334 904 01
334 904 01
    SPELSBERG
    SPELSBERG - 334 904 01 - Plastic Enclosure, Junction Box, Polyethylene (PE), 23 mm, 40 mm, 56 mm, IP...
334 904 01 数据手册
JUNCTION BOX Q 4-L Q 4-L Junction box 56 x 40 x 23 mm Article number: 33490401 Junction box acc. DIN EN 60598 (VDE 0711), 4 entries, with strain relief acc. VDE 0606, 2 of which are accessible from the top, strain relief clamp for pendulum lights, with external fixing positions grey, without terminal Technical data Certificates Measures Width: 56 mm Length: 40 mm Height: 23 mm Material Base: Polypropylene Cover: Polypropylene Environmental attributes Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Ambient temperature (24 h): 35 °C Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) JUNCTION BOX Q 4-L Other attributes Color: Rated cross section: Tackable: Entries: sealable: Rated insulation voltage AC: grey 2,5 mm² No 4 No 400 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Ingress protection: Weatherproof: Equiqment: IP20 - acc. EN 60529 / DIN VDE 0470-1 No None Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
334 904 01 价格&库存
很抱歉,暂时无法提供与“334 904 01”相匹配的价格&库存,您可以联系我们找货
