10540301
10540301
    SPELSBERG
10540301 数据手册
EMPTY ENCLOSURE TK PS 99-6-m TK PS 99-6-m Empty enclosure CUSTOMIZABLE 94 x 94 x 57 mm Article number: 10540301 Empty enclosure, Base and cover: polystyrene, Grey, similar to RAL 7035 with metric knockouts Technical data Accessory ASS-kl - External hinge set Measures HBA - Mounting material Width: 94 mm MPS-KRI - Mounting plate Length: 94 mm TK ABL - External fixing lugs kit Height: 57 mm TK DST - Spacing kit Inner height: 45 mm TK MPI-99 - Mounting plate TS 15-80 - Standard rail Material Base: Polystyrene, grey, similar to RAL 7035 Cover: Polystyrene, grey, similar to RAL 7035 Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Polyurethane Ambient temperature (24 h): 35 °C Sealing: Cover screw: Polyamide 6, fiberglass reinforced Environmental attributes Max. rel. humidity at 25° C (short term): 95% Max. rel. humidity at 40° C: 50% Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) EMPTY ENCLOSURE TK PS 99-6-m Other attributes Ingress protection: IP66 - acc. EN 60529 / DIN VDE 0470-1 Impact resistance: IK07 acc. DIN EN 5012 / VDE 0470 Part 100 Protection class: II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690 V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: No Combustion behaviour acc. to UL 94: Combustion behaviour acc. to VDE: HB acc. UL94 650°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: No Cable entries: Yes Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
10540301 价格&库存
很抱歉,暂时无法提供与“10540301”相匹配的价格&库存,您可以联系我们找货
