735-414
735-414
    SPELSBERG
735-414 数据手册
DISTRIBUTION BOARD AK 14 AK 14 Distribution board CUSTOMIZABLE 300 x 300 x 142 mm Article number: 73541401 Distribution board, 1 row, 14 modules, screwless PE/N terminal rails each with 3 screwable clamping points, 2.5 - 16 mm², 14 screwless clamping points, 1.5 - 4 mm², elastic entries on top, with cable covering, masking and labelling strips, additional double-membrane seals and other accessories Technical data Accessory AK KS-IP65 - Combi set Measures AK SGA-1 - Lock fittings Width: 300 mm Length: 300 mm Height: 142 mm Material BST M20 - Ventilation seal Environmental attributes Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Base: Polystyrene, grey, similar to RAL 7035 Ambient temperature (24 h): 35 °C Cover: Polystyrene, grey, similar to RAL 7035 Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Sealing: Cover screw: Polyurethane Polyamide 6, fiberglass reinforced Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) DISTRIBUTION BOARD AK 14 Other attributes Color: Ingress protection: Number of distribution units: Tackable: Fire protection: grey IP65 - acc. EN 60529 / DIN VDE 0470-1 14 Yes none Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes sealable: Yes Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
735-414 价格&库存
很抱歉,暂时无法提供与“735-414”相匹配的价格&库存,您可以联系我们找货
