 254 300 HYHY 254 300 JJJJ 250 400 HFHF 250 400 HJHJ 250 400 HMHM 250 400 HYHY 250 400 JJJJ 254 400 HFHF 254 400 HJHJ 254 400 HMHM 254 400 HYHY 254 400 JJJJ 100 mA 150 mA 200 mA 250 mA 300 mA 250 100 JRJR 250 100 JXJX 250 100 KAKA 250 100 KDKD 250 100 KGKG 250 200 JRJR 254 200 JXJX 250 200 KAKA 250 200 KDKD 250 200 KGKG 254 200 JRJR 254 200 JXJX 254 200 KAKA 254 200 KDKD 254 200 KGKG 250 300 JRJR 250 300 JXJX 250 300 KAKA 250 300 KDKD 250 300 KGKG 254 300 JRJR 254 300 JXJX 254 300 KAKA 254 300 KDKD 254 300 KGKG 250 400 JRJR 250 400 JXJX 250 400 KAKA 250 400 KDKD 250 400 KGKG 254 400 JRJR 254 400 JXJX 254 400 KAKA 254 400 KDKD 254 400 KGKG 500 mA 800 mA 250 100 KMKM 250 100 KWKW 250 200 KMKM 250 200 KWKW 254 200 KMKM 254 200 KWKW 250 300 KMKM 250 300 KWKW 254 300 KMKM 254 300 KWKW 250 400 KMKM 250 400 KWKW 254 400 KMKM 254 400 KWKW 3 New Big Look DC Ammeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band Pivot and Jewel DC MILLIAMMETERS — ZERO-CENTER 1-0-1 mA 5-0-5 mA 10-0-10 mA 20-0-20 mA 250 101 FAFA 250 101 FXFX 250 101 GZGZ 250 101 HFHF 250 201 FAFA 250 201 FXFX 250 201 GZGZ 250 201 HFHF 254 201 FAFA 254 201 FXFX 254 201 GZGZ 254 201 HFHF 250 301 FAFA 250 301 FXFGX 250 301 GZGZ 250 301 HFHF 254 301 FAFA 254 301 FXFX 254 301 GZGZ 254 301 HFHF 250 401 FAFA 250 401 FXFX 250 401 GZGZ 250 401 HFHF 254 401 FAFA 254 401 FXFX 254 401 GZGZ 254 401 HFHF 25-0-25 mA 30-0-30 mA 50-0-50 mA 100-0-100 mA 150-0-150 mA 250 101 HJHJ 250 101 HMHM 250 101 HYHY 250 101 JRJR 250 101 JXJX 250 201 HJHJ 250 201 HMHM 250 201 HYHY 250 201 JRJR 250 201 JXJX 254 201 HJHJ 254 201 HMHM 254 201 HYHY 254 201 JRJR 254 201 JXJX 250 301 HJHJ 250 301 HMHM 250 301 HYHY 250 301 JRJR 250 301 JXJX 254 301 HJHJ 254 301 HMHM 254 301 HYHY 254 301 JRJR 254 301 JXJX 250 401 HJHJ 250 401 HMHM 250 401 HYHY 250 401 JRJR 250 401 JXJX 254 401 HJHJ 254 401 HMHM 254 401 HYHY 254 401 JRJR 254 401 JXJX 200-0-200 mA 250-0-250 mA 300-0-300 mA 500-0-500 mA 250 101 KAKA 250 101 KDKD 250 101 KGKG 250 101 KMKM 250 201 KAKA 250 201 KDKD 250 201 KGKG 250 201 KMKM 254 201 KAKA 254 201 KDKD 254 201 KGKG 254 201 KMKM 250 301 KAKA 250 301 KDKD 250 301 KGKG 250 301 KMKM 254 301 KAKA 254 301 KDKD 254 301 KGKG 254 301 KMKM 250 401 KAKA 250 401 KDKD 250 401 KGKG 250 401 KMKM 254 401 KAKA 254 401 KDKD 254 401 KGKG 254 401 KMKM DC AMMETERS — ZERO-LEFT 1 Amp 1.5 Amp 2 Amp 3 Amp 5 Amp 10 Amp 15 Amp 20 Amp 30 Amp 50 Amp 250 100 LALA 250 100 LCLC 250 100 LELE 250 100 LJLJ 250 100 LSLS 250 200 LALA 250 200 LCLC 250 200 LELE 250 200 LJLJ 250 200 LSLS 254 200 LALA 254 200 LCLC 254 200 LELE 254 200 LJLJ 254 200 LSLS 250 300 LALA 250 300 LCLC 250 300 LELE 250 300 LJLJ 250 300 LSLS 254 300 LALA 254 300 LCLC 254 300 LELE 254 300 LJLJ 254 300 LSLS 250 400 LALA 250 400 LCLC 250 400 LELE 250 400 LJLJ 250 400 LSLS 254 400 LALA 254 400 LCLC 254 200 LELE 254 400 LJLJ 254 400 LSLS 250 100 MTMT 250 100 NDND .......... .......... .......... 250 200 MTMT 250 200 NDND 250 200 NGNG 250 200 NLNL .......... 254 200 MTMT 254 200 NDND 254 200 NGNG 254 200 NLNL .......... 250 300 MTMT 250 300 NDND 250 300 NGNG 250 300 NLNL 250 300 NTNT 254 300 MTMT 254 300 NDND 254 300 NGNG 254 300 NLNL 250 300 NTNT 250 400 MTMT 250 400 NDND 250 400 NGNG 250 400 NLNL 250 400 NTNT 254 400 MTMT 254 400 NDND 254 400 NGNG 254 400 NLNL 254 400 NTNT DC AMMETERS — ZERO-LEFT, 50 mV, SHUNT RATED (LEAD RES. RANGE: .05-.07Ω)* S C A L E O N L Y 20 Amp 30 Amp 50 Amp 75 Amp 100 Amp 250 124 ECNG 250 124 ECNL 250 124 ECNT 250 124 ECPB 250 124 ECPK 250 224 ECNG 250 224 ECNL 250 224 ECNT 250 224 ECPB 250 224 ECPK 254 224 ECNG 254 224 ECNL 254 224 ECNT 254 224 ECPB 254 224 ECPK 250 324 ECNG 250 324 ECNL 250 324 ECNT 250 324 ECPB 250 324 ECPK 254 324 ECNG 254 324 ECNL 254 324 ECNT 254 324 ECPB 254 324 ECPK 250 424 ECNG 250 424 ECNL 250 424 ECNT 250 424 ECPB 250 424 ECPK 254 424 ECNG 254 424 ECNL 254 424 ECNT 254 424 ECPB 254 424 ECPK 150 Amp 200 Amp 250 Amp 300 Amp 400 Amp 250 124 ECPZ 250 124 ECRL 250 124 ECRS 250 124 ECRX 250 124 ECSC 250 224 ECPZ 250 224 ECRL 250 224 ECRS 250 224 ECRX 250 224 ECSC 254 224 ECPZ 254 224 ECRL 254 224 ECRS 254 224 ECRX 254 224 ECSC 250 324 ECPZ 250 324 ECRL 250 324 ECRS 250 324 ECRX 250 324 ECSC 254 324 ECPZ 254 324 ECRL 254 324 ECRS 254 324 ECRX 254 324 ECSC 250 424 ECPZ 250 424 ECRL 250 424 ECRS 250 424 ECRX 250 424 ECSC 254 424 ECPZ 254 424 ECRL 254 424 ECRS 254 424 ECRX 254 424 ECSC 500 Amp 600 Amp 800 Amp 250 124 ECSF 250 124 ECSJ 250 124 ECSN 250 224 ECSF 250 224 ECSJ 250 224 ECSN 254 224 ECSF 254 224 ECSJ 254 224 ECSN 250 324 ECSF 250 324 ECSJ 250 324 ECSN 254 324 ECSF 254 324 ECSJ 254 324 ECSN 250 424 ECSF 250 424 ECSJ 250 424 ECSN 254 424 ECSF 254 424 ECSJ 254 424 ECSN 250 124 ECVA 250 124 ECVC 250 124 ECVE 250 224 ECVA 250 224 ECVC 250 224 ECVE 254 224 ECVA 254 224 ECVC 254 224 ECVE 250 324 ECVA 250 324 ECVC 250 324 ECVE 254 324 ECVA 254 324 ECVC 254 324 ECVE 250 424 ECVA 250 424 ECVC 250 424 ECVE 254 424 ECVA 254 424 ECVC 254 424 ECVE 1 Kiloamp 1.5 Kiloamp 2 Kiloamp DC AMMETERS — ZERO-LEFT, 100 mV, SHUNT RATED (LEAD RES. RANGE: .04-.08Ω)* S C A L E O N L Y 20 Amp 40 Amp 50 Amp 75 Amp 100 Amp 250 124 GBNG 250 124 GBNP 250 124 GBNT 250 124 GBPB 250 124 GBPK 250 224 GBNG 250 224 GBNP 250 224 GBNT 250 224 GBPB 250 224 GBPK 254 224 GBNG 254 224 GBNP 254 224 GBNT 254 224 GBPB 254 224 GBPK 250 324 GBNG 250 324 GBNP 250 324 GBNT 250 324 GBPB 250 324 GBPK 254 324 GBNG 254 324 GBNP 254 324 GBNT 254 324 GBPB 254 324 GBPK 250 424 GBNG 250 424 GBNP 250 424 GBNT 250 424 GBPB 250 424 GBPK 254 424 GBNG 254 424 GBNP 254 424 GBNT 254 424 GBPB 254 424 GBPK 150 Amp 200 Amp 250 Amp 300 Amp 400 Amp 250 124 GBPZ 250 124 GBRL 250 124 GBRS 250 124 GBRX 250 124 GBSC 250 224 GBPZ 250 224 GBRL 250 224 GBRS 250 224 GBRX 250 224 GBSC 254 224 GBPZ 254 224 GBRL 254 224 GBRS 254 224 GBRX 254 224 GBSC 250 324 GBPZ 250 324 GBRL 250 324 GBRS 250 324 GBRX 250 324 GBSC 254 324 GBPZ 254 324 GBRL 254 324 GBRS 254 324 GBRX 254 324 GBSC 250 424 GBPZ 250 424 GBRL 250 424 GBRS 250 424 GBRX 250 424 GBSC 254 424 GBPZ 254 424 GBRL 254 424 GBRS 254 424 GBRX 254 424 GBSC 500 Amp 600 Amp 800 Amp 1Kiloamp 2 Kiloamp 250 124 GBSF 250 124 GBSJ 250 124 GBSN 250 124 GBVA 250 124 GBVE 250 224 GBSF 250 224 GBSJ 250 224 GBSN 250 224 GBVA 250 224 GBVE 254 224 GBSF 254 224 GBSJ 254 224 GBSN 254 224 GBVA 254 224 GBVE 250 324 GBSF 250 324 GBSJ 250 324 GBSN 250 324 GBVA 250 324 GBVE 254 324 GBSF 254 324 GBSJ 254 324 GBSN 254 324 GBVA 254 324 GBVE 250 424 GBSF 250 424 GBSJ 250 424 GBSN 250 424 GBVA 250 424 GBVE 254 424 GBSF 254 424 GBSJ 254 424 GBSN 254 424 GBVA 254 424 GBVE *Shunts are not included: For 50mV shunts, see page 29 4 DC Ammeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band Pivot and Jewel DC AMMETERS — ZERO-CENTER 1-0-1 Amp 2-0-2 Amp 5-0-5 Amp 10-0-10 Amp 15-0-15 Amp 250 101 LALA 250 101 LELE 250 101 LSLS 250 101 MTMT .......... 250 201 LALA 250 201 LELE 250 201 LSLS 250 201 MTMT 250 201 NDND 254 201 LALA 254 201 LELE 254 201 LSLS 254 201 MTMT 254 201 NDND 250 301 LALA 250 301 LELE 250 301 LSLS 250 301 MTMT 250 301 NDND 254 301 LALA 254 301 LELE 254 301 LSLS 254 301 MTMT 254 301 NDND 250 401 LALA 250 401 LELE 250 401 LSLS 250 401 MTMT 250 401 NDND 254 401 LALA 254 401 LELE 254 401 LSLS 254 401 MTMT 254 401 NDND 20-0-20 Amp 30-0-30 Amp 50-0-50 Amp .......... .......... .......... 250 201 NGNG 250 201 NLNL .......... 254 201 NGNG 254 201 NLNL .......... 250 301 NGNG 250 301 NLNL 250 301 NTNT 254 301 NGNG 254 301 NLNL 254 301 NTNT 250 401 NGNG 250 401 NLNL 250 401 NTNT 254 401 NGNG 254 401 NLNL 254 401 NTNT DC AMMETERS — ZERO-CENTER, 50 mV, SHUNT RATED (LEAD RES. RANGE: .05-.07Ω)* S C A L E O N L Y 20-0-20 Amp 40-0-40 Amp 50-0-50 Amp 75-0-75 Amp 100-0-100 Amp 250 125 ECNG 250 125 ECNP 250 125 ECNT 250 125 ECPB 250 125 ECPK 250 225 ECNG 250 225 ECNP 250 225 ECNT 250 225 ECPB 250 225 ECPK .......... 254 225 ECNP 254 225 ECNT 254 225 ECPB 254 225 ECPK 250 325 ECNG 250 325 ECNP 250 325 ECNT 250 325 ECPB 250 325 ECPK .......... 254 325 ECNP 254 325 ECNT 254 325 ECPB 254 325 ECPK .......... 250 425 ECNP 250 425 ECNT 250 425 ECPB 250 425 ECPK .......... 254 425 ECNP 254 425 ECNT 254 425 ECPB 254 425 ECPK *Shunts are not included: For 50mV shunts, see page 29 AC Voltmeters 11⁄2 Size Rating & Scale Type 21⁄2 31⁄2 41⁄2 200 Series 200 Series 200 Series AC VOLTMETERS — SELF-CONTAINED, IRON VANE TYPE, PIVOT AND JEWEL 60 Hz 3 Volts 5 Volts 10 Volts 15 Volts 30 Volts .......... .......... .......... .......... .......... 250 244 LJLJ 250 244 LSLS 250 244 MTMT 250 244 NDND 250 244 NLNL 250 344 LJLJ 250 344 LSLS 250 344 MTMT 250 344 NDND 250 344 NLNL 250 444 LJLJ 250 444 LSLS 250 444 MTMT 250 444 NDND 250 444 NLNL 50 Volts 100 Volts 150 Volts 300 Volts 500 Volts 600 Volts .......... .......... .......... .......... .......... .......... 