733-414 01
733-414 01
    SPELSBERG
    SPELSBERG - 733-414 01 - Plastic Enclosure, Junction Box, Polycarbonate, 300 mm, 315 mm, 155 mm, IP6...
733-414 01 数据手册
SMALL-SCALE DISTRIBUTORS AK 14 AK 14 Small-scale distributors CUSTOMIZABLE 315 x 300 x 155 mm Article number: 73341401 Small-scale distributors - Industrial Quality -, 1-row, 14 distribution units, integrated ventilation elements to reduce the formation of condensate water, elastic entries on top, masking and labelling strips, additional double-membrane seals and other accessories screwless PE/N terminal rails each with 3 screwable clamping points, Clamping units 2.5 - 16 mm², 14 screwless type clamping units 1.5 - 4 mm² Technical data Certificates Measures Width: 315 mm Length: 300 mm Height: 155 mm Accessory AK3 KBL - Cable cover with document compartment Inner height: 95 mm AK3 NS35-14 - Standard rail Inner width: 295 mm AK3 NS35-275 - Standard rail AK3 ABL-ES - External fixing lugs Material AK3 STD - shroud contactsgrowing putlet Base: Polycarbonate Cover: Polycarbonate Sealing: Cover screw: Polyurethane Polyamide 6, fiberglass reinforced AK3 KS M50 - Combination cable gland M50 AK AS - Masking off strips AK AS-v - Masking off strips AK SGA-1 - Lock fittings AK SGA-2 - Lock fittings KLS N 35 - Terminal block Created on 2016-02-02. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) SMALL-SCALE DISTRIBUTORS AK 14 KLS PE 35 - Terminal block Other attributes Ingress protection: IP65 - acc. to EN 60529 / DIN VDE 0470-1 Impact resistance: IK08 Tackable: Yes Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Color: Grey Rated insulation voltage AC: 1000 V Rated insulation voltage DC: 1500 V sealable: Functional integrity: KST M25-33 - Combi connector Environmental attributes Ambient temperature (min.): -35 °C Ambient temperature (max.): 80 °C Ambient temperature (24 h): 60 °C Max. rel. humidity at 25° C (short term): 90% Max. rel. humidity at 40° C: 50% Yes none Number of distribution units: 14 EMC design: No with lock: No Created on 2016-02-02. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
733-414 01 价格&库存
很抱歉,暂时无法提供与“733-414 01”相匹配的价格&库存,您可以联系我们找货
