EMPTY ENCLOSURE
TK PS 2518-11-m
TK PS 2518-11-m
Empty enclosure
CUSTOMIZABLE
254 x 180 x 111 mm
Article number: 10590801
Empty enclosure, Base and cover: polystyrene, Grey, similar
to RAL 7035
with metric knockouts
Technical data
Accessory
ASS-gro - External hinge set
Measures
HBA - Mounting material
Width:
254 mm
MPS-KRI - Mounting plate
Length:
180 mm
NS 35-216 - Standard rail
Height:
111 mm
TK ABL - External fixing lugs kit
97 mm
TK MPI-2518 - Mounting plate
Inner height:
Material
Environmental attributes
Base:
Polystyrene, grey,
similar to RAL 7035
Cover:
Polystyrene, grey,
similar to RAL 7035
Sealing:
Cover screw:
Polyurethane
Polyamide 6, fiberglass reinforced
Ambient temperature (min.):
-25 °C
Ambient temperature (max.):
40 °C
Ambient temperature (24 h):
35 °C
Max. rel. humidity at 25° C (short
term):
95%
Max. rel. humidity at 40° C:
50%
Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved.
Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299
Page 1 of 2
Powered by TCPDF (www.tcpdf.org)
EMPTY ENCLOSURE
TK PS 2518-11-m
Other attributes
Ingress protection:
IP66 - acc. EN
60529 / DIN VDE
0470-1
Impact resistance:
IK07 acc. DIN EN
5012 / VDE 0470
Part 100
Protection class:
II - isolate
protection acc. VDE
0106
Rated insulation voltage AC:
690 V
Rated insulation voltage DC:
1000 V
Heavy metals-free:
Yes
PVC-free:
Yes
Silicone-free:
Yes
Fitted for outdoor application:
No
Combustion behaviour acc. to UL 94:
Combustion behaviour acc. to VDE:
HB acc. UL94
650°C acc. VDE
0471/ EN 60695
sealable:
Yes
Weatherproof:
No
Cable entries:
Yes
Page 2 of 2
很抱歉,暂时无法提供与“10590801”相匹配的价格&库存,您可以联系我们找货