250 244 NTNT 250 244 PKPK 250 244 PZPZ 250 244 RXRX .......... .......... 250 344 NTNT 250 344 PKPK 250 344 PZPZ 250 344 RXRX 250 344 SFSF 250 344 SJSJ 250 444 NTNT 250 444 PKPK 250 444 PZPZ 250 444 RXRX 250 444 SFSF 250 444 SJSJ AC VOLTMETERS — SELF-CONTAINED, IRON VANE TYPE, PIVOT AND JEWEL 400 Hz 150 Volts 300 Volts .......... .......... 250 245 PZPZ 250 245 RXRX 250 345 PZPZ 250 345 RXRX 250 445 PZPZ 250 445 RXRX AC VOLTMETERS — TRANSFORMER RATED, 0-150 VOLTS, PIVOT AND JEWEL, IRON VANE TYPE, 60 Hz. (See page 29 for Transformers) S C A L E O N L Y 600 Volts 750 Volts 3 kV .......... .......... .......... 250 244 PZSJ 250 244 PZSM 250 244 PZVJ 250 344 PZSJ 250 344 PZSM 250 344 PZVJ 250 444 PZSJ 250 444 PZSM 250 444 PZVJ AC VOLTMETERS — EXPANDED SCALE, RECTIFIER TYPE 11⁄2 Size Rating & Scale Type 110-130 Volts 105-125 Volts Taut Band .......... .......... 21⁄2 Taut Band .......... .......... 31⁄2 Pivot and Jewel .......... .......... 41⁄2 Taut Band Pivot and Jewel Taut Band 250 337 PNPN 250 337 PTPT 254 337 PNPN 254 337 PTPT 250 437 PNPN 250 437 PTPT Pivot and Jewel 254 437 PNPN 254 437 PTPT 5 New Big Look AC Voltmeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 Pivot and Jewel Taut Band 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel AC VOLTMETERS — SELF-CONTAINED, RECTIFIER TYPE 10 Volts 15 Volts 20 Volts 25 Volts 30 Volts 250 130 MTMT 250 130 NDND 250 130 NGNG 250 130 NJNJ 250 130 NLNL 250 230 MTMT 250 230 NDND 250 230 NGNG 250 230 NJNJ 250 230 NLNL 254 230 MTMT 254 230 NDND 254 230 NGNG 254 230 NJNJ 254 230 NLNL 250 330 MTMT 250 330 NDND 250 330 NGNG 250 330 NJNJ 250 330 NLNL 254 330 MTMT 254 330 NDND 254 330 NGNG 254 330 NJNJ 254 330 NLNL 250 430 MTMT 250 430 NDND 250 430 NGNG 250 430 NJNJ 250 430 NLNL 254 430 MTMT 254 430 NDND 254 430 NGNG 254 430 NJNJ 254 430 NLNL 50 Volts 80 Volts 100 Volts 150 Volts 200 Volts 250 130 NTNT 250 130 PDPD 250 130 PKPK 250 130 PZPZ .......... 250 230 NTNT 250 230 PDPD 250 230 PKPK 250 230 PZPZ .......... 254 230 NTNT 254 230 PDPD 254 230 PKPK 254 230 PZPZ .......... 250 330 NTNT 250 330 PDPD 250 330 PKPK 250 330 PZPZ 250 330 RLRL 254 330 NTNT 254 330 PDPD 254 330 PKPK 254 330 PZPZ 254 330 RLRL 250 430 NTNT 250 430 PDPD 250 430 PKPK 250 430 PZPZ 250 430 RLRL 254 430 NTNT 254 430 PDPD 254 430 PKPK 254 430 PZPZ 254 430 RLRL 250 Volts 300 Volts .......... .......... .......... .......... .......... .......... 250 330 RSRS 250 330 RXRX 254 330 RSRS 254 330 RXRX 250 430 RSRS 250 430 RXRX 254 430 RSRS 254 430 RXRX AC Ammeters AC MICROAMMETERS AND MILLIAMMETERS — RECTIFIER TYPE 500 µA 800 µA 1 mA 1.5 mA 2 mA 250 110 EMEM 250 110 EWEW 250 110 FAFA 250 110 FDFD 250 110 FGFG 250 210 EMEM 250 210 EWEW 250 210 FAFA 250 210 FDFD 250 210 FGFG 254 210 EMEM 254 210 EWEW 254 210 FAFA 254 210 FDFD 254 210 FGFG 250 310 EMEM 250 310 EWEW 250 310 FAFA 250 310 FDFD 250 310 FGFG 254 310 EMEM 254 310 EWEW 254 310 FAFA 254 310 FDFD 254 310 FGFG 250 410 EMEM 250 410 EWEW 250 410 FAFA 250 410 FDFD 250 410 FGFG 254 410 EMEM 254 410 EWEW 254 410 FAFA 254 410 FDFD 254 410 FGFG 3 mA 5 mA 10 mA 20 mA 250 110 FNFN 250 110 FXFX 250 110 GZGZ 250 110 HFHF 250 210 FNFN 250 210 FXFX 250 210 GZGZ 250 210 HFHF 254 210 FNFN 254 210 FXFX 254 210 GZGZ 254 210 HFHF 250 310 FNFN 250 310 FXFX 250 310 GZGZ 250 310 HFHF 254 310 FNFN 254 310 FXFX 254 310 GZGZ 254 310 HFHF 250 410 FNFN 250 410 FXFX 250 410 GZGZ 250 410 HFHF 254 410 FNFN 254 410 FXFX 254 410 GZGZ 254 410 HFHF 11⁄2 Size Rating & Scale Type 21⁄2 31⁄2 41⁄2 200 Series 200 Series 200 Series AC MILLIAMMETERS — SELF-CONTAINED, 25-400 Hz, IRON VANE, PIVIT AND JEWEL 10 mA 25 mA 50 mA 100 mA 200 mA .......... .......... .......... .......... .......... 250 240 GZGZ 250 240 HJHJ 250 240 HYHY 250 240 JRJR 250 240 KAKA 250 340 GZGZ 250 340 HJHJ 250 340 HYHY 250 340 JRJR 250 340 KAKA 250 440 GZGZ 250 440 HJHJ 250 440 HYHY 250 440 JRJR 250 440 KAKA 500 mA .......... 250 240 KMKM 250 340 KMKM 250 440 KMKM AC AMMETERS — SELF-CONTAINED, 25-400 Hz, IRON VANE, PIVOT AND JEWEL 1 Amp 3 Amp 5 Amp 8 Amp 10 Amp .......... .......... .......... .......... .......... 250 240 LALA 250 240 LJLJ 250 240LSLS 250 240 MJMJ 250 240 MTMT 250 340 LALA 250 340 LJLJ 250 340 LSLS 250 340 MJMJ 250 340 MTMT 250 440 LALA 250 440 LJLJ 250 440 LSLS 250 440 MJMJ 250 440 MTMT 15 Amp 20 Amp 30 Amp 50 Amp 80 Amp .......... .......... .......... .......... .......... 250 240 NDND 250 240 NGNG* 250 240 NLNL* .......... .......... 250 340 NDND 250 340 NGNG* 250 340 NLNL* 250 340 NTNT* 250 340 PDPD* 250 440 NDND 250 440 NGNG* 250 440 NLNL* 250 440 NTNT* 250 440 PDPD* * External Magnetic shield included 6 AC Ammeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 31⁄2 41⁄2 200 Series 200 Series 200 Series AC AMMETERS — TRANSFORMER-RATED, 0-5 AMPERES, 25-500 Hz, PIVOT AND JEWEL, IRON VANE (See page 29 for Transformers) S C A L E O N L Y 10 Amp 15 Amp 20 Amp 30 Amp 40 Amp .......... .......... .......... .......... .......... 250 240 LSMT 250 240 LSND 250 240 LSNG 250 240 LSNL 250 240 LSNP 250 340 LSMT 250 340 LSND 250 340 LSNG 250 340 LSNL 250 340 LSNP 250 440 LSMT 250 440 LSND 250 440 LSNG 250 440 LSNL 250 440 LSNP 50 Amp 75 Amp 80 Amp 100 Amp 150 Amp .......... .......... .......... .......... .......... 250 240 LSNT 250 240 LSPB 250 240 LSPD 250 240 LSPK 250 240 LSPZ 250 340 LSNT 250 340 LSPB 250 340 LSPD 250 340 LSPK 250 340 LSPZ 250 440 LSNT 250 440 LSPB 250 440 LSPD 250 440 LSPK 250 440 LSPZ 200 Amp 300 Amp 400 Amp 500 Amp 600 Amp 800 Amp .......... .......... .......... .......... .......... .......... 250 240 LSRL 250 240 LSRX 250 240 LSSC 250 240 LSSF 250 240 LSSJ 250 240 LSSN 250 340 LSRL 250 340 LSRX 250 340 LSSC 250 340 LSSF 250 340 LSSJ 250 340 LSSN 250 440 LSRL 250 440 LSRX 250 440 LSSC 250 440 LSSF 250 440 LSSJ 250 440 LSSN .......... .......... .......... .......... .......... 250 240 LSVA 250 240 LSVB 250 240 LSVC 250 240 LSVE 250 240 LSVJ 250 340 LSVA 250 340 LSVB 250 340 LSVC 250 340 LSVE 250 340 LSVJ 250 440 LSVA 250 440 LSVB 250 440 LSVC 250 440 LSVE 250 440 LSVJ 1 Kiloamp 1.2 Kiloamp 1.5 Kiloamp 2.0 Kiloamp 3.0 Kiloamp Horizon Line ANSI Specification: All meters meet ANSI Specifications C-39.1. Overload: Voltmeters (AC and DC) - 50% momentary, 20% sustained. Ammeters (AC and DC) momentary: 10 times the rated current for 10 consecutive intervals of .5 second with a 1 minute interval between successive applications; sustained: 20% for six hours. Type 251 and 255 Horizon Line Specifications Accuracy: All DC and AC iron-vane; ±2% of full-scale, AC rectifier type; ±3% of full scale (with 60 Hz sine wave at 25º C). When standard 60 Hz iron vane ammeters are used at the extreme limits of 20 or 400 Hz, additional error (approx. .75%) may be experienced. Expanded-scale voltmeters; ±.5% of full scale value. Scale Data: 90 degree rotation. Scale Length: Size 11⁄2” 21⁄2” 31⁄2” 41⁄2” Horizon Line 1.50” 2.06” 2.88” 3.93” Insulation Level: All meters (except 11⁄2”), 2600 VRMS Hi-pot, 11⁄2”-1500 VRMS Hi-pot. Burden Data: AC ammeter-5 amps, 0.5 va max. 0.5 power-factor lagging, @60 Hz. AC Voltmeter-unity power factor. Response Time and Overshoot: Response time: 3 seconds (max.) for 21⁄2”, 31⁄2”, 41⁄2” size for microammeters: 2 seconds (max.) for all other DC ratings, and 2.5 seconds (max.) for AC ratings. Maximum of 40% overshoot. Dimensions: See page 34-35. How To Order To Order Horizon Line panel meters use the appropriate catalog numbers provided in the tables. Taut band instruments have a 251 prefix number, Pivot & jewel instruments have a 255 prefix number, except AC Iron Vane prefix which is 251. Ordering Examples: 1. 21⁄2”, 300 V DC Voltmeter, zero left, taut band - 251 220 RXRX 2. 21⁄2”, 300 V DC Voltmeter, zero left, pivot & jewel - 255 220 RXRX 3. 21⁄2”, 300 VAC (Iron Vane) pivot & jewel 251 244 RXRX Severe-duty meters are available to meet UL 1437 requirements. UL/CSA version, with flame retardant window and base, is not offered in 11⁄2”. To order, add /UL or /CSA after catalog number, or contact factory. For ratings and scales not listed contact factory. 