JUNCTION BOX
HP 100-L
HP 100-L
Junction box
113 x 113 x 58 mm
Article number: 32690001
Junction box acc. DIN EN 60670 (VDE 0606), Ui=690V, 7
recessed stepped nipples, seal range 5 - 21 mm, for terminals
up to 10 mm²
grey, without terminals
Technical data
Accessory
Abox 025/040 KLS-2,5²/4² - Terminal block
Measures
WK 060 KLS-6² - Terminal block
Width:
113 mm
WK 100 KLS-10² - Terminal block
Length:
113 mm
BST M20 - Ventilation seal
Height:
58 mm
DMS M20 - Double-membrane seals
Inner height:
32 mm
DMS M25 - Double-membrane seals
Inner width:
103.5 mm
KVR M20-GDB/MGM - Cable gland
KVR M20-MGM - Cable gland
Material
KVR M25-MGM - Cable gland
Base:
polypropylene,
flame-retardent
Cover:
polypropylene,
flame-retardent
SNI M20 - Stepped nipple
SNI M25 - Stepped nipple
Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved.
Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299
Page 1 of 2
Powered by TCPDF (www.tcpdf.org)
JUNCTION BOX
HP 100-L
Other attributes
Equiqment:
Entries:
Rated cross section:
Tackable:
Environmental attributes
None
Ambient temperature (min.):
-25 °C
11
Ambient temperature (max.):
40 °C
10 mm²
Ambient temperature (24 h):
35 °C
No
Rated insulation voltage AC:
690 V
Explosion safety:
none
Fire protection:
none
sealable:
No
Heavy metals-free:
Yes
PVC-free:
Yes
Silicone-free:
Yes
Ingress protection:
Weatherproof:
Max. rel. humidity at 25° C (short
Therm):
95%
Max. rel. humidity at 40° C:
50%
IP55 - acc. EN
60529 / DIN VDE
0470-1
No
Page 2 of 2
很抱歉,暂时无法提供与“326-900.”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+77.92932
- 5+76.37501
- 10+74.82069
- 20+73.25451
- 50+71.19000