7 Horizon Line DC Voltmeters 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band Pivot and Jewel DC VOLTMETERS - ZERO-LEFT 1.0 Volts 1.5 Volts 3 Volts 5 Volts 8 Volts 251 120 LALA 251 120 LCLC 251 120 LJLJ 251 120 LSLS 251 120 MJMJ 251 220 LALA 251 220 LCLC 251 220 LJLJ 251 220 LSLS 251 220 MJMJ 255 220 LALA 255 220 LCLC 255 220 LJLJ 255 220 LSLS 255 220 MJMJ 251 320 LALA 251 320 LCLC 251 320 LJLJ 251 320 LSLS 251 320 MJMJ 255 320 LALA 255 320 LCLC 255 320 LJLJ 255 320 LSLS 255 320 MJMJ 251 420 LALA 251 420 LCLC 251 420 LJLJ 251 420 LSLS 251 420 MJMJ 255 420 LALA 255 420 LCLC 255 420 LJLJ 255 420 LSLS 255 420 MJMJ 10 Volts 15 Volts 30 Volts 40 Volts 50 Volts 251 120 MTMT 251 120 NDND 251 120 NLNL 251 120 NPNP 251 120 NTNT 251 220 MTMT 251 220 NDND 251 220 NLNL 251 220 NPNP 251 220 NTNT 255 220 MTMT 255 220 NDND 255 220 NLNL 255 220 NPNP 255 220 NTNT 251 320 MTMT 251 320 NDND 251 320 NLNL 251 320 NPNP 251 320 NTNT 255 320 MTMT 255 320 NDND 255 320 NLNL 255 320 NPNP 255 320 NTNT 251 420 MTMT 251 420 NDND 251 420 NLNL 251 420 NPNP 251 420 NTNT 255 420 MTMT 255 420 NDND 255 420 NLNL 255 420 NPNP 255 420 NTNT 80 Volts 100 Volts 150 Volts 200 Volts 250 Volts 251 120 PDPD 251 120 PKPK 251 120 PZPZ 251 120 RLRL 251 120 RSRS 251 220 PDPD 251 220 PKPK 251 220 PZPZ 251 220 RLRL 251 220 RSRS 255 220 PDPD 255 220 PKPK 255 220 PZPZ 255 220 RLRL 255 220 RSRS 251 320 PDPD 251 320 PKPK 251 320 PZPZ 251 320 RLRL 251 320 RSRS 255 320 PDPD 255 320 PKPK 255 320 PZPZ 255 320 RLRL 255 320 RSRS 251 420 PDPD 251 420 PKPK 251 420 PZPZ 251 420 RLRL 251 420 RSRS 255 420 PDPD 255 420 PKPK 255 420 PZPZ 255 420 RLRL 255 420 RSRS 300 Volts 500 Volts 600 Volts 251 120 RXRX .......... .......... 251 220 RXRX .......... .......... 255 220 RXRX .......... .......... 251 320 RXRX 251 320 SFSF 251 320 SJSJ 255 320 RXRX 255 320 SFSF 255 320 SJSJ 251 420 RXRX 251 420 SFSF 251 420 SJSJ 255 420 RXRX 255 420 SFSF 255 420 SJSJ DC VOLTMETERS — ZERO-LEFT, RATED 0-1 mA DC, FOR USE WITH EXTERNAL RESISTORS, RESISTORS NOT INCLUDED (SEE PAGE 29 FOR RESISTORS) S C A L E O N L Y 500 Volts 600 Volts 750 Volts 251 104 FASF 251 104 FASJ 251 104 FASM 251 204 FASF 251 204 FASJ 251 204 FASM 255 204 FASF 255 204 FASJ 255 204 FASM .......... .......... 251 304 FASM .......... .......... 255 304 FASM .......... .......... 251 404 FASM .......... .......... 255 404 FASM DC VOLTMETERS — ZERO-CENTER 5-0-5 Volts 10-0-10 Volts 30-0-30 Volts 50-0-50 Volts 80-0-80 Volts 251 121 LSLS 251 121 MTMT 251 121 NLNL 251 121 NTNT 251 121 PDPD 251 221 LSLS 251 221 MTMT 251 221 NLNL 251 221 NTNT 251 221 PDPD 255 221 LSLS 255 221 MTMT 255 221 NLNL 255 221 NTNT 255 221 PDPD 251 321 LSLS 251 321 MTMT 251 321 NLNL 251 321 NTNT 251 321 PDPD 255 321 LSLS 255 321 MTMT 255 321 NLNL 255 321 NTNT 255 321 PDPD 251 421 LSLS 251 421 MTMT 251 421 NLNL 251 421 NTNT 251 421 PDPD 255 421 LSLS 255 421 MTMT 255 421 NLNL 255 421 NTNT 255 421 PDPD 150-0-150 Volts 300-0-300 Volts 500-0-500 Volts 600-0-600 Volts 251 121 PZPZ 251 121 RXRX .......... .......... 251 221 PZPZ 251 221 RXRX .......... .......... 255 221 PZPZ 255 221 RXRX .......... .......... 251 321 PZPZ 251 321 RXRX 251 321 SFSF 251 321 SJSJ 255 321 PZPZ 255 321 RXRX 255 321 SFSF 255 321 SJSJ 251 421 PZPZ 251 421 RXRX 251 421 SFSF 251 421 SJSJ 255 421 PZPZ 255 421 RXRX 255 421 SFSF 255 421 SJSJ DC VOLTMETERS — ZERO-CENTER, RATED 1-0-1 mA, DC, FOR USE WITH EXTERNAL RESISTORS, RESISTORS NOT INCLUDED (SEE PAGE 29 FOR RESISTORS) S C A L E O N L Y 500-0-500 Volts 600-0-600 Volts 750-0-750 Volts 251 105 FASF 251 105 FASJ 251 105 FASM 251 205 FASF 251 205 FASJ 251 205 FASM 255 205 FASF 255 205 FASJ 255 205 FASM .......... .......... 251 305 FASM .......... .......... 255 305 FASM .......... .......... 251 405 FASM .......... .......... 255 405 FASM 255 338 NNNN 255 338 PNPN 255 338 RTRT 251 438 NNNN 251 438 PNPN 251 438 RTRT 255 438 NNNN 255 438 PNPN 255 438 RTRT DC VOLTMETERS — EXPANDED SCALE; ZENER DIODE TYPE 24-30 Volts 110-130 Volts 220-260 Volts .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 338 NNNN 251 338 PNPN 251 338 RTRT DC Ammeters 11⁄2 Size Rating & Scale Type Taut Band 21⁄2 Taut Band 31⁄2 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel Taut Band .......... .......... .......... 255 200 EAEA 255 200 EMEM 251 300 CFCF 251 300 CYCY 251 300 DRDR 251 300 EAEA 251 300 EMEM .......... .......... .......... 255 300 EAEA 255 300 EMEM .......... 251 400 CYCY 251 400 DRDR 251 400 EAEA 251 400 EMEM Pivot and Jewel DC MICROAMMETERS — ZERO-LEFT 8 20 µA 50 µA 100 µA 200 µA 500 µA 251 100 CFCF 251 100 CYCY 251 100 DRDR 251 100 EAEA 251 100 EMEM 251 200 CFCF 251 200 CYCY 251 200 DRDR 251 200 EAEA 251 200 EMEM .......... .......... .......... 255 400 EAEA 255 400 EMEM DC Ammeters Cont’d 11⁄2 Size Rating & Scale Type Taut Band 21⁄2 Taut Band 31⁄2 Pivot and Jewel 41⁄2 Taut Band Pivot and Jewel Taut Band Pivot and Jewel .......... .......... 255 201 DRDR 255 201 EAEA 255 201 EMEM 251 301 CFCF 251 301 CYCY 251 301 DRDR 251 301 EAEA 251 301 EMEM .......... .......... 255 301 DRDR 255 301 EAEA 255 301 EMEM .......... 251 401 CYCY 251 401 DRDR 251 401 EAEA 251 401 EMEM .......... .......... 255 401 DRDR 255 401 EAEA 255 401 EMEM DC MICROAMMETERS — ZERO-CENTER 20-0-20 µA 50-0-50 µA 100-0-100 µA 200-0-200 µA 500-0-500 µA 251 101 CFCF 251 101 CYCY 251 101 DRDR 251 101 EAEA 251 101 EMEM 251 201 CFCF 251 201 CYCY 251 201 DRDR 251 201 EAEA 251 201 EMEM DC MILLIAMMETERS — ZERO-LEFT 1 mA 251 100 FAFA 251 200 FAFA 255 200 FAFA 251 300 FAFA 255 300 FAFA 251 400 FAFA 255 400 FAFA 5 mA 10 mA 251 100 FXFX 251 100 GZGZ 251 200 FXFX 251 200 GZGZ 255 200 FXFX 255 200 GZGZ 251 300 FXFX 251 300 GZGZ 255 300 FXFX 255 300 GZGZ 251 400 FXFX 251 400 GZGZ 255 400 FXFX 255 400 GZGZ 20 mA 25 mA 30 mA 50 mA 80 mA 251 100 HFHF 251 100 HJHJ 251 100 HMHM 251 100 HYHY 251 100 JJJJ 251 200 HFHF 251 200 HJHJ 251 200 HMHM 251 200 HYHY 251 200 JJJJ 255 200 HFHF 255 200 HJHJ 255 200 HMHM 255 200 HYHY 255 200 JJJJ 251 300 HFHF 251 300 HJHJ 251 300 HMHM 251 300 HYHY 251 300 JJJJ 255 300 HFHF 255 300 HJHJ 255 300 HMHM 255 300 HYHY 255 300 JJJJ 251 400 HFHF 251 400 HJHJ 251 400 HMHM 251 400 HYHY 251 400 JJJJ 255 400 HFHF 255 400 HJHJ 255 400 HMHM 255 400 HYHY 255 400 JJJJ 100 mA 150 mA 200 mA 250 mA 300 mA 251 100 JRJR 251 100 JXJX 251 100 KAKA 251 100 KDKD 251 100 KGKG 251 200 JRJR 251 200 JXJX 251 200 KAKA 251 200 KDKD 251 200 KGKG 255 200 JRJR 255 200 JXJX 255 200 KAKA 255 200 KDKD 255 200 KGKG 251 300 JRJR 251 300 JXJX 251 300 KAKA 251 300 KDKD 251 300 KGKG 255 300 JRJR 255 300 JXJX 255 300 KAKA 255 300 KDKD 255 300 KGKG 251 400 JRJR 251 400 JXJX 251 400 KAKA 251 400 KDKD 251 400 KGKG 255 400 JRJR 255 400 JXJX 255 400 KAKA 255 400 KDKD 255 400 KGKG 500 mA 800 mA 251 100 KMKM 251 100 KWKW 251 200 KMKM 251 200 KWKW 255 200 KMKM 255 200 KWKW 251 300 KMKM 251 300 KWKW 255 300 KMKM 255 300 KWKW 251 400 KMKM 251 400 KWKW 255 400 KMKM 255 400 KWKW DC MILLIAMMETERS — ZERO-CENTER 1-0-1 mA 251 101 FAFA 251 201 FAFA 255 201 FAFA 251 301 FAFA 255 301 FAFA 251 401 FAFA 255 401 FAFA 5-0-5 10-0-10 20-0-20 mA mA mA 251 101 FXFX 251 101 GZGZ 251 101 HFHF 251 201 FXFX 251 201 GZGZ 251 201 HFHF 255 201 FXFX 255 201 GZGZ 255 201 HFHF 251 301 FXFX 251 301 GZGZ 251 301 HFHF 255 301 FXFX 255 301 GZGZ 255 301 HFHF 251 401 FXFX 251 401 GZGZ 251 401 HFHF 255 401 FXFX 255 401 GZGZ 255 401 HFHF 25-0-25 30-0-30 50-0-50 100-0-100 150-0-150 mA mA mA mA mA 251 101 HJHJ 251 101 HMHM 251 101 HYHY 251 101 JRJR 251 101 JXJX 251 201 HJHJ 251 201 HMHM 251 201 HYHY 251 201 JRJR 251 201 JXJX 255 201 HJHJ 255 201 HMHM 255 201 HYHY 255 201 JRJR 255 201 JXJX 251 301 HJHJ 251 301 HMHM 251 301 HYHY 251 301 JRJR 251 301 JXJX 255 301 HJHJ 255 301 HMHM 255 301 HYHY 255 301 JRJR 255 301 JXJX 251 401 HJHJ 251 401 HMHM 251 401 HYHY 251 401 JRJR 251 401 JXJX 255 401 HJHJ 255 401 HMHM 255 401 HYHY 255 401 JRJR 255 401 JXJX 200-0-200 250-0-250 300-0-300 500-0-500 mA mA mA mA 251 101 KAKA 251 101 KDKD 251 101 KGKG 251 101 KMKM 251 201 KAKA 251 201 KDKD 251 201 KGKG 251 201 KMKM 255 201 KAKA 255 201 KDKD 255 201 KGKG 255 201 KMKM 251 301 KAKA 251 301 KDKD 251 301 KGKG 251 301 KMKM 255 301 KAKA 255 301 KDKD 255 301 KGKG 255 301 KMKM 251 401 KAKA 251 401 KDKD 251 401 KGKG 251 401 KMKM 255 401 KAKA 255 401 KDKD 255 401 KGKG 255 401 KMKM DC AMMETERS — ZERO-LEFT 1 Amp 1.5 Amp 2 Amp 13 Amp 5 Amp 251 100 LALA 251 100 LCLC 251 100 LELE 251 100 LJLJ 251 100 LSLS 251 200 LALA 251 200 LCLC 251 200 LELE 251 200 LJLJ 251 200 LSLS 255 200 LALA 255 200 LCLC 255 200 LELE 255 200 LJLJ 255 200 LSLS 251 300 LALA 251 300 LCLC 251 300 LELE 251 300 LJLJ 251 300 LSLS 255 300 LALA 255 300 LCLC 255 300 LELE 255 300 LJLJ 255 300 LSLS 251 400 LALA 251 400 LCLC 251 400 LELE 251 400 LJLJ 251 400 LSLS 255 400 LALA 255 400 LCLC 255 400 LELE 255 400 LJLJ 255 400 LSLS 10 Amp 15 Amp 20 Amp 30 Amp 50 Amp 251 100 MTMT .......... .......... .......... .......... 251 200 MTMT 251 200 NDND 251 200 NGNG 251 200 NLNL 251 200 NTNT 255 200 MTMT 255 200 NDND 255 200 NGNG 255 200 NLNL .......... 251 300 MTMT 251 300 NDND 251 300 NGNG 251 300 NLNL 251 300 NTNT 255 300 MTMT 255 300 NDND 255 300 NGNG 255 300 NLNL 255 300 NTNT 251 400 MTMT 251 400 NDND 251 400 NGNG 251 400 NLNL 251 400 NTNT 255 400 MTMT 255 400 NDND 255 400 NGNG 255 400 NLNL 255 400 NTNT DC AMMETERS — ZERO-LEFT, 50 mV, SHUNT RATED (LEAD RES. RANGE: .05-.07Ω)* S C A L E O N L Y 20 Amp 30 Amp 50 Amp 75 Amp 100 Amp 251 124 ECNG 251 124 ECNL 251 124 ECNT 251 124 ECPB 251 124 ECPK 251 224 ECNG 251 224 ECNL 251 224 ECNT 251 224 ECPB 251 224 ECPK 255 224 ECNG 255 224 ECNL 255 224 ECNT 255 224 ECPB 255 224 ECPK 251 324 ECNG 251 324 ECNL 251 324 ECNT 251 324 ECPB 251 324 ECPK 255 324 ECNG 255 324 ECNL 255 324 ECNT 255 324 ECPB 255 324 ECPK 251 424 ECNG 251 424 ECNL 251 424 ECNT 251 424 ECPB 251 424 ECPK 255 424 ECNG 255 424 ECNL 255 424 ECNT 255 424 ECPB 255 424 ECPK 150 Amp 200 Amp 250Amp 300 Amp 400 Amp 251 124 ECPZ 251 124 ECRL 251 124 ECRS 251 124 ECRX 251 124 ECSC 251 224 ECPZ 251 224 ECRL 251 224 ECRS 251 224 ECRX 251 224 ECSC 255 224 ECPZ 255 224 ECRL 255 224 ECRS 255 224 ECRX 255 224 ECSC 251 324 ECPZ 251 324 ECRL 251 324 ECRS 251 324 ECRX 251 324 ECSC 255 324 ECPZ 255 324 ECRL 255 324 ECRS 255 324 ECRX 255 324 ECSC 251 424 ECPZ 251 424 ECRL 251 424 ECRS 251 424 ECRX 251 424 ECSC 255 424 ECPZ 255 424 ECRL 255 424 ECRS 255 424 ECRX 255 424 ECSC 9 Horizon Line DC Ammeters Cont’d 11⁄2 Size Type Rating & Scale 21⁄2 Taut Band Taut Band 31⁄2 Pivot and Jewel Taut Band 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel DC AMMETERS — ZERO-LEFT, 50mV, SHUNT RATED* - continued S C A L E O N L Y 500 Amp 600 Amp 800 Amp 1 Kilomap 1.5 Kiloamp 2 Kiloamp 251 124 ECSF 251 124 ECSJ 251 124 ECSN 251 224 ECSF 251 224 ECSJ 251 224 ECSN 255 224 ECSF 255 224 ECSJ 255 224 ECSN 251 324 ECSF 251 324 ECSJ 251 324 ECSN 255 324 ECSF 255 324 ECSJ 255 324 ECSN 251 424 ECSF 251 424 ECSJ 251 424 ECSN 255 424 ECSF 255 424 ECSJ 255 424 ECSN 251 124 ECVA 251 124 ECVC 251 124 ECVE 251 224 ECVA 251 224 ECVC 251 224 ECVE 255 224 ECVA 255 224 ECVC 255 224 ECVE 251 324 ECVA 251 324 ECVC 251 324 ECVE 255 324 ECVA 255 324 ECVC 255 324 ECVE 251 424 ECVA 251 424 ECVC 251 424 ECVE 255 424 ECVA 255 424 ECVC 255 424 ECVE DC AMMETERS — ZERO-LEFT, 100mV, SHUNT RATED (LEAD RES. RANGE: .04-.08Ω)* S C A L E O N L Y 20 Amp 40 Amp 50 Amp 75 Amp 100 Amp 251 124 GBNG 251 124 GBNP 251 124 GBNT 251 124 GBPB 251 124 GBPK 251 224 GBNG 251 224 GBNP 251 224 GBNT 251 224 GBPB 251 224 GBPK 255 224 GBNG 255 224 GBNP 255 224 GBNT 255 224 GBPB 255 224 GBPK 251 324 GBNG 251 324 GBNP 251 324 GBNT 251 324 GBPB 251 324 GBPK 255 324 GBNG 255 324 GBNP 255 324 GBNT 255 324 GBPB 255 324 GBPK 251 424 GBNG 251 424 GBNP 251 424 GBNT 251 424 GBPB 251 424 GBPK 255 424 GBNG 255 424 GBNP 255 424 GBNT 255 424 GBPB 255 424 GBPK 150 Amp 200 Amp 250 Amp 300 Amp 400 Amp 251 124 GBPZ 251 124 GBRL 251 124 GBRS 251 124 GBRX 251 124 GBSC 251 224 GBPZ 251 224 GBRL 251 224 GBRS 251 224 GBRX 251 224 GBSC 255 224 GBPZ 255 224 GBRL 255 224 GBRS 255 224 GBRX 255 224 GBSC 251 324 GBPZ 251 324 GBRL 251 324 GBRS 251 324 GBRX 251 324 GBSC 255 324 GBPZ 255 324 GBRL 255 324 GBRS 255 324 GBRX 255 324 GBSC 251 424 GBPZ 251 424 GBRL 251 424 GBRS 251 424 GBRX 251 424 GBSC 255 424 GBPZ 255 424 GBRL 255 424 GBRS 255 424 GBRX 255 424 GBSC 500 Amp 600 Amp 800 Amp 251 124 GBSF 251 124 GBSJ 251 124 GBSN 251 224 GBSF 251 224 GBSJ 251 224 GBSN 255 224 GBSF 255 224 GBSJ 255 224 GBSN 251 324 GBSF 251 324 GBSJ 251 324 GBSN 255 324 GBSF 255 324 GBSJ 255 324 GBSN 251 424 GBSF 251 424 GBSJ 251 424 GBSN 255 424 GBSF 255 424 GBSJ 255 424 GBSN 251 124 GBVA 251 124 GBVE 251 224 GBVA 251 224 GBVE 255 224 GBVA 255 224 GBVE 251 324 GBVA 251 324 GBVE 255 324 GBVA 255 324 GBVE 251 424 GBVA 251 424 GBVE 255 424 GBVA 255 424 GBVE 1 Kiloamp 2 Kiloamp DC AMMETERS — ZERO-CENTER 1-0-1 Amp 2-0-2 Amp 5-0-5Amp 10-0-10 Amp 15-0-15 Amp 251 101 LALA 251 101 LELE 251 101 LSLS 251 101 MTMT .......... 251 201 LALA 251 201 LELE 251 201 LSLS 251 201 MTMT 251 201 NDND 255 201 LALA 255 201 LELE 255 201 LSLS 255 201 MTMT 255 201 NDND 251 301 LALA 251 301 LELE 251 301 LSLS 251 301 MTMT 251 301 NDND 255 301 LALA 255 301 LELE 255 301 LSLS 255 301 MTMT 255 301 NDND 251 401 LALA 251 401 LELE 251 401 LSLS 251 401 MTMT 251 401 NDND 255 401 LALA 255 401 LELE 255 401 LSLS 255 401 MTMT 255 401 NDND 20-0-20 Amp 30-0-30 Amp 50-0-50 Amp .......... .......... .......... 251 201 NGNG 251 201 NLNL .......... 255 201 NGNG 255 201 NLNL .......... 251 301 NGNG 251 301 NLNL 251 301 NTNT 255 301 NGNG 255 301 NLNL 255 301 NTNT 251 401 NGNG 251 401 NLNL 251 401 NTNT 255 401 NGNG 255 401 NLNL 255 401 NTNT DC AMMETERS — ZERO-CENTER, 50mV, SHUNT RATED (LEAD RES. RANGE .05-.07Ω)* S C A L E O N L Y 20-0-20 Amp 40-0-40 Amp 50-0-50 Amp 75-0-75 Amp 100-0-100 Amp 251 125 ECNG 251 125 ECNP 251 125 ECNT 251 125 ECPB 251 125 ECPK 251 225 ECNG 251 225 ECNP 251 225 ECNT 251 225 ECPB 251 225 ECPK 255 225 ECNG 255 225 ECNP 255 225 ECNT 255 225 ECPB 255 225 ECPK 251 325 ECNG 251 325 ECNP 251 325 ECNT 251 325 ECPB 251 325 ECPK 255 325 ECNG 255 325 ECNP 255 325 ECNT 255 325 ECPB 255 325 ECPK .......... 251 425 ECNP 251 425 ECNT 251 425 ECPB 251 425 ECPK .......... 225 425 ECNP 225 425 ECNT 225 425 ECPB 225 425 ECPK *Shunts are not included: For 50mV shunts, see page 29 AC Voltmeters 11⁄2 Size Rating & Scale Type Taut Band 21⁄2 Taut Band 31⁄2 Pivot and Jewel Taut Band 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel AC VOLTMETERS — SELF-CONTAINED, IRON VANE TYPE, 60 Hz 10 3 Volts 5 Volts 10 Volts 15 Volts 30 Volts .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 244 LJLJ 251 244 LSLS 251 244 MTMT 251 244 NDND 251 244 NLNL .......... .......... .......... .......... .......... 251 344 LJLJ 251 344 LSLS 251 344 MTMT 251 344 NDND 251 344 NLNL .......... .......... .......... .......... .......... 251 444 LJLJ 251 444 LSLS 251 444 MTMT 251 444 NDND 251 444 NLNL 50 Volts 150 Volts 300 Volts 500 Volts 600 Volts .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 244 NTNT 251 244 PZPZ 251 244 RXRX .......... .......... .......... .......... .......... .......... .......... 251 344 NTNT 251 344 PZPZ 251 344 RXRX 251 344 SFSF 251 344 SJSJ .......... .......... .......... .......... .......... 251 444 NTNT 251 444 PZPZ 251 444 RXRX 251 444 SFSF 251 444 SJSJ AC Voltmeters Cont’d 11⁄2 Size Rating & Scale Type 21⁄2 Taut Band Taut Band 31⁄2 Pivot and Jewel Taut Band 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel AC VOLTMETERS — SELF-CONTAINED, IRON VANE TYPE, 400 Hz 150 Volts 300 Volts .......... .......... .......... .......... 251 245 PZPZ 251 245 RXRX .......... .......... 251 345 PZPZ 251 345 RXRX .......... .......... 251 445 PZPZ 251 445 RXRX AC VOLTMETERS — TRANSFORMER RATED, 0-150 VOLTS, IRON VANE TYPE, 60 Hz. (See Page 29 For Transformers) S C A L E O N L Y 600 Volts 750 Volts 3 kV .......... .......... .......... .......... .......... .......... 251 244 PZSJ 251 244 PZSM 251 244 PZVJ .......... .......... .......... 251 344 PZSJ 251 344 PZSM 251 344 PZVJ .......... .......... .......... 251 444 PZSJ 251 444 PZSM 251 444 PZVJ 255 337 PNPN 255 337 PTPT 251 437 PNPN 251 437 PTPT 255 437 PNPN 255 437 PTPT AC VOLTMETERS — EXPANDED SCALE, RECTIFIER TYPE 110-130 Volts 105-125 Volts .......... .......... .......... .......... .......... .......... 251 337 PNPN 251 337 PTPT AC VOLTMETERS — SELF-CONTAINED, RECTIFIER TYPE 10 Volts 15 Volts 20 Volts 25 Volts 30 Volts 251 130 MTMT 251 130 NDND 251 130 NGNG 251 130 NJNJ 251 130 NLNL 251 230 MTMT 251 230 NDND 251 230 NGNG 251 230 NJNJ 251 230 NLNL 255 230 MTMT 255 230 NDND 255 230 NGNG 255 230 NJNJ 255 230 NLNL 251 330 MTMT 251 330 NDND 251 330 NGNG 251 330 NJNJ 251 330 NLNL 255 330 MTMT 255 330 NDND 255 330 NGNG 255 330 NJNJ 255 330 NLNL 251 430 MTMT 251 430 NDND 251 430 NGNG 251 430 NJNJ 251 430 NLNL 255 430 MTMT 255 430 NDND 255 430 NGNG 255 430 NJNJ 255 430 NLNL 50 Volts 80 Volts 100 Volts 150 Volts 200 Volts 251 130 NTNT 251 130 PDPD 251 130 PKPK 251 130 PZPZ .......... 251 230 NTNT 251 230 PDPD 251 230 PKPK 251 230 PZPZ .......... 255 230 NTNT 255 230 PDPD 255 230 PKPK 255 230 PZPZ .......... 251 330 NTNT 251 330 PDPD 251 330 PKPK 251 330 PZPZ 251 330 RLRL 255 330 NTNT 255 330 PDPD 255 330 PKPK 255 330 PZPZ 255 330 RLRL 251 430 NTNT 251 430 PDPD 251 430 PKPK 251 430 PZPZ 251 430 RLRL 255 430 NTNT 255 430 PDPD 255 430 PKPK 255 430 PZPZ 255 430 RLRL 250 Volts 300 Volts .......... .......... .......... .......... .......... .......... 251 330 RSRS 251 330 RXRX 255 330 RSRS 255 330 RXRX 251 430 RSRS 251 430 RXRX 255 430 RSRS 255 430 RXRX AC Ammeters 11⁄2 Size Rating & Scale Type Taut Band 21⁄2 Taut Band 31⁄2 Pivot and Jewel Taut Band 41⁄2 Pivot and Jewel Taut Band Pivot and Jewel AC MICROAMMETERS AND MILLIAMMETERS — RECTIFIER TYPE 500 µA 800 µA 1 mA 1.5 mA 2 mA 251 110 EMEM 251 110 EWEW 251 110 FAFA 251 110 FDFD 251 110 FGFG 251 210 EMEM 251 210 EWEW 251 210 FAFA 251 210 FDFD 251 210 FGFG 255 210 EMEM 255 210 EWEW 255 210 FAFA 255 210 FDFD 255 210 FGFG 251 310 EMEM 251 310 EWEW 251 310 FAFA 251 310 FDFD 251 310 FGFG 255 310 EMEM 255 310 EWEW 255 310 FAFA 255 310 FDFD 255 310 FGFG 251 410 EMEM 251 410 EWEW 251 410 FAFA 251 410 FDFD 251 410 FGFG 255 410 EMEM 255 410 EWEW 255 410 FAFA 255 410 FDFD 255 410 FGFG 3 mA 5 mA 10 mA 20 mA 251 110 FNFN 251 110 FXFX 251 110 GZGZ 251 110 HFHF 251 210 FNFN 251 210 FXFX 251 210 GZGZ 251 210 HFHF 255 210 FNFN 255 210 FXFX 255 210 GZGZ 255 210 HFHF 251 310 FNFN 251 310 FXFX 251 310 GZGZ 251 310 HFHF 255 310 FNFN 255 310 FXFX 255 310 GZGZ 255 310 HFHF 251 410 FNFN 251 410 FXFX 251 410 GZGZ 251 410 HFHF 255 410 FNFN 255 410 FXFX 255 410 GZGZ 255 410 HFHF 11 Horizon Line AC Ammeters Cont’d AC MILLIAMMETERS — SELF-CONTAINED, 25-400 Hz, IRON VANE 10 mA 25 mA 50 mA 100 mA 200 mA .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 GZGZ 251 240 HJHJ 251 240 HYHY 251 240 JRJR 251 240 KAKA .......... .......... .......... .......... .......... 251 340 GZGZ 251 340 HJHJ 251 340 HYHY 251 340 JRJR 251 340 KAKA .......... .......... .......... .......... .......... 251 440 GZGZ 251 440 HJHJ 251 440 HYHY 251 440 JRJR 251 440 KAKA 500 mA .......... .......... 251 240 KMKM .......... 251 340 KMKM .......... 251 440 KMKM AC AMMETERS — SELF-CONTAINED, 25-400 Hz, IRON VANE 1 Amp 3 Amp 5 Amp 8 Amp 10 Amp .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 LALA 251 240 LJLJ 251 240 LSLS 251 240 MJMJ 251 240 MTMT .......... .......... .......... .......... .......... 251 340 LALA 251 340 LJLJ 251 340 LSLS 251 340 MJMJ 251 340 MTMT .......... .......... .......... .......... .......... 251 440 LALA 251 440 LJLJ 251 440 LSLS 251 440 MJMJ 251 440 MTMT 15 Amp 20 Amp 30 Amp 50 Amp 80 Amp .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 NDND 251 240 NGNG* 251 240 NLNL* .......... .......... .......... .......... .......... .......... .......... 251 340 NDND 251 340 NGNG* 251 340 NLNL* 251 340 NTNT* 251 340 PDPD* .......... .......... .......... .......... .......... 251 440 NDND 251 440 NGNG* 251 440 NLNL* 251 440 NTNT* 251 440 PDPD* *External magnetic shield included AC AMMETERS — TRANSFORMER-RATED, 0-5 AMPERES, 25-400 Hz, IRON VANE (See Page 29 For Transformers) S C A L E O N L Y 10 Amp 15 Amp 20 Amp 30 Amp 40 Amp .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 LSMT 251 240 LSND 251 240 LSNG 251 240 LSNL 251 240 LSNP .......... .......... .......... .......... .......... 251 340 LSMT 251 340 LSND 251 340 LSNG 251 340 LSNL 251 340 LSNP .......... .......... .......... .......... .......... 251 440 LSMT 251 440 LSND 251 440 LSNG 251 440 LSNL 251 440 LSNP 50 Amp 75 Amp 80 Amp 100 Amp 150 Amp .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 LSNT 251 240 LSPB 251 240 LSPD 251 240 LSPK 251 240 LSPZ .......... .......... .......... .......... .......... 251 340 LSNT 251 340 LSPB 251 340 LSPD 251 340 LSPK 251 340 LSPZ .......... .......... .......... .......... .......... 251 440 LSNT 251 440 LSPB 251 440 LSPD 251 440 LSPK 251 440 LSPZ 200 Amp 300 Amp 400 Amp 500 Amp 600 Amp 800 Amp .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 LSRL 251 240 LSRX 251 240 LSSC 251 240 LSSF 251 240 LSSJ 251 240 LSSN .......... .......... .......... .......... .......... .......... 251 340 LSRL 251 340 LSRX 251 340 LSSC 251 340 LSSF 251 340 LSSJ 251 340 LSSN .......... .......... .......... .......... .......... .......... 251 440 LSRL 251 440 LSRX 251 440 LSSC 251 440 LSSF 251 440 LSSJ 251 440 LSSN .......... .......... .......... .......... .......... .......... .......... .......... .......... .......... 251 240 LSVA 251 240 LSVB 251 240 LSVC 251 240 LSVE 251 240 LSVJ .......... .......... .......... .......... .......... 251 340 LSVA 251 340 LSVB 251 340 LSVC 251 340 LSVE 251 340 LSVJ .......... .......... .......... .......... .......... 251 440 LSVA 251 440 LSVB 251 440 LSVC 251 440 LSVE 251 440 LSVJ 1 Kiloamp 1.2 Kiloamp 1.5 Kiloamp 2.0 Kiloamp 3.0 Kiloamp AC Motor Load Indicators - Available in Horizon Line or New Big Look Size Rating Amps Scale Marking Terminal Resistance Ohms (±15%) 21⁄2 31⁄2 41⁄2 Cat. No. Cat. No. Cat. No. AC LOAD INDICATORS, PIVOT AND JEWEL TYPE 250 — 5-AMP CURRENT TRANSFORMER RATED, 60 Hz — IRON VANE TYPE 5 0-150% Motor Load Current Red Band — 100-150 5 0-150% Motor Load Current Green — 0-100 Yellow — 100-125, Red — 125-150 0.007 250 240 LSPZ7AAA 250 340 LSPZ7AAA 250 440 LSPZ7AAA 0.007 250 240 LSPZ7AAB 250 340 LSPZ7AAB 250 440 LSPZ7AAB AC LOAD INDICATORS, PIVOT AND JEWEL TYPE 251 — 5-AMP CURRENT TRANSFORMER RATED, 60 Hz — IRON VANE TYPE 12 5 0-150% Motor Load Current Red Band — 100-150 5 0-150% Motor Load Current Green — 0-100 Yellow — 100-125, Red — 125-150 0.007 251 240 LSPZ7AAJ 251 340 LSPZ7AAJ 251 440 LSPZ7AAJ 0.007 251 240 LSPZ7AAK 251 340 LSPZ7AAK 251 440 LSPZ7AAK AC Frequency Meters - Available in Horizon Line or New Big Look 11⁄2 Size Center Voltage Frequency Scale Hertz Hertz Cat. No. 21⁄2 31⁄2 41⁄2 Cat. No. Cat. No. Cat. No. AC FREQUENCY — PIVOT AND JEWEL, SELF-CONTAINED, ACCURACY ±3 PERCENT OF SPAN; I.E., 0.3 Hz FOR 45-55 AND 55-65, AND 1.2 Hz FOR 380-420 RANGE 120 120 120 120 50 55 60 400 45-55 45-65 55-65 380-420 .......... .......... .......... .......... 208 208 208 208 50 55 60 400 45-55 45-65 55-65 380-420 .......... .......... .......... .......... 240 240 240 240 50 55 60 400 45-55 45-65 55-65 380-420 .......... .......... .......... .......... Choose prefix 254 or 255 250 AGAG 250 AJAJ 250 ANAN 250 BKBK 250 GGGG 250 GJGJ 250 GNGN 250 HKHK 250 DGDG 250 DJDJ 250 DNDN 250 EKEK Choose prefix 254 or 255 350 AGAG 350 AJAJ 350 ANAN 350 BKBK 350 GGGG 350 GJGJ 350 GNGN 350 HKHK Choose prefix 254 or 255 350 DGDG 350 DJDJ 350 DNDN 350 EKEK 450 AGAG 450 AJAJ 450 ANAN 450 BKBK 450 GGGG 450 GJGJ 450 GNGN 450 HKHK 450 DGDG 450 DJDJ 450 DNDN 450 EKEK NOTE: For non-listed voltages, up to 480 VAC, frequency ranges or special calibration (accuracy ±2% of span) contact factory. For taut-band suspension replace prefix 254 with 250 and prefix 255 with 251. Stylist Series Overload: Voltmeters (AC + DC) - 50% momentary, 20% sustained. Ammeters (AC +DC) momentary: 10 times the rated current for 10 consecutive intervals of .5 seconds with 1 minute interval between successive applications; sustained: 20% for six hours. Type 260 and 264 Stylist Surface Mount Specifications Accuracy: All DC and AC iron vane, ±2% of fullscale, AC rectifier type; ±3% of fullscale (60 Hz sinewave). Expanded scale voltmeters ±5% of fullscale. Special order DC with mirror back scale (DC only) 31⁄2 41⁄2” Available @ ±1%. ANSI Specification: All meters meet ANSI Specifications C-39.1 (See page 14 for exceptions.) Scale Data: ARC 90% 95% METER SIZE AC IRON VANE TAUT BAND/ PIVOT & JEWEL 11⁄2” — 1.66” 21⁄2” 2.15” 2.29” 31⁄2” 2.70” 2.85” 4 ⁄2” 3.80” 4.01” 1 Insulation Level: 2600V/1 min. (21⁄2”-41⁄2”) 1500V/1 min. (11⁄2”) Response Time: 3 seconds (Max.) - Microammeters 2 seconds (Max.) - All other DC ratings 2.5 seconds (Max.) - All AC ratings Maximum 40% overshoot Dimensions: See page 36. Burden Data: AC Ammeter 5 amps @ 60 Hz, 0.5VA, Max. .5 Power factor lagging, AC voltmeter - unity power factor. Notes: Severe-duty meters are available to meet CSA or UL 1437 requirements in 21⁄2”-41⁄2” sizes. To order, add /UL or /CSA after catalog number, or contact factory. 13 Stylist Series DC Voltmeters Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 DC MILLIVOLTMETERS — ZERO-LEFT 0-50 0-100 260124ECEC 260124GBGB 26  224ECEC 26  224GBGB 26  324ECEC 26  324GBGB 26  424ECEC 26  424GBGB 26  225ECEC 26  225GBGB 26  325ECEC 26  325GBGB 26  425ECEC 26  425GBGB DC MILLIVOLTMETERS — ZERO-CENTER 50-0-50 100-0-100 260125ECEC 260125GBGB DC VOLTMETERS — ZERO-LEFT 0-1 0-1.5 0-2 0-3 0-5 260120LALA 260120LCLC 260120LELE 260120LJLJ 260120LSLS 26  220LALA 26  220LCLC 26  220LELE 26  220LJLJ 26  220LSLS 26  320LALA 26  320LCLC 26  320LELE 26  320LJLJ 26  320LSLS 26  420LALA 26  420LCLC 26  420LELE 26  420LJLJ 26  420LSLS 0-10 0-15 0-20 0-25 0-30 260120MTMT 260120NDND 260120NGNG 260120NJNJ 260120NLNL 26  220MTMT 26  220NDND 26  220NGNG 26  220NJNJ 26  220NLNL 26  320MTMT 26  320NDND 26  320NGNG 26  320NJNJ 26  320NLNL 26  420MTMT 26  420NDND 26  420NGNG 26  420NJNJ 26  420NLNL 0-40 0-50 0-75 0-80 0-100 260120NPNP 260120NTNT 260120PBPB 260120PDPD 260120PKPK 26  220NPNP 26  220NTNT 26  220PBPB 26  220PDPD 26  220PKPK 26  320NPNP 26  320NTNT 26  320PBPB 26  320PDPD 26  320PKPK 26  420NPNP 26  420NTNT 26  420PBPB 26  420PDPD 26  420PKPK * 0-150 0-200 0-250 0-300 0-500 260120PZPZ 260120RLRL 260120RSRS 260120RXRX 260120SFSF 26  220PZPZ 26  220RLRL 26  220RSRS 26  220RXRX 26  220SFSF 26  320PZPZ 26  320RLRL 26  320RSRS 26  320RXRX 26  320SFSF 26  420PZPZ 26  420RLRL 26  420RSRS 26  420RXRX 26  420SFSF * * * 0-600 0-750 0-1000 260120SJSJ 260120SMSM 260120SSSS 26  220SJSJ 26  220SMSM 26  220SSSS 26  320SJSJ 26  320SMSM 26  320SSSS 26  420SJSJ 26  420SMSM 26  420SSSS DC VOLTMETERS — ZERO-CENTER * * 5-0-5 10-0-10 15-0-15 25-0-25 50-0-50 260121LSLS 260121MTMT 260121NDND 260121NJNJ 260121NTNT 26  221LSLS 26  221MTMT 26  221NDND 26  221NJNJ 26  221NTNT 26  321LSLS 26  321MTMT 26  321NDND 26  321NJNJ 26  321NTNT 26  421LSLS 26  421MTMT 26  421NDND 26  421NJNJ 26  421NTNT 100-0-100 150-0-150 300-0-300 500-0-500 600-0-600 260121PKPK 260121PZPZ 260121RXRX 260121SFSF 260121SJSJ 26  221PKPK 26  221PZPZ 26  221RXRX 26  221SFSF 26  221SJSJ 26  321PKPK 26  321PZPZ 26  321RXRX 26  321SFSF 26  321SJSJ 26  421PKPK 26  421PZPZ 26  421RXRX 26  421SFSF 26  421SJSJ 5 ± 10% 12 ± 10% 15 ± 10% 28 ± 10% 48 ± 10% 26  238LYLY 26  238MYMY 26  238NFNF 26  238NHNH 26  238NSNS 26  338LYLY 26  338MYMY 26  338NFNF 26  338NHNH 26  338NSNS 26  438LYLY 26  438MYMY 26  438NFNF 26  438NHNH 26  438NSNS 120 ± 10% 150 ± 10% 300 ± 10% 26  238PPPP 26  238PYPY 26  238RWRW 26  338PPPP 26  338PYPY 26  338RWRW 26  438PPPP 26  438PYPY 26  438RWRW DC VOLTMETERS — EXPANDED SCALE DC VOLTMETERS — PERCENT DEVIATION ±.05% FULL SCALE ACCURACY 12 ± 10% 28 ± 10% 120 ± 10% 26  221MYMY 26  221NHNH 26  221PPPP 26  321MYMY 26  321NHNH 26  321PPPP 26  421MYMY 26  421NHNH 26  421PPPP NOTE ON ORDERING: The ranges and catalog numbers in this catalog refer to both surface and window mount panel meters. To specify your choice, replace the  in the catalog number with either of the following: 0 for Surface Mount (Taut Band), 1 for Window Mount (Taut Band), 4 for Surface Mount (Pivot & Jewel) or 5 for Window Mount (Pivot & Jewel). (11⁄2” is only available in Surface Mount (Taut Band). *Not ANSI. 14 Panel Meters DC Ammeters Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 26  200BZBZ* 26  200CFCF* 26  200CYCY 26  200DRDR 26  200EAEA 26  200EMEM 26  300BZBZ* 26  300CFCF* 26  300CYCY 26  300DRDR 26  300EAEA 26  300EMEM 26  400BZBZ* 26  400CFCF* 26  400CYCY 26  400DRDR 26  400EAEA 26  400EMEM 26  201BZBZ* 26  201CJCJ 26  201CYCY 26  201DRDR 26  201EMEM 26  301BZBZ* 26  301CJCJ 26  301CYCY 26  301DRDR 26  301EMEM 26  401BZBZ* 26  401CJCJ 26  401CYCY 26  401DRDR 26  401EMEM DC MICROAMMETERS — ZERO-LEFT 0-10 0-20 0-50 0-100 0-200 0-500 260100BZBZ 260100CFCF 260100CYCY 260100DRDR 260100EAEA 260100EMEM DC MICROAMMETERS — ZERO-CENTER 10-0-105 25-0-25 50-0-50 100-0-100 500-0-500 260101BZBZ 260101CJCJ 260101CYCY 260101DRDR 260101EMEM *Taut Band Only DC MILLIAMMETEERS — ZERO-LEFT 0-1 0-2 0-3 0-5 0-10 260100FAFA 260100FGFG 260100FNFN 260100FXFX 260100GZGZ 26  200FAFA 26  200FGFG 26  200FNFN 26  200FXFX 26  200GZGZ 26  300FAFA 26  300FGFG 26  300FNFN 26  300FXFX 26  300GZGZ 26  400FAFA 26  400FGFG 26  400FNFN 26  400FXFX 26  400GZGZ 0-15 0-20 0-25 0-30 0-50 260100HCHC 260100HFHF 260100HJHJ 260100HMHM 260100HYHY 26  200HCHC 26  200HFHF 26  200HJHJ 26  200HMHM 26  200HYHY 26  300HCHC 26  300HFHF 26  300HJHJ 26  300HMHM 26  300HYHY 26  400HCHC 26  400HFHF 26  400HJHJ 26  400HMHM 26  400HYHY 0-100 0-150 0-200 0-300 0-500 0-750 260100JRJR 260100JXJX 260100KAKA 260100KGKG 260100KMKM 260100KUKU 26  200JRJR 26  200JXJX 26  200KAKA 26  200KGKG 26  200KMKM 26  200KUKU 26  300JRJR 26  300JXJX 26  300KAKA 26  300KGKG 26  300KMKM 26  300KUKU 26  400JRJR 26  400JXJX 26  400KAKA 26  400KGKG 26  400KMKM 26  400KUKU DC MILLIAMMETERS — ZERO-CENTER 1-0-1 5-0-5 10-0-10 25-0-25 50-0-50 260101FAFA 260101FXFX 260101GZGZ 260101HJHJ 260101HYHY 26  201FAFA 26  201FXFX 26  201GZGZ 26  201HJHJ 26  201HYHY 26  301FAFA 26  301FXFX 26  301GZGZ 26  301HJHJ 26  301HYHY 26  401FAFA 26  401FXFX 26  401GZGZ 26  401HJHJ 26  401HYHY 100-0-100 200-0-200 500-0-500 260101JRJR 260101KAKA 260101KMKM 26  201JRJR 26  201KAKA 26  201KMKM 26  301JRJR 26  301KAKA 26  301KMKM 26  401JRJR 26  401KAKA 26  401KMKM DC MILLIAMMETERS — SUPPRESSED ZERO (Indicating receiving gauge applications ±3% F.S.) 0.25-1.25 1-5 4-20 10-50 260100FEFE 260100FYFY 260100HEHE 260100HXHX 26  200FEFE 26  200FYFY 26  200HEHE 26  200HXHX 26  300FEFE 26  300FYFY 26  300HEHE 26  300HXHX 26  400FEFE 26  400FYFY 26  400HEHE 26  400HXHX These meters are supplied with 0-100 dial labeled PERCENT. DC AMMETERS — ZERO-LEFT, SELF-CONTAINED 0-1 0-1.5 0-2 0-3 0-5 260100LALA 260100LCLC 260100LELE 260100LJLJ 260100LSLS 26  200LALA 26  200LCLC 26  200LELE 26  200LJLJ 26  200LSLS 26  300LALA 26  300LCLC 26  300LELE 26  300LJLJ 26  300LSLS 26  400LALA 26  400LCLC 26  400LELE 26  400LJLJ 26  400LSLS 0-10 0-15 0-20 260100MTMT — — 26  200MTMT 26  200NDND 26  200NGNG 26  300MTMT 26  300NDND 26  300NGNG 26  400MTMT 26  400NDND 26  400NGNG NOTE ON ORDERING: The ranges and catalog numbers in this catalog refer to both surface and window mount panel meters. To specify your choice, replace the  in the catalog number with either of the following: 0 for Surface Mount (Taut Band), 1 for Window Mount (Taut Band), 4 for Surface Mount (Pivot & Jewel) or 5 for Window Mount (Pivot & Jewel). (11⁄2” is only available in Surface Mount (Taut Band). 15 Stylist Series DC Ammeters Cont’d Size 11⁄2 Rating & Scale 21⁄2 31⁄2 41⁄2 DC AMMETERS — ZERO-LEFT, SELF-CONTAINED (cont’d) 0-25 0-30 0-50 — — — 26  200NJNJ 26  200NLNL 26  200NTNT 26  300NJNJ 26  300NLNL 26  300NTNT 26  400NJNJ 26  400NLNL 26  400NTNT DC AMMETERS — ZERO-LEFT ,50mV SHUNT RATED (LEAD RES. RANGE: .05-.07Ω)* S C A L E O N L Y 0-15 0-20 0-25 0-30 0-50 260124ECND 260124ECNG 260124ECNJ 260124ECNL 260124ECNT 26  224ECND 26  224ECNG 26  224ECNJ 26  224ECNL 26  224ECNT 26  324ECND 26  324ECNG 26  324ECNJ 26  324ECNL 26  324ECNT 26  424ECND 26  424ECNG 26  424ECNJ 26  424ECNL 26  424ECNT 0-75 0-100 0-150 0-200 0-300 260124ECPB 260124ECPK 260124ECPZ 260124ECRL 260124ECRX 26  224ECPB 26  224ECPK 26  224ECPZ 26  224ECRL 26  224ECRX 26  324ECPB 26  324ECPK 26  324ECPZ 26  324ECRL 26  324ECRX 26  424ECPB 26  424ECPK 26  424ECPZ 26  424ECRL 26  424ECRX 0-500 0-750 0-1000 0-1200 0-1500 0-2000 260124ECSF 260124ECSM 260124ECSS 260124ECSV 260124ECTC 260124ECTM 26  224ECSF 26  224ECSM 26  224ECSS 26  224ECSV 26  224ECTC 26  224ECTM 26  324ECSF 26  324ECSM 26  324ECSS 26  324ECSV 26  324ECTC 26  324ECTM 26  424ECSF 26  424ECSM 26  424ECSS 26  424ECSV 26  424ECTC 26  424ECTM DC AMMETERS — ZERO LEFT, 100mV SHUNT RATED (LEAD RES. RANGE: 0.4-0.8Ω)* S C A L E O N L Y 0-75 0-100 0-150 0-200 0-300 260124GBPB 260124GBPK 260124GBPZ 260124GBRL 260124GBRX 26  224GBPB 26  224GBPK 26  224GBPZ 26  224GBRL 26  224GBRX 26  324GBPB 26  324GBPK 26  324GBPZ 26  324GBRL 26  324GBRX 26  424GBPB 26  424GBPK 26  424GBPZ 26  424GBRL 26  424GBRX 0-500 0-750 0-1000 0-1200 0-1500 0-2000 260124GBSF 260124GBSM 260124GBSS 260124GBSV 260124GBTC 260124GBTM 26  224GBSF 26  224GBSM 26  224GBSS 26  224GBSV 26  224GBTC 26  224GBTM 26  324GBSF 26  324GBSM 26  324GBSS 26  324GBSV 26  324GBTC 26  324GBTM 26  424GBSF 26  424GBSM 26  424GBSS 26  424GBSV 26  424GBTC 26  424GBTM DC AMMETERS — ZERO-CENTER, SELF-CONTAINED 1-0-1 3-0-3 5-0-5 10-0-10 15-0-15 260101LALA 260101LJLJ 260101LSLS 260101MTMT — 26  201LALA 26  201LJLJ 26  201LSLS 26  201MTMT 26  201NDND 26  301LALA 26  301LJLJ 26  301LSLS 26  301MTMT 26  301NDND 26  401LALA 26  401LJLJ 26  401LSLS 26  401MTMT 26  401NDND 25-0-25 50-0-50 — — 26  201NJNJ 26  201NTNT 26  301NJNJ 26  301NTNT 26  401NJNJ 26  401NTNT DC AMMETERS — ZER0-CENTER, 50mV, SHUNT RATED (LEAD RES. RANGE: .05-.07Ω)* S C A L E O N L Y 15-0-15 25-0-25 50-0-50 75-0-75 100-0-100 260125ECND 260125ECNJ 260125ECNT 260125ECPB 260125ECPK 26  225ECND 26  225ECNJ 26  225ECNT 26  225ECPB 26  225ECPK 26  325ECND 26  325ECNJ 26  325ECNT 26  325ECPB 26  325ECPK 26  425ECND 26  425ECNJ 26  425ECNT 26  425ECPB 26  425ECPK 200-0-200 300-0-300 400-0-400 500-0-500 260125ECRL 260125ECRX 260125ECSC 260125ECSF 26  225ECRL 26  225ECRX 26  225ECSC 26  225ECSF 26  325ECRL 26  325ECRX 26  325ECSC 26  325ECSF 26  425ECRL 26  425ECRX 26  425ECSC 26  425ECSF *Shunts are not included. See Page 29 For 50mV Shunts. NOTE ON ORDERING: The ranges and catalog numbers in this catalog refer to both surface and window mount panel meters. To specify your choice, replace the  in the catalog number with either of the following: 0 for Surface Mount (Taut Band), 1 for Window Mount (Taut Band), 4 for Surface Mount (Pivot & Jewel) or 5 for Window Mount (Pivot & Jewel). (11⁄2” is only available in Surface Mount (Taut Band).). 16 Panel Meters AC Voltmeters Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 AC VOLTMETERS — TAUT BAND, MOVING COIL: SELF-CONTAINED, RECTIFIER TYPE 0-3 0-5 0-10 0-15 0-25 260130LJLJ 260130LSLS 260130MTMT 260130NDND 260130NJNJ 26  230LJLJ 26  230LSLS 26  230MTMT 26  230NDND 26  230NJNJ 26  330LJLJ 26  330LSLS 26  330MTMT 26  330NDND 26  330NJNJ 26  430LJLJ 26  430LSLS 26  430MTMT 26  430NDND 26  430NJNJ 0-50 0-100 0-150 0-300 0-500 0-600 260130NTNT 260130PKPK 260130PZPZ 260130RXRX 260130SFSF 260130SJSJ 26  230NTNT 26  230PKPK 26  230PZPZ 26  230RXRX 26  230SFSF 26  230SJSJ 26  330NTNT 26  330PKPK 26  330PZPZ 26  330RXRX 26  330SFSF 26  330SJSJ 26  430NTNT 26  430PKPK 26  430PZPZ 26  430RXRX 26  430SFSF 26  430SJSJ AC VOLTMETERS — TAUT BAND, MOVING COIL: TRANSFORMER RATED, 0-150V, RECTIFIER TYPE* S C A L E O N L Y 0-750 0-1500 0-3000 260130PZSM 260130PZTC 260130PZUA 26  230PZSM 26  230PZTC 26  230PZUA 26  330PZSM 26  330PZTC 26  330PZUA 26  430PZSM 26  430PZTC 26  430PZUA AC VOLTMETERS — TAUT BAND, MOVING COIL: EXPANDED SCALE, RECTIFIER TYPE Accuracy ±0.5%FS ±0.5%FS ±1.0%FS ±1.0%FS 105-125 210-250 95-135 190-270 26  237PTPT 26  237RRRR 26  237PJPJ 26  237RKRK 26  337PTPT 26  337RRRR 26  337PJPJ 26  337RKRK 26  437PTPT 26  437RRRR 26  437PJPJ 26  437RKRK AC VOLTMETERS — IRON VANE, PIVOT & JEWEL: SELF-CONTAINED, 60Hz* 0-500 0-5 0-10 0-15 0-30 0-50 26  244LJLJ 26  244LSLS 26  244MTMT 26  244NDND 26  244NLNL 26  244NTNT 26  344LJLJ 26  344LSLS 26  344MTMT 26  344NDND 26  344NLNL 26  344NTNT 26  444LJLJ 26  444LSLS 26  444MTMT 26  444NDND 26  444NLNL 26  444NTNT 0-100 0-150 0-300 0-500 0-600 26  244PKPK 26  244PZPZ 26  244RXRX 26  244SFSF 26  244SJSJ 26  344PKPK 26  344PZPZ 26  344RXRX 26  344SFSF 26  344SJSJ 26  444PKPK 26  444PZPZ 26  444RXRX 26  444SFSF 26  444SJSJ AC VOLTMETERS — IRON VANE, PIVOT & JEWEL: TRANSFORMER RATED 0-150 VOLTS, 60Hz* S C A L E O N L Y 26  244PZSJ 26  244PZSM 26  244PZVJ 0-600 0-750 0-3K 26  344PZSJ 26  344PZSM 26  344PZVJ 26  444PZSJ 26  444PZSM 26  444PZVJ *Iron Vane, Pivot & Jewel use only 0 for Surface Mount, 1 for Window Mount. Also, For Transformer Rated Voltmeters See Page 29 For Transformers. AC Ammeters Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 AC MILLIAMMETERS — TAUT BAND, MOVING COIL: SELF-CONTAINED, RECTIFIER TYPE 0-1 0-5 0-10 0-25 0-50 260110FAFA 260110FXFX 260110GZGZ 260110HJHJ 260110HYHY 26  210FAFA 26  210FXFX 26  210GZGZ 26  210HJHJ 26  210HYHY 26  310FAFA 26  310FXFX 26  310GZGZ 26  310HJHJ 26  310HYHY 26  410FAFA 26  410FXFX 26  410GZGZ 26  410HJHJ 26  410HYHY 0-100 0-200 260110JRJR — 26  210JRJR 26  210KAKA 26  310JRJR 26  310KAKA 26  410JRJR 26  410KAKA  See page 18 for notes on ordering. 17 Stylist Series AC Ammeters Cont’d Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 AC AMMETERS — TAUT BAND, MOVING COIL: SELF-CONTAINED, RECTIFIER TYPE, 60Hz±10% 0-1 0-1.5 0-2 0-3 0-5 26  210LALA 26  210LCLC 26  210LELE 26  210LJLJ 26  210LSLS 26  310LALA 26  310LCLC 26  310LELE 26  310LJLJ 26  310LSLS 26  410LALA 26  410LCLC 26  410LELE 26  410LJLJ 26  410LSLS 0-10 0-15 0-20 0-25 0-30 26  210MTMT 26  210NDND 26  210NGNG 26  210NJNJ 26  210NLNL 26  310MTMT 26  310NDND 26  310NGNG 26  310NJNJ 26  310NLNL 26  410MTMT 26  410NDND 26  410NGNG 26  410NJNJ 26  410NLNL AC AMMETERS — TAUT BAND, MOVING COIL: TRANSFORMER RATED, 0-5A, RECTIFIER TYPE, 60Hz±10% S C A L E O N L Y 0-50 0-60 0-75 0-100 0-150 0-200 26  210LSNT 26  210LSNW 26  210LSPB 26  210LSPK 26  210LSPZ 26  210LSRL 26  310LSNT 26  310LSNW 26  310LSPB 26  310LSPK 26  310LSPZ 26  310LSRL 26  410LSNT 26  410LSNW 26  410LSPB 26  410LSPK 26  410LSPZ 26  410LSRL 0-300 0-400 0-500 0-600 0-800 26  210LSRX 26  210LSSC 26  210LSSF 26  210LSSJ 26  210LSSN 26  310LSRX 26  310LSSC 26  310LSSF 26  310LSSJ 26  310LSSN 26  410LSRX 26  410LSSC 26  410LSSF 26  410LSSJ 26  410LSSN 0-1000 0-1500 0-2000 26  210LSSS 26  210LSTC 26  210LSTM 26  310LSSS 26  310LSTC 26  310LSTM 26  410LSSS 26  410LSTC 26  410LSTM AC AMMETERS — TAUT BAND, MOVING COIL: SEPARATE TRANSFORMERS, RECTIFIER TYPE, 60Hz±10% S C A L E O N L Y 0-1 0-1.5 0-2 0-3 0-5 260110LALA 260110LCLC 260110LELE 260110LJLJ 260110LSLS 0-10 0-15 0-20 0-25 0-30 260110MTMT 260110NDND 260110NGNG 260110NJNJ 260110NLNL 0-50 0-60 0-75 0-100 0-150 260110LSNT 260110LSNW 260110LSPB 260110LSPK 260110LSPZ 0-200 0-300 0-400 0-500 0-600 260110LSRL 260110LSRX 260110LSSC 260110LSSF 260110LSSJ 0-800 0-1000 0-1500 0-2000 260110LSSN 260110LSSS 260110LSTC 260110LSTM } } EACH METER IS SUPPLIED WITH AN EXTERNAL C.T. WITH INPUT RANGE MATCHING FULL SCALE INPUT. METER SUPPLIED WITH 5 AMP EXTERNAL C.T. — USER MUST PURCHASE ADDITIONAL C.T. OF PROPER SCALE RANGE WITH 5 AMP SECONDARY TO CONNECT TO EXT. 5 AMP C.T. SUPPLIED, SEE CATALOG 500 CTPT. AC MILLIAMMETERS — IRON VANE, PIVOT & JEWEL: SELF-CONTAINED, 50-400Hz* 0-10 0-25 0-50 0-100 0-250 0-500 26  240GZGZ 26  240HJHJ 26  240HYHY 26  240JRJR 26  240KDKD 26  240KMKM 26  340GZGZ 26  340HJHJ 26  340HYHY 26  340JRJR 26  340KDKD 26  340KMKM 26  440GZGZ 26  440HJHJ 26  440HYHY 26  440JRJR 26  440KDKD 26  440KMKM NOTE ON ORDERING: The ranges and catalog numbers in this catalog refer to both surface and window mount panel meters. To specify your choice, replace the  in the catalog number with either of the following: 0 for Surface Mount (Taut Band), 1 for Window Mount (Taut Band), 4 for Surface Mount (Pivot & Jewel) or 5 for Window Mount (Pivot & Jewel). (11⁄2” is only available in Surface Mount (Taut Band). *Iron Vane, Pivot & Jewel use only 0 for Surface Mount, 1 for Window Mount. 18 Panel Meters AC Ammeters Cont’d Size Rating & Scale 11⁄2 21⁄2 31⁄2 41⁄2 AC AMMETERS — IRON VANE, PIVOT & JEWEL: SELF-CONTAINED, 50-400Hz* 0-1 0-1.5 0-2 0-3 0-5 0-10 0-15 26  240LALA 26  240LCLC 26  240LELE 26  240LJLJ 26  240LSLS 26  240MTMT 26  240NDND 26  340LALA 26  340LCLC 26  340LELE 26  340LJLJ 26  340LSLS 26  340MTMT 26  340NDND 26  440LALA 26  440LCLC 26  440LELE 26  440LJLJ 26  440LSLS 26  440MTMT 26  440NDND 0-20 0-25 0-30 0-50 26  240NGNG 26  240NJNJ 26  240NLNL 26  240NTNT 26  340NGNG 26  340NJNJ 26  340NLNL 26  340NTNT 26  440NGNG 26  440NJNJ 26  440NLNL 26  440NTNT AC AMMETERS — IRON VANE, PIVOT & JEWEL: TRANSFORMER RATED, 0-5 AMPERES, 50-400Hz* S C A L E O N L Y 0-10 0-15 0-20 0-30 0-40 0-50 26  240LSMT 26  240LSND 26  240LSNG 26  240LSNL 26  240LSNP 26  240LSNT 26  340LSMT 26  340LSND 26  340LSNG 26  340LSNL 26  340LSNP 26  340LSNT 26  440LSMT 26  440LSND 26  440LSNG 26  440LSNL 26  440LSNP 26  440LSNT 0-75 0-80 0-100 0-150 0-200 0-300 26  240LSPB 26  240LSPD 26  240LSPK 26  240LSPZ 26  240LSRL 26  240LSRX 26  340LSPB 26  340LSPD 26  340LSPK 26  340LSPZ 26  340LSRL 26  340LSRX 26  440LSPB 26  440LSPD 26  440LSPK 26  440LSPZ 26  440LSRL 26  440LSRX 0-400 0-500 0-600 0-800 0-1K 0-1.2K 26  240LSSC 26  240LSSF 26  240LSSJ 26  240LSSN 26  240LSVA 26  240LSVB 26  340LSSC 26  340LSSF 26  340LSSJ 26  340LSSN 26  340LSVA 26  340LSVB 26  440LSSC 26  440LSSF 26  440LSSJ 26  440LSSN 26  440LSVA 26  440LSVB 0-1.5K 0-2.0K 0-3.0K 26  240LSVC 26  240LSVE 26  240LSVJ 26  340LSVC 26  340LSVE 26  340LSVJ 26  440LSVC 26  440LSVE 26  440LSVJ *Iron Vane, Pivot & Jewel use only 0 for Surface Mount, 1 for Window Mount. Also see Page 29 For Transformer-Rated Meters Frequency Meters Center Voltage Frequency Scale Hertz 11⁄2 (For 480V AC input contact factory) 21⁄2 31⁄2 41⁄2 FREQUENCY METERS — TAUT BAND OR PIVOT & JEWEL: SELF-CONTAINED 120 120 120 120 50 55 60 400 45-55 45-65 55-65 380-420 26  250AGAG 26  250AJAJ 26  250ANAN 26  250BKBK 26  350AGAG 26  350AJAJ 26  350ANAN 26  350BKBK 26  450AGAG 26  450AJAJ 26  450ANAN 26  450BKBK 208 208 208 208 50 55 60 400 45-55 45-65 55-65 380-240 26  250GGGG 26  250GJGJ 26  250GNGN 26  250HKHK 26  350GGGG 26  350GJGJ 26  350GNGN 26  350HKHK 26  450GGGG 26  450GJGJ 26  450GNGN 26  450HKHK 240 240 240 240 50 60 400 55 45-55 55-65 380-420 45-65 26  250DGDG 26  250DNDN 26  250EKEK 26  250DJDJ 26  350DGDG 26  350DNDN 26  350EKEK 26  350DJDJ 26  450DGDG 26  450DNDN 26  450EKEK 26  450DJDJ NOTE ON ORDERING: The ranges and catalog numbers in this catalog refer to both surface and window mount panel meters. To specify your choice, replace the  in the catalog number with either of the following: 0 for Surface Mount (Taut Band), 1 for Window Mount (Taut Band), 4 for Surface Mount (Pivot & Jewel) or 5 for Window Mount (Pivot & Jewel). 19 Terminal Resistance Values ALL VALUES ARE ±15% TOLERANCE New Big Look and Horizon Line Rating and Scale Taut Band New Big Look and Horizon Line Pivot and Jewel Rating and Scale Taut Band Pivot and Jewel DC MILLIAMMETERS — ZERO-LEFT DC Voltmeters (See pages 2, 3, 8) DC VOLTMETER — ZERO-LEFT 1.0 Volts 1.5 Volts 3 Volts 5 Volts 8 Volts 10 Volts 15 Volts 30 Volts 80 Volts 100 Volts 150 Volts 200 Volts 250 Volts 300 Volts 500 Volts 600 Volts 1,000 Ohms/Volt 1,000 Ohms/Volts O N L Y 500 Volts 600 Volts 750 Volts 10.5 Ohms 10.5 Ohms 10.5 Ohms 42.4 Ohms 42.4 Ohms 42.4 Ohms DC VOLTMETERS — ZERO-CENTER 5-0-5 Volts 10-0-10 Volts 30-0-30 Volts 50-0-50 Volts 80-0-80 Volts 150-0-150 Volts 300-0-300 Volts 500-0-500 Volts 600-0-600 Volts 1,000 Ohms/Volt 1,000 Ohms Volt O N L Y 500-0-500 Volts 600-0-600 Volts 750-0-750 Volts 6.8 Ohms 6.8 Ohms 6.8 Ohms 5 mA 10 mA 20 Ohms 5.0 Ohms 10.0 Ohms 5.0 Ohms 20 mA 25 mA 30 mA 50 mA 80 mA 2.39 Ohms 1.99 Ohms 1.66 Ohms 1.0 Ohms 0.64 Ohms 2.4 Ohms 2.0 Ohms 1.7 Ohms 1.0 Ohms 0.63 Ohms 100 mA 150 mA 200 mA 250 mA 300 mA 0.50 Ohms 0.33 Ohms 0.25 Ohms 0.2 Ohms 0.16 Ohms 0.50 Ohms 0.33 Ohms 0.25 Ohms 0.20 Ohms 0.167 Ohms 500 mA 800 mA 0.10 Ohms 0.06 Ohms 0.100 Ohms 0.063 Ohms 1-0-1 mA 6.8 Ohms 22.4 Ohms 5-0-5 mA 10-0-10 mA 20-0-20 mA 5.0 Ohms 2.4 Ohms 1.2 Ohms 9.7 Ohms 4.9 Ohms 2.4 Ohms 25-0-25 mA 30-0-30 mA 50-0-50 mA 100-0-50 mA 150-0-150 mA 1.0 Ohms 0.88 Ohms 0.51 Ohms 0.51 Ohms 0.33 Ohms 2.0 Ohms 1.7 Ohms 1.0 Ohms 0.51 Ohms 0.33 Ohms 200-0-200 mA 250-0-250 mA 300-0-300 mA 500-0-500 mA 0.25 Ohms 0.2 Ohms 0.17 Ohms 0.10 Ohms 0.25 Ohms 0.20 Ohms 0.168 Ohms 0.100 Ohms 22.4 Ohms 22.4 Ohms 22.4 Ohms 1 Amp 1.5 Amp 2 Amp 3 Amp 5 Amp 0.050 Ohms 0.033 Ohms 0.025 Ohms 0.0169 Ohms 0.010 Ohms 0.050 Ohms 0.033 Ohms 0.025 Ohms 0.0169 Ohms 0.0100 Ohms 10 Amp 15 Amp 20 Amp 30 Amp 50 Amp 0.0050 Ohms 0.0033 Ohms 0.0025 Ohms 0.00167 Ohms 0.00100 Ohms 0.0050 Ohms 0.0033 Ohms 0.0025 Ohms 0.00167 Ohms 0.00100 Ohms DC AMMETERS — ZERO-LEFT, 50 mV, SHUNT RATED DC Ammeters 20 Amp 30 Amp 50 Amp 75 Amp 100 Amp (See pages 3-5, 8-10) DC MICROAMMETERS — ZERO-LEFT 20 50 100 200 500 µA µA µA µA µA 2000 Ohms 2000 Ohms 484 Ohms 121 Ohms 40 Ohms ............ ............ ............ 980 Ohms 228 Ohms 20-0-20 50-0-50 100-0-100 200-0-200 500-0-500 µA µA µA µA µA 12000 Ohms 484 Ohms 121 Ohms 750 Ohms 10.5 Ohms S C A L E O N L Y 150 Amp 200 Amp 250 Amp 300 Amp 400 Amp 500 Amp 600 Amp 800 Amp DC MICROAMMETERS — ZERO-CENTER 20 42.4 Ohms DC AMMETERS — ZERO-LEFT DC VOLTMETERS — ZERO-CENTER, RATED 1-0-1 mA DC, FOR USE WITH EXTERNAL RESISTORS S C A L E 10.5 Ohms DC MILLIAMMETERS — ZERO-CENTER DC VOLTMETERS — ZERO-LEFT, RATED 0-1 mA DC, FOR USE WITH EXTERNAL RESISTORS S C A L E 1 mA ............... ............... 980 Ohms 228 Ohms 42.4 Ohms 1 Kiloamp 1.5 Kiloamp 2 Kiloamp 25 Ohms 12.5 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms New Big Look and Horizon Line Rating and Scale Taut Band Pivot and Jewel DC AMMETERS — ZERO-LEFT, 100 mV, SHUNT RATED 20 Amp 40 Amp 50 Amp 75 Amp 100 Amp S C A L E O N L Y 150 Amp 200 Amp 250 Amp 300 Amp 400 Amp 50 Ohms 25 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms 1,000 Ohms/Volt 1,000 Ohms/Volt 20-0-20 Amp 30-0-30 Amp 50-0-50 Amp 0.0025 Ohms 0.00167 Ohms 0.00100 Ohms 0.0025 Ohms 0.00167 Ohms 0.00100 Ohms 10 mA 25 mA 50 mA 100 mA 200 mA 2158 Ohms 341 Ohms 84 Ohms 21 Ohms 4.1 Ohms 500 mA 0.7 Ohms AC AMMETERS — SELF-CONTAINED, 25-400 Hz (IRON VANE) DC AMMETERS — ZERO-CENTER, 50 mV, SHUNT RATED 50 Ohms 25 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms Calibrated for use with two-way Shunt lead resistance of 0.065 Ohms AC Voltmeters (See pages 6-7, 11-12) AC MILLIAMMETERS, SELF-CONTAINED, 25-400 Hz (IRON VANE) 0.0500 Ohms 0.0250 Ohms 0.0100 Ohms 0.0050 Ohms 0.0033 Ohms (IRON VANE) See pages 5-6, 10-11 AC VOLTMETERS, SELF-CONTAINED, 60 Hz 3 Volts 5 Volts 10 Volts 15 Volts 30 Volts 11.1 Ohms 29.0 Ohms 110 Ohms 251 Ohms 779 Ohms 50 Volts 100 Volts 150 Volts 300 Volts 500 Volts 2,500 Ohms 10,000 Ohms 15,000 Ohms 70,260 Ohms 117,260 Ohms 600 Volts 140,000 Ohms AC VOLTMETERS, SELF-CONTAINED, 400 Hz (IRON VANE) 15,268 Ohms 70,900 Ohms AC VOLTMETERS, TRANSFORMER RATED, 60 Hz, 150 Volts (IRON VANE) SCALE 600 Volts ONLY 750 Volts 3 Kv 50 Volts 80 Volts 100 Volts 150 Volts 200 Volts AC Ammeters 0.0500 Ohms 0.0250 Ohms 0.0100 Ohms 0.0050 Ohms 0.0033 Ohms 150 Volts 300 Volts Pivot and Jewel 250 Volts 300 Volts 1-0-1 Amp 2-0-2 Amp 5-0-5 Amp 10-0-10 Amp 15-0-15 Amp 20-0-20 Amp 50-0-50 Amp 75-0-75 Amp 100-0-100 Amp 150-0-150 Amp Taut Band 10 Volts 15 Volts 20 Volts 25 Volts 30 Volts DC AMMETERS — ZERO-CENTER O N L Y Rating and Scale AC VOLTMETERS (RECTIFIER TYPE) 500 Amp 600 Amp 800 Amp 1 Kiloamp 2 Kiloamp S C A L E New Big Look and Horizon Line 1 Amp 3 Amp 5 Amp 8 Amp 10 Amp 0.17 Ohms 0.015 Ohms 0.007 Ohms 0.003 Ohms 0.0024 Ohms 15 Amp 20 Amp 30 Amp 50 Amp 80 Amp 0.0016 Ohms 0.001 Ohms 0.0006 Ohms 0.0004 Ohms 0.0004 Ohms AC AMMETERS — TRANSFORMER RATED 60 Hz (IRON VANE) 5 AMPERES 10 Amp 15 Amp 20 Amp 30 Amp 40 Amp S C A L E O N L Y 50 Amp 75 Amp 80 Amp 100 Amp 150 Amp 0.007 Ohms 200 Amp 300 Amp 400 Amp 500 Amp 600 Amp 800 Amp 1 Kiloamp 1.2 Kiloamp 1.5 Kiloamp 2.0 Kiloamp 3.0 Kiloamp 15,000 Ohms 15,000 Ohms 15,000 Ohms 21 Terminal Resistance Values ALL VALUES ARE ±15% TOLERANCE Stylist Series Rating and Scale Stylist Series Taut Band Pivot and Jewel Rating and Scale Taut Band Pivot and Jewel DC MILLIAMMETERS — ZERO-CENTER DC Voltmeters 1-0-1 mA 5-0-5 mA 10-0-10 mA 25-0-25 mA 50-0-50 mA 100-0-100 mA 200-0-200 mA 500-0-500 mA (See page 14) DC MILLIVOLTMETERS — ZERO-LEFT 50 mV 100 mV 10 Ohms 20 Ohms 12.5 Ohms 25 Ohms 11.2 Ohms 9.9 Ohms 5.0 Ohms 2.0 Ohms 1.0 Ohms 0.53 Ohms 0.25 Ohms 0.10 Ohms 22 Ohms * * * * * * * DC MILLIVOLTMETERS — ZERO-CENTER 50-0-50 mV 100-0-100 mV 20 Ohms 40 Ohms DC MILLIAMMETERS — SUPPRESSED ZERO 25 Ohms 50 Ohms (Indicating receiving guage applications) 0.25-1.25 mA 1-5 mA 4-20 mA 10-50 mA DC VOLTMETERS — ZER0-LEFT 1 Volt thru 500 Volts 600 Volts 1000 Ohms/Volt 10000 Ohms/Volt 1000 Ohms/Volt 10000 Ohms/Volt 600-0-600 Volts 1 Amp 1.5 Amp 2 Amp 3 Amp 5 Amp 10 Amp 15 Amp 20 Amp 25 Amp 30 Amp 50 Amp (See pages 15-16) DC MICROAMMETERS — ZERO-LEFT 5900 Ohms 4600 Ohms 2000 Ohms 660 Ohms 190 Ohms 116 Ohms N/A N/A 6000 Ohms 1950 Ohms 980 Ohms 228 Ohms S C A L E DC MICROAMMETERS — ZERO-CENTER 10-0-10 uA 25-0-25 uA 50-0-50 uA 100-0-100 uA 500-0-500 uA 4600 Ohms 2000 Ohms 660 Ohms 190 Ohms 32 Ohms 32 11.2 30 3.5 4.9 3.3 2.5 1.9 1.7 1.0 0.49 0.33 0.25 0.17 0.10 0.067 Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms O N L Y 15 Amps thru 2000 Amps N/A 6000 Ohms 1950 Ohms 980 Ohms 42.4 Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms * * * * * * * * * * * 10 Ohms * Stylist Series Rating and Scale 42.4 Ohms 22 Ohms * * * * * * * * * * * * * * 0.05 0.033 0.025 0.017 0.010 0.0050 0.0033 0.0025 0.0020 0.0017 0.0010 DC AMMETERS — ZERO-LEFT, 50mV, SHUNT RATED DC MILLIAMMETERS — ZERO-LEFT 1 mA 2 mA 3 mA 5 mA 10 mA 15 mA 20 mA 25 mA 30 mA 50 mA 100 mA 150 mA 200 mA 300 mA 500 mA 750 mA 42.4 Ohms * * * 1000 Ohms/Volt 10000 Ohms/Volt DC Ammeters 10 uA 20 uA 50 uA 100 uA 200 uA 500 uA Ohms Ohms Ohms Ohms DC AMMETERS — ZERO-LEFT, SELFCONTAINED DC VOLTMETERS — ZERO-CENTER 5-0-5 Volts thru 500-0-500 Volts 32 31 6.2 2.4 S C A L E Pivot and Jewel DC AMMETERS — ZERO-LEFT, 100mV, SHUNT RATED O N L Y 75 Amps thru 2000 Amps 20 Ohms DC AMMETERS — ZERO-CENTER, SELFCONTAINED 1-0-1 Amp 3-0-3 Amp 5-0-5 Amp 10-0-10 Amp 15-0-15 Amp 25-0-25 Amp 50-0-50 Amp 0.050 Ohms 0.017 Ohms 0.010 Ohms 0.0050 Ohms 0.0033 Ohms 0.0020 Ohms 0.0010 Ohms DC AMMETERS — ZERO-CENTER, 50mV, SHUNT RATED S C A L E O N L Y 15-0-15 Amps thru 500-0-500 Amps *Contact factory 22 20 Ohms Stylist Panel Meter Stylist Series Rating and Scale Stylist Series Taut Band AC Voltmeters Rating and Scale AC VOLTMETERS — SELF-CONTAINED, RECTIFIER TYPE 900 Ohms/Volt AC VOLTMETERS — TRANSFORMER RATED, 0-150V, RECTIFIER TYPE 750 Volts thrugh 3000 Volts (SCALE ONLY) 130 KOhms 1 Amp 1.5 Amp 2 Amp 3 Amp 5 Amp 10 Amp 15 Amp 20 Amp 25 Amp 30 Amp 50 Amp 60 Amps thru 2000 Amps (SCALE ONLY) 225 Ohms/Volt 50 Amps thru 2000 Amps 3 Volts 5 Volts 10 Volts 15 Volts 30 Volts 50 Volts 100 Volts 150 Volts 300 Volts 500 Volts 600 Volts * .015 Ohms * Stylist Series Rating and Scale 11.1 Ohms 29.0 Ohms 110.0 Ohms 251.0 Ohms 779.0 Ohms 2.5 KOhms 10.1 KOhms 15.1 KOhms 70.3 KOhms 117.3 KOhms 139.9 KOhms 600 Volts thrugh 3KVolts (SCALE ONLY) 10 mA 25 mA 50 mA 100 mA 250 mA 500 mA 15.1 KOhms Stylist Series Taut Band AC Ammeters Pivot and Jewel 2.158 341.0 83.7 21.0 2.75 .704 KOhms Ohms Ohms Ohms Ohms Ohms AC AMMETERS — IRON VANE, SELFCONTAINED, 50-400 Hz 1 Amp 1.5 Amps 2 Amps 3 Amps 5 Amps 10 Amps 15 Amps 20 Amps 25 Amps 30 Amps 50 Amps .17 .110 .044 .0153 .0071 .0024 .0017 .0009 .0007 .0006 .0004 Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms Ohms (See pages 17-19) AC AMMETERS — IRON VANE, TRANSFORMER RATED, 0-5 AMPS, 50-400Hz AC MILLIAMMETERS — SELF-CONTAINED, RECTIFIER TYPE 630 Ohms 180 Ohms 95 Ohms 39 Ohms 35 Ohms 18 Ohms 9 Ohms .20 Ohms Pivot & Jewel AC MILLIAMMETERS — IRON VANE, SELFCONTAINED, 50-400Hz AC VOLTMETERS — IRON VANE, TRANSFORMER RATED, 150 VOLTS, 60Hz 1 mA 5 mA 10 mA 25 mA 50 mA 100 mA 200 mA 500 mA .02 Ohms Pivot & Jewel AC VOLTMETERS — IRON VANE, SELFCONTAINED, 60 Hz Rating and Scale * * * * * * * * * * * AC AMMETERS — SEPARATE TRANSFORMER RECTIFIER TYPE (11⁄2” SIZE) Stylist Series Rating and Scale .09 Ohms .07 Ohms .05 Ohms .03 Ohms 0.2 Ohms 0.1 Ohms .007 Ohms .005 Ohms .005 Ohms .003 Ohms .002 Ohms AC AMMETERS — TRANSFORMER RATED, 0-5A, RECTIFIER TYPE AC VOLTMETERS — EXPANDED SCALE, RECTIFIER TYPE 105-125 Volts thru 190-270 Volts Pivot and Jewel AC AMMETERS — SELF-CONTAINED, RECTIFIER TYPE (See page 17) 3 Volts thru 600 Volts Taut Band * * * * * * * * 10 Amps thru 3KAmps (Scale Only) .0071 Ohms *Contact Factory 23
250 340 LSPB 价格&库存
很抱歉,暂时无法提供与“250 340 LSPB”相匹配的价格&库存,您可以联系我们找货
